Old Mon, Nov-05-2012, 02:17:03 PM   #11
bmwm3smg2
forever stock...
bmwm3smg2's Avatar
Reputation: 0 bmwm3smg2 is on a distinguished road
Default Re: Intermittent “car would not crank” issues
Definitely check the starter. My friend took his ex M3 to the dealer and they replaced his keys and the module that reads the keys. Spent a LOT of money and the problem persisted. Same exact symptoms as what you described. Turned out to be the starter. Dealer ruled it out because the car eventually starts. But because of M3Froum, we found others who had the same exact problem caused by the starter. He took the car back to the dealer with this knowledge and told them to change the starter. Problem solved and got some money back from the keys and reader they replaced. Starter can be DIY and is cheaper than replacing keys and the reader, sorry forgot what you call that module. :LOL
Erwin
Jump to top bmwm3smg2 is offline   Reply With Quote
key, smg, smg sensor, start, start engine
Discussing Intermittent “car would not crank” issues in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
