Old Fri, Dec-15-2017, 04:31:53 PM   #341
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
Default Re: M3 SMG pump reconditioning
Originally Posted by Dr M3an M3 View Post
Are the issues occurring even in colder (winter temps) or only when it's warm out, or when stuck in traffic? Have you relocated the SMG pump?
yes. the current smg issue happens during cold or warm days. it's either a starting issue or engaging in gear after starting. but once the car starts, the issue seems to be gone. it only occurs during morning starts.
since having this issue i've changed the gps and compression spring. currently the fault codes are pointing towards a bad electric motor.
i'm currently in talks with burkhart. i'll read the fault codes right when i cant start the car and will report burkhart. initially that had thought it was the valve body seals, but the pressure tests shows my smg can old pressure.
Tischer aka GetBmwParts
Old Sat, Dec-16-2017, 12:28:52 AM   #342
scoopy128
Reputation: 0 scoopy128 is on a distinguished road
Btw, after you changed your smg motor and accumulator how many miles did you get before you got the cog light again
Jump to top scoopy128 is offline   Reply With Quote
Old Sat, Dec-16-2017, 12:38:16 AM   #343
daytonaviolet
OEM CSL Whoore
i would say 10k-12k miles. i'd have to check actual miles.
Discussing M3 SMG pump reconditioning in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
