Old Tue, Jul-08-2014, 02:12:09 AM   #131
SliM3
SliM3's Avatar
Default Re: M3 SMG pump reconditioning
Little update fellas:
I managed to strip the SMG pump down to pretty much nothing and wanted to post a few pics for reference.
Aluminum block, pump head & pressure relief valve
Pump head showing the pinions, with a .25 cent piece for size comparison
Block, pump head, & pressure relief valve disassembled
Pressure relief valve:
I don't recall this ever being mentioned in this thread, and if so my apologies. After looking at everything, the pressure relief valve looks to serve a dual purpose.
  • First, this is where the fluid returns to the reservoir by overcoming the spring rate when the shift cylinders are actuated.
  • Second, per the function of a pressure relief valve it serves to regulate system pressure and protect the accumulator in an event where the electric motor might run continuously (for instance).
If the spring inside were to fail or the o-ring deteriorates it's possible fluid will leak back into the reservoir, subsequently slowly bleeding-off system pressure, and causing the electric motor to run continuously. I could also see this being mistaken as a bad accumulator.
Unfortunately this little $0.95 part is non-replaceable and could cost you a pump. Very unlikely, but still worth considering when troubleshooting.
I'm (slowly) working on a Solidworks model of the aluminum block so we can have a clear picture of how fluid flows through it. Stay tuned..
///M3 '06 Carbon Black
-Benjamin Franklin
- Fuel adaptations explained
- Checksum Verification
Jump to top SliM3 is online now   Reply With Quote
Old Tue, Jul-08-2014, 06:59:50 AM   #132
SteveEvans
Reputation: 0 SteveEvans is on a distinguished road
United Kingdom
Are you sure about the pressure relief valve? I'd believed it to be a one way valve with pressure relief such that pressure wouldn't bleed back when the pump stopped, but also that it would prevent over pressuring the system if the pump overran.
There are two drillings in the block, one right next to the valve, which appear to be used for fluid return.
Some more close up photos of the individual parts would be good, as per my first post. Macro time!
Thanks,
Steve
Jump to top SteveEvans is offline   Reply With Quote
Old Tue, Jul-08-2014, 12:51:21 PM   #133
SliM3
SliM3's Avatar
Thanks,
Steve
Here's a crude drawing of the pressure/return circuit machined into the aluminum block, verified by snaking safety wire through the various ports. Again, I'll get the Solidworks model done to illustrate it a little better.
If you you look at the top of the block where the outlet ports are you'll see one of the plugs used after drilling (indicated by black dots), and the two located on the side.
I believe there is also a ball/spring type check valve installed in the block right after the pump pressure inlet. Obviously this prevents pressure from surging back into the pump head and destroying the electric motor.
You can see how all the ports intersect in one way or another, with the pressure relief valve as the common return back to the reservoir. Also, that is the only direction of flow through the valve (pressure/return circuit <O----- reservoir).
I have to look at the block again, as it's not in front of me, but I meticulously looked over this thing and didn't see any other ports intersected other than the ones I identified.
-Benjamin Franklin
Old Tue, Jul-08-2014, 08:57:55 PM   #134
SteveEvans
United Kingdom
I stand corrected.
Edit: Just realised I posted this very image on the previous page! Doh!
Steve
Old Tue, Jul-08-2014, 10:32:05 PM   #135
SliM3
SliM3's Avatar
No sir!! Actually I stand corrected. Didn't notice it before but it looks like they machined inside two of the solenoid ports, where the holes are drilled, for return.
Definitely good to know what pressure the relief valve opens.
Sent from my Stenograph.
-Benjamin Franklin
Old Tue, Jul-08-2014, 10:43:49 PM   #136
cntrvrsy
44
cntrvrsy's Avatar
United Nations
Loving this thread And yes I do think it should be a 'sticky', not sure if here in the E46 section or DIY section.
I know there's places to replace or rewind the motor but are there any i.d. markings to compare if the SMG pump motor is the same as the DSC motor or even the ABS motor from a few Ford cars as mentioned on this forum? The Ford motors are way cheaper.
sig engineered by Fcukupayme
Jump to top cntrvrsy is offline   Reply With Quote
Old Tue, Jul-08-2014, 10:54:11 PM   #137
SteveEvans
United Kingdom
We're all learning!
Interesting SMG 2 manual HERE if you've not seen it before.
Steve
Old Tue, Jul-15-2014, 06:31:13 PM   #138
jdamore44
Reputation: 0 jdamore44 is on a distinguished road
I just bought a used smg pump but it came with a broken red snap ring ( anyone have a spare ?? I would be so greatly thankful! Let me know what you need for it I hope we could work something out! Thank u again
SOLD- 125K on the clock, 5 speed, Sport Package, Fan Delete Mod, 4-spoke M3 steering wheel, Clear lenses all around her, ZHP Shiftknob, Trunk Debadge, Sharked, Stromung Catback, H&R Sport Cup Kit and Staggered Ds2's!
New Ride - 2003 Steel Grey Metallic M3 Coupe
Jump to top jdamore44 is offline   Reply With Quote
Old Mon, Jul-21-2014, 04:10:55 PM   #139
SouthTexasE46
Reputation: 0 SouthTexasE46 is on a distinguished road
Which snap ring are you talking about? Send me a picture. I have a bunch of spare stuff at home but not sure if I have one of those. I'll be home later today to look.
Jump to top SouthTexasE46 is offline   Reply With Quote
Old Mon, Jul-21-2014, 04:37:36 PM   #140
jdamore44
Here is a link and a picture. Its a sensitive lil guy.. most people break them because you have to push the red rim down and pull up on tube. I would be forever grateful if I could find a good one
http://www.m3forum.net/m3forum/showthread.php?t=250333
Discussing M3 SMG pump reconditioning in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
