Old Mon, Apr-26-2010, 07:09:55 PM   #31
CKintner
CKintner's Avatar
Reputation: 0 CKintner is on a distinguished road
Default DMTL Pump Code
Originally Posted by MadeInPhilly View Post
what is the code for a failing DMTL pump? or the cat code that you got? what does DMTL stand for?
I think the code is P1434
I used a Actron reader from Autozone. I searched for a while and I think the P1434 code translates to the DMTL pump failure.
2011 M3 /// Competition Package /// SMG /// DINAN Exhaust ///
Stepping Stones:
2002 M3 (stock), 2004 Subaru WRX STi (stock), 1991 Nissan 300ZX Twin Turbo (~420hp), 1990 Honda Prelude Si, 1993 Corvette (stock), 1986 Nissan 300ZX (stock), 1990 Nissan 300ZX Twin Turbo (stock), 1987 Ford Mustang (~275hp)
Jump to top CKintner is offline   Reply With Quote
Old Sat, Jun-26-2010, 12:37:59 PM   #32
ALwAyS4SaLe
Reputation: 0 ALwAyS4SaLe is on a distinguished road
I know this thread hasn't been updated for a while. I got the code that says diagnostic tank leak (Code 176). VAC read the code and they said they have no clue. After searching on the forums, I am assuming that it is the pump because they cleared the codes multiple times and it kept coming back every 500 miles of driving. So I guess I will be making an appointment or attempting to get this taken care of at VAC. I will let you guys know what happens.
Jump to top ALwAyS4SaLe is offline   Reply With Quote
Old Thu, Nov-22-2012, 06:15:07 PM   #33
dcspeed
dcspeed's Avatar
Reputation: 0 dcspeed is on a distinguished road
Default Re: DMTL pump throwing SES light?
I just got an SES as well and looked up the codes and found out it's DMTL related. I am posting just to add the codes to this thread for anyone else doing any future searching.
Using my CEN-TECH 99722 OBDII/EOBD Scanner Code Reader, I got code P1434.
Using the Peake R5 FCX 3 I got table 1b and codes
b0 - DM-TL Error
b5 - Filler cap open
Given the b5 code, I just double checked my gas cap was on tight and reset the codes. So far the SES has not come back on just running in my garage. Hopefully that did it my case, I will post back up if the SES returns.
Jump to top dcspeed is offline   Reply With Quote
Old Wed, Mar-27-2013, 01:53:00 AM   #34
stukreit
Reputation: 0 stukreit is on a distinguished road
I have a 2002 m3 that shot P1434 during smog test (and a few times over the past months). So, I'll be ordering up a DTML, sealing grommit, and gas cap.
The car is at UCLA, I'm not. Can anyone recommend a reasonable shop?
Stuart
Jump to top stukreit is offline   Reply With Quote
Old Mon, Apr-01-2013, 02:41:29 AM   #35
meccanoble
///M3CCANOBLE
Reputation: 0 meccanoble is on a distinguished road
Just wanted to let you guys know I got this same code a good 5,000+ miles ago and replaced a canister like sensor in the rear of my car. Code went away after driving under 100 miles. I found the instructions on how to replace here somewhere, very easy fix.
///M3CCANOBLE
SOLD 03 Steel Grey 6MT
Eisenmann Race 83mm + section II| RE Rasp Pipe| D/A Street Software| Vogtland Springs| KONI Yellow Adjustables| Kenwood KDC X994| smoked LED tails & corners| 330 SSK/knob/boot| Dynaudio 362 Comps (custom kicks) & 2X 10" Alpine type r subs| Alpine PDX 4.150 & 1.1000| Matte gille/grille| Clifford 50.7x pager alarm| Clutchstop (1 1/4")| CDV Delete| Stoptech SS lines/Powerslot Slotted Rotors/OEM pads| Poly RTABS| Armrest Delete| Umnitza V4 Opaque AE|
R.I.P.
04 Mystic Blue w/ Cinnamon SMG (STOCK)
Jump to top meccanoble is offline   Reply With Quote
Old Mon, Feb-17-2014, 01:41:17 PM   #36
1BadPig
Reputation: 0 1BadPig is on a distinguished road
Can anyone give me the pump's part number and the best place to order?
Jump to top 1BadPig is offline   Reply With Quote
Old Tue, Feb-18-2014, 05:29:23 AM   #37
itsme
itsme's Avatar
Reputation: 0 itsme is on a distinguished road
China
Should be P/N #13
http://realoem.com/bmw/showparts.do?...88&hg=16&fg=10
-Wing
2002.5 Stl Grey M3 SMG II
Jump to top itsme is offline   Reply With Quote
Old Sat, Dec-06-2014, 01:36:44 PM   #38
John-03Conv6sp
Reputation: 0 John-03Conv6sp is on a distinguished road
Smile Code P1434 "No DTC definition" was New DMTL Pump for Me
03. M3, Convertible, 6sp, 103,000 miles, no accident damage, garaged
History: Out of nowhere SES lit. Code: P1434 "No DTC definition found" Checked forums and found reference to gas cap and DMTL pump as possible causes. Some references were also made to Secondary Air Pump but was able to confirm mine was operational and I think that will pop a different code than P1434.
Purchased (at dealer), 13 Nov 2014:
p/n 16-11-7-222-391 FILLER CAP List $31.99 Net $20.86
p/n 16-13-7-193-479 LEAK DIAGNOSTIC...(pump) List $170.24 Net $132.08
Actions:
1. Replaced filler cap, 1 minute (Yeah, I'm slow), SES remained lit for next 100 miles and multiple restarts
2. Replaced pump, 30 minutes
3. Cleared codes, 2 minutes
4. No SES again after more than 200 miles and 30 restarts, 2 weeks.
Notes:
1. Pump is fairly easy replacement on E46 M3 because more room between muffler heat shield and pump/filter assembly than regular E46.
2. Use car ramps (backing up, of course) for easy access. Have a nice blanket to lie on and maybe a little wine and cheese for a picnic. Perhaps a pillow if you want to take a nap. (Hey, it was a nice day in Florida when I did this.)
3. Need #10 socket and/or #10 open/box end wrench, and #20 torx bit with some means to turn it (there isn't enough room for a ratchet head to fit on a torx bit. For easy access to torx bolts on regular E46 (and I suppose an M3 too) loosen the two main bolts that hold up the entire pump/filter assembly and lower it a couple of inches.
4. SES should clear itself after several restarts (20+?) and a few miles (100+?) but a lot faster if you have friend at AutoZone or Advance who will reset codes even though they're not supposed to.
5. Google "bmw e46 dmtl pump replacement" for many pics and references for doing this easy job.
6. Hope this helps someone.
Jump to top John-03Conv6sp is offline   Reply With Quote
Old Thu, Sep-01-2016, 11:35:48 AM   #39
cyberlando
cyberlando's Avatar
Reputation: 0 cyberlando is on a distinguished road
did anyone experience bad gas mileage with this pump being defective?
mine has been bad for about 5000 miles now and my MPG is at roughly 13.5 to 14 on a good day.
Engine:
[] Euro Headers [] Euro Cats [] OEM Section 2 AR20[] B&B Exhaust [] AFE Stage 2
Interior:
[] Led Interior [] DICE Module [] Auxilary 3.5 jack [] 4 channel Amp with component speakers.....and more
Suspension/Handling:
[] KW V3 [] Eibach F&R Sways [] Vibratechnics Tranny mount [] UUC RTAB
[] Vibratechnics Motor Mount [] SSBL [] Turner Camber Plates
[] 90A Akg Subframe Bushings [] Akg Differential Bushings [] Subframe Renforcement
Jump to top cyberlando is offline   Reply With Quote
dmtl, light, pump, ses, throwing
Need Help: DIY for DMTL Pump replacement IR M3 Faults, Fixes and DIY 5 Sat, Aug-28-2010 06:55:38 AM
SES Light : P0133, dealer replace the 02 sensor, 1 week later again the same SES code Seblavoie E46 M3 (2001-2006) 14 Fri, Oct-17-2008 09:40:21 PM
SES light and SMG Failure light...funny story jateshk E46 M3 (2001-2006) 1 Tue, May-20-2008 08:24:02 PM
SES Light BadReligion E46 M3 (2001-2006) 0 Tue, Oct-09-2007 02:53:22 AM
SES light keeps going on and off M3addict9802 E46 M3 (2001-2006) 2 Wed, Aug-08-2007 05:38:08 PM
Discussing DMTL pump throwing SES light? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
