Old Thu, Apr-07-2011, 05:08:49 PM   #21
M3ANMACHINE
@natrajusa
M3ANMACHINE's Avatar
Originally Posted by Heckafunctional View Post
yeah..sure
when are you free?
Awesome.
I need to order the cpv first, but I'd like to do the install next weekend hopefully
2011 E90///M3 | Space Grey | Fox Red | DCT | ZCP | Slicktop
APEX | BIMMERWORLD | COBY WHEEL | CORSA | H&R | MACHT SCHNELL | PEDALHAUS
2014 F15 X5 | Space Grey | M-Sport
Old Thu, Apr-07-2011, 05:19:22 PM   #22
duracellttu
Default Re: DIY: CPV valve
Originally Posted by Car.Addict View Post
Thanks for the DIY. Seems this is coming up for everyone at once. Does anyone know what to torque the new CPV in at?
This was a question I had too. Do you just hand tighten?
Also, do you need any locktite on the CPV?
Last question, does this have to be done during an oil change? If I just take out the CPV will oil start gushing out? (Sorry if this is a noob question, just started doing my own car repairs)
2005 BMW M3 ZCP - Black/Black Built not bought. All DIY!
Evolve-R | AP V2 Headers | CPI Euro200R (200 cell) | SS Non-res X-pipe + Race | 3.91 w/ 3 stage clutch | TCK SA 450/500 | Vorshlag Camber Plates
Rogue Engineering ASP, RSM, RTABs, TM | TMS Sway Bars, Camber Arms, Pullies | Mason Race Strut, Rear X-Brace | AS 30% SSK | aFe Stage 2 | SPAL Fan
AKG FCABs, SFB | Redish Reinforcement | Turbo Toys V2 Hub | WPC Treated Rod Bearings
Old Thu, Apr-07-2011, 06:38:55 PM   #23
BlazenXLT
We've had one yes, what about second breakfast?
BlazenXLT's Avatar
Reputation: 0 BlazenXLT is on a distinguished road
Just hand tight. If there's a torque spec, I've never seen it.
No loctite.
You can do it with oil in the car (I did). Some oil will run out, but nothing that a paper towel can't handle.
Jump to top BlazenXLT is offline   Reply With Quote
Old Thu, Apr-07-2011, 06:58:09 PM   #24
duracellttu
Thanks, I plan on doing this when I change out the cooling system next month. About to hit 100k and I want her to last another 100k!
Old Thu, Apr-07-2011, 07:49:35 PM   #25
Car.Addict
Car.Addict's Avatar
Reputation: 0 Car.Addict is on a distinguished road
No loctite.
Thanks, I figured it couldn't be in there too tight. I Just figured since some folks are saying they are tearing them up when they pull them out, that maybe there was some torque on them. "Tech tight" works for me.
Jump to top Car.Addict is offline   Reply With Quote
Old Thu, Apr-07-2011, 09:24:16 PM   #26
Xtreme M3
Brake.Enter.Apex.Exit.Acc elerate
Xtreme M3's Avatar
Reputation: 0 Xtreme M3 is on a distinguished road
Originally Posted by caliSTile View Post
I would've used this DIY myself when I found out the dealer said my CPV was leaking. Fortunately I was still within CPO extended warranty. Currently at 73,xxx miles as a daily.
The dealer CPO'ed it? i was told thats not covered by the CPO from my dealer... and they quoted me 1400 to repair it. Thankfully i took care of it when i installed my headers.
John
BMW M3 ZCP
2005 - TiAg/Cinn - 6spd
Performance: CSL Headers/BMW Msport 4:10/BW Race Exh/TMS Intake/Epic Tune(GTS3)/TMS Race Pulleys/ BW Oil DV/ BW Solid Trans and Engine Mounts/ BW Oil Cooler and CR Radiator, BW Diff Cooler
Safety: Schroth Profi II 6pt Hans/Hans/4l Fire Suppression
Brakes: PFC Z45 (F), PFC DD Rear
Suspension: MCS Rear Coilover 2Way 800/425, Rogue RTAB/FCAB/RSM/RLCA/GC Camber Plates/H&R Front Sway/ F&R Subframe/PF Subframe bushings
Wheels: Apex Arc-8 w/ 275/35 Hankook C51/ Apex Arc-8 Hoosier (R6)/ TR-1 18x9.5 Hoosier Wets (WET)
Interior: OMP HTE/BW Solid Shifter/Jaffster Shift Knob/CF Sunroof Delete/ Full Cage (Dave Weaver)
Exterior: BW Brake Ducts/Vorsteiner Rear Diffuser, BW Dive Planes, BW Wing, Weaver Splitter
Jump to top Xtreme M3 is offline   Reply With Quote
Old Thu, Apr-07-2011, 10:07:38 PM   #27
M3ANMACHINE
@natrajusa
Just ordered my CPV from Turner and will be doing the swap next week!
Irvine BMW wanted $55 for the CPV and stated that retail was $73...
Old Thu, Apr-07-2011, 10:15:19 PM   #28
Heckafunctional
Do you even racecar bro?
Heckafunctional's Avatar
Reputation: 0 Heckafunctional is on a distinguished road
Originally Posted by M3ANMACHINE View Post
Awesome.
alrighty
just pm me when you're ready
Jump to top Heckafunctional is offline   Reply With Quote
Old Thu, Apr-07-2011, 10:16:15 PM   #29
Heckafunctional
yeah
bob smith I think wanted $70
ended up getting it at center bmw for $34 I think..
don't really remember
Old Fri, Apr-08-2011, 03:08:01 AM   #30
Xtreme M3
Xtreme M3's Avatar
i was told you can simply replace the washer instead of the whole nut/screw/valve assembly - is this true? I replaced the whole thing when i did mine however my friend said he believed you can just remove the old metal washer and install a new one, i cant remember if that was the case or not. From the picture its hard to tell...
John
BMW M3 ZCP
Discussing DIY: CPV valve in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
