Old Fri, Jun-11-2010, 12:45:04 PM   #1
oskee64
oskee64's Avatar
Reputation: 0 oskee64 is on a distinguished road
Default Cold startup issue noticed
Lately, Cold starts noticed RPM rev goes drastic ups and downs. Not a smooth high note. But once it reaches normal operating temp, seems to be fine. Anyone experience this issues?
2006 Jet Black ///M3 Nappa Black Interior / ZCP / SMG II / Premium / NAV / CWP / HK Sound / Zenons/AE/ V1 Hardwired w/ Concealed unit/OEM Alarm/
2001 INFINITI QX4: DD
2014 BMW X5 M SPORT: Wifey's DD
Jump to top oskee64 is offline   Reply With Quote
Old Fri, Jun-11-2010, 02:17:46 PM   #2
BHenderson
Reputation: 0 BHenderson is on a distinguished road
Yeah, I have the same issue. I even stalled out this morning. I think it's just the fuel mixture.
Jump to top BHenderson is offline   Reply With Quote
Old Fri, Jun-11-2010, 05:01:56 PM   #3
oskee64
oskee64's Avatar
Hope it's not fuel starvation or bad Fuel. Normally i fill up my tank when it reach 1/4. Do anyone wait for their low fuel light indicator before filling up?
Old Fri, Jun-11-2010, 05:05:45 PM   #4
PSLC
PSLC's Avatar
Reputation: 0 PSLC is on a distinguished road
I usually gas up when the light comes on...no problems here
Jump to top PSLC is offline   Reply With Quote
Old Fri, Jun-11-2010, 05:06:38 PM   #5
Waitwhat
Reputation: 0 Waitwhat is on a distinguished road
South Africa
I have a 2002 model and pretty much always wait for the low fuel light to come on unless I know I need a full tank to get somewhere. Few ups and downs at idle but nothing that's made me worried.
Jump to top Waitwhat is offline   Reply With Quote
Old Fri, Jun-11-2010, 05:09:57 PM   #6
BHenderson
Yeah, it kind of fluctuates at idle when I first start it up, but I always figured that was normal. If I let it idle for like 10 seconds like that, it will gradually even out.
Old Fri, Jun-11-2010, 06:50:59 PM   #7
cducati
cducati's Avatar
Reputation: 0 cducati is on a distinguished road
Just peg the throttle for about 60 seconds when it does that.
It won't do it for much longer.
Mine does it was well.... I kinda like it.
Jump to top cducati is offline   Reply With Quote
Old Fri, Jun-11-2010, 09:41:55 PM   #8
CLOUD_STR1FE
Reputation: 0 CLOUD_STR1FE is on a distinguished road
I have the same issue with mine. It idles at 1 and revs to about 1 1/2 then bad down agin etc. I just bump the gas pedal a couple times and let it warm up and i'm straight.
Jump to top CLOUD_STR1FE is offline   Reply With Quote
Old Sat, Jun-12-2010, 01:24:16 AM   #9
djpfine
Reputation: 0 djpfine is on a distinguished road
I have the same thing. I think it's a common problem for M3's, as I also had similar issues develop with my E36. Not sure of a fix.
Jump to top djpfine is offline   Reply With Quote
Old Sat, Jun-12-2010, 03:10:43 AM   #10
There are a number of things that regulate the idle on these cars. You can try replacing the air filter, clean the MAF, replace the Trottle Position Sensor. I think these cars may also have, like the E36, an idle control valve. On the E36 you can clean it with some mineral spirits, I don't know about the E46 though.
I doubt its a bad fuel mixture, a lower octane would only cause knocking, and I wouldn't expect that to happen on cold start up.
I'm not sure about this, but the emission regulation system on these cars may cause some funny running on start up from what I've heard from some, but I don't anything about that.
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav no xenon no anything JOURNAL
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped SS V1 S pipe + 200 cell HFC OE sect 2 SS Sport BMW Motorsport 4.10 Besian RE pullies/fan delete WPC rod bearings TMS Camber & Subf plates RE Trans Mounts AKG poly SUB/DIFF SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 440/550) + tall RSMs OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 ss brake/clutch lines Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
cold, issue, noticed, startup
Discussing Cold startup issue noticed in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
