Old Fri, Oct-12-2007, 06:22:06 PM   #21
johnnyboi1016
Reputation: 0 johnnyboi1016 has disabled reputation
shall we re-visit this issue once weather gets warm again? i'm interested to know if it solves it for you bigneil...
Jump to top johnnyboi1016 is offline   Reply With Quote
Old Sat, Apr-19-2008, 02:23:00 PM   #22
M TOPLS
Bullet the Wonder Dog!
M TOPLS's Avatar
Reputation: 0 M TOPLS is on a distinguished road
Originally Posted by M TOPLS View Post
Sorry to report that I recently had the same symptoms that many of you describe -- oil pressure light on, ticking, etc. I put thicker oil in and that helped for awhile, but wasn't a permanent fix. We tried replacing the sensor next. Didn't solve the problem, so at 115K, I got a new oil pump and everything's been fine since. Also fixed the OPN at the same time, so now I don't have to worry about that falling out in the future.
Well, let's revisit this oil pressure thing again because my oil pressure problem is back rearing its ugly head. As you can see above, I replaced the oil pump and switch last year and since then, the oil pressure light has flickered once in awhile, but nothing to overly concern me. Well, we had the first hot weather of the year in the northeast yesterday and the oil pressure light came on frequently when I was in stop and go traffic on the highway. When I got up to normal highway speeds, the light didn't come on -- it only came on when I was slowing to or at an idle.
Does this mean I'm due for some type of rebuild or should I try changing the oil weight to 20/50? I just had the oil changed about 1000 miles ago and the shop said they used either 10/30 or 10/40 (regular oil - my car has used non-synthetic oil it's whole life). When I used to live in TX, I used 20/50 in my e30 and never had any issues (didn't have my e36 back then).
Any thoughts? I'm moving back to TX in about 2.5 weeks and was going to drive this 97 M3 all the way there. Will it make it? I had no problems on a sunny 2 hour drive to NJ last weekend, but the temps outside were only around 65 degrees and I was not in any stop and go traffic.
I'M MORE FUN WITH MY TOP DOWN
99 M - Palmetto Green / Kyalami Orange; 97 M3 - Hellrot / Black; 88 M3 - Alpinweiss / Red. My Web Site
Jump to top M TOPLS is offline   Reply With Quote
Old Fri, May-09-2008, 10:14:09 PM   #23
bigneil
bigneil's Avatar
Reputation: 0 bigneil is on a distinguished road
I'm happy to report that this problem (which went away during the winter) was solved by installing a new Oil Temperature Sensor, which is located between the oil filter and the engine. It's a tight squeeze to access it but you shouldn't need to remove the oil filter (though removing the lid helps). You need a large socket. Bigger than a typical socket set or medium adjustable wrench will allow. The O2 sensor socket might work.
Jump to top bigneil is offline   Reply With Quote
Old Tue, Sep-30-2008, 01:02:08 PM   #24
TWRViper
Reputation: 0 TWRViper is on a distinguished road
Bigneil - What is a "Oil Temperature Sensor?" Do you mean coolant temperature sensor?
My oil pressure light is flickering at hot idle too. I run 5w30.
Jump to top TWRViper is offline   Reply With Quote
Old Tue, Sep-30-2008, 05:06:49 PM   #25
TheM
Reputation: 0 TheM is on a distinguished road
I think an oil pressure switch might be the culprit, not sure what a temp sensor has to do with it.
2002 M3 SteelGray/Cinnamon, TCKline, Besian, ACT clutch
Jump to top TheM is offline   Reply With Quote
Old Wed, Oct-01-2008, 01:27:33 AM   #26
Isis M
Soundgarden 2010
Isis M's Avatar
Reputation: 0 Isis M is on a distinguished road
are you overheating at all at idle with the a/c on? for me the flicker was the pusher fan being dead part number 64508364093
That sailboat is Mvious!
Sold: 1997 Arctic M
Jump to top Isis M is offline   Reply With Quote
Old Tue, Jan-06-2009, 02:07:09 PM   #27
bigneil
bigneil's Avatar
BMW is saying we don't have an oil temperature sensor but I know I replaced this. Does anyone have the part number or correct name?
Thanks!
Nevermind I see we got merged and I had already posted the number last year!
Part #12-61-7-568-480
Old Tue, Jan-06-2009, 08:16:14 PM   #28
Isis M
Soundgarden 2010
Isis M's Avatar
Thanks!
BMW told you that, wow that is pretty tired!!
Sold: 1997 Arctic M
Old Tue, Jan-06-2009, 09:44:22 PM   #29
s50swapped
Reputation: 0 s50swapped is on a distinguished road
Just a warning. I 'thought' I had a faulty switch on my m52b28. Then I lost oil pressure @ 145mph. Not cool.
Jump to top s50swapped is offline   Reply With Quote
Old Tue, Jan-06-2009, 11:40:25 PM   #30
Sirius
How many licks..
Sirius's Avatar
What caused it?
♪♫♪♪♫♪ Trevor ♪♫♪♪♫♪
97' M3. '10 R6.
flicker, hot, light, oil
Flickering battery light, never stays on more than 2 secs, don't flicker for days ? gixxer E46 M3 (2001-2006) 40 Sat, Mar-28-2009 02:01:44 AM
help: battery flicker, now light dimmer doesn't work jacclark E46 M3 (2001-2006) 1 Wed, Jun-11-2008 08:20:33 PM
Oil Pressure Light at Hot Idle??? alpinesaloon E36 M3 (1992-1999) 4 Tue, Jun-10-2008 12:53:44 AM
parking light flicker mugenh22a4 Faults, Fixes and DIY 0 Mon, Aug-28-2006 12:14:08 AM
Oil light flicker bigneil E36 M3 (1992-1999) 5 Tue, Oct-04-2005 11:55:23 PM
Discussing Oil Light Flicker (when hot) in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
