Old Mon, Aug-15-2011, 04:06:51 PM   #101
oocutioo
Reputation: 0 oocutioo is on a distinguished road
Viet Nam
Good info. Thanks
Sent from my MB860 using Tapatalk
Jump to top oocutioo is offline   Reply With Quote
Old Mon, Aug-15-2011, 08:19:59 PM   #102
suaveflooder
suaveflooder's Avatar
Reputation: 0 suaveflooder is on a distinguished road
Here's where I am now. Not a bad job (so far). Mine was leaking for sure and the o-ring is a little crispy
2004 IR Slicktop
Jump to top suaveflooder is offline   Reply With Quote
Old Mon, Aug-15-2011, 08:23:11 PM   #103
roarf
Jimmies: Not Rustled
roarf's Avatar
Reputation: 0 roarf is on a distinguished road
Default Re: DIY: CPV valve
Originally Posted by M Nectar View Post
Many thanks for the DIY!
Replaced my CPV this afternoon -- a serious PITA to get out with the stock US headers. It is really, really tight. I used a craftsman 9/16" drag link; no way it was coming out with the screw bit socket. Save yourself the time and use a drag link if possible.
I wasn't expecting but a few drops and ended up with a face full of oil. This much oil came out of mine:
[/IMG]
Is your pan/shield full of oil or is that water?
'02 M5 - Carbon Black/Silverstone
'01 M3 - Imola Red/Black
Jump to top roarf is offline   Reply With Quote
Old Mon, Aug-15-2011, 08:55:20 PM   #104
Dewstain
E90 Driver
Dewstain's Avatar
Reputation: 0 Dewstain has disabled reputation
My pan was WAY dirtier than that. Nice and clean now though. My o-ring was completely squared off too.
Mind your manners, guys. This is FOT.
Jump to top Dewstain is offline   Reply With Quote
Old Mon, Aug-15-2011, 09:41:55 PM   #105
lucad2
lucad2's Avatar
Reputation: 0 lucad2 is on a distinguished road
[QUOTE=TigerDave;1064874511]Looks like I'm not the first to come across this:
http://m3forum.net/m3forum/showthread.php?t=202623
These M10 bolts apparently stretch upon installation. The idea is to torque them to 43 ft-lb, and then stretch them by turning the bolt another 90 degrees.
At $2.50 per bolt, I'll just go buy some (12) new ones to be on the safe side before tackling this job.
http://www.pelicanparts.com/cgi-bin/...30%2E%39ZNS%33
I havent took of the subframe reinforcement plate but I just by 12 of the same bolt, or are they different sizes?
"M" The most powerful letter in the world
Originally Posted by wyskass View Post
If a new owner showed up at some meet or started talking to you in the parking lot, would you tell him to STFU and suggest he read a book?
Jump to top lucad2 is offline   Reply With Quote
Old Tue, Aug-16-2011, 04:53:15 AM   #106
suaveflooder
[QUOTE=lucad2;1065011064]
They are all the same size
2004 IR Slicktop
Old Tue, Aug-16-2011, 08:08:39 PM   #107
M Nectar
M Nectar's Avatar
Reputation: 0 M Nectar is on a distinguished road
Yep, it's full of oil
An amazing amount of oil seeps out of that pesky CPV when it leaks.
Got me a can of brake cleaner and prettied up my reinforcement shield after replacing the CPV o-ring. No more oil!
Jump to top M Nectar is offline   Reply With Quote
Old Fri, Oct-07-2011, 10:54:51 PM   #108
kokgo20
kokgo20's Avatar
Do u guys tourq that sucker? if yes what do u tourq it to?
Build thread
Old Sun, Oct-09-2011, 07:44:50 PM   #109
Heckafunctional
Do you even racecar bro?
Heckafunctional's Avatar
Reputation: 0 Heckafunctional is on a distinguished road
I looked for a tq spec..couldn't find one..
Jump to top Heckafunctional is offline   Reply With Quote
Old Sun, Oct-09-2011, 10:31:57 PM   #110
Cuz5150
Cuz5150
Cuz5150's Avatar
Reputation: 0 Cuz5150 is on a distinguished road
Like they say in the industry, when u can't find tq. specs,---> "mechanic tight"
http://im1.shutterfly.com/media/47a3cc29b3127ccef48539c87df200000030O00AaNHDJi0YuG  IPbz4a/cC/f%3D0/ls%3D00108141284420131209001350520.JPG/ps%3D50/r%3D0/rx%3D550/ry%3D400/
2007 Z4 Coupe/Black/Black/6mt/Premium/Xenon
2004/M3/Vert/Black/Imola/6mt/Cold/Xenon/HK
2006/M3/Coupe/Mystic/Black/6mt/ZCP/Xenon/HK
2009/135i/Coupe/Alpine/Black/6mt/M-sport/Idrive-sold
2002 998 Ducati-sold
-Diplomacy is saying "nice doggie" while trying to find a rock
Jump to top Cuz5150 is offline   Reply With Quote
Discussing DIY: CPV valve in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
