Old Sat, Jun-28-2008, 02:47:03 AM   #1
gixxer
gixxer's Avatar
Reputation: 0 gixxer is on a distinguished road
Default Is this crazy and even doable? Have two DME's, one with pump map, and other race map
Is this crazy?
If not that crazy, is this even doable?
That is, have two DME's,
* one with pump map from AA, and
* one for race(+meth+nitrous) map (more/aggressive timing) from AA?
So while i'm on 93 pump gas, use the DME with pump map.
When when i'm on VP MS109/110 unleaded, use the other DME with with more aggressive timing map.
I understand that DME do adapt to the environment, and add timing when race gas (and meth) is used.
I'm not even sure if you can use one DME for one week, and use a different DME next week.
That is, whether the new DME can be made to work in the car, and then have AA program it with race map, and have it used in the car, interchangeably with the original DME.
This is pretty stupid idea? Yes? No?
(not to mention new DME probably would cost an arm and a leg, and not to mention, cost to get it programmed to even have it work in the car by the dealer)
need2buy: LTW flywheel + clutch ;
wish: HPF ;
Mod Journal
Jump to top gixxer is offline   Reply With Quote
Old Sat, Jun-28-2008, 03:51:08 AM   #2
WizeGi///M3
Reputation: 11 WizeGi///M3 is on a distinguished road
For that type of effort may as well just go with a Motec - also having 2 DMEs isn't possible.
Carmen™
e92 M3 Competition Edition
Jump to top WizeGi///M3 is offline   Reply With Quote
Old Sat, Jun-28-2008, 07:04:23 AM   #3
Sertan
Reputation: 0 Sertan is on a distinguished road
yes with a motex you will have 4 different maps, can go from one to the other map with the touch of a botton. i am working on a motec for my E46 M3 these days.
Jump to top Sertan is offline   Reply With Quote
Old Sat, Jun-28-2008, 10:38:28 AM   #4
Saintly
Reputation: 0 Saintly is on a distinguished road
If they both have the same software version then you can interchange but then you would need the software to align the EWS. I have two ECU's as I flashed one too many times whilst testing its locked with pump/track map
The next thing is you will be surprised how much hp you will pick up by adding race gas mix the Ecu will adapt.
I did this just last week with a customers AA charged car made 360rwhp I put 20l c16 in he had just over 1/4 of a tank of pump (50/50) and he made 403rwhp after 2nd run, I changed nothing else! I see this result often.
Just my
508rwhp Dynodynamics AA charged 9psi race gas(no nos) 11.618@122.65mph
521rwhp Dynodynamics AA charged 9psi race gas(125shot) 11.412@126.09mph(Best trap 129.72mph)
611rwhp Dynodynamics AA charged 9psi race gas(150shot) 11.7@129.49mph
631Rwhp highest HP to date.
Now: 528rwhp Dynodynamics 13psi Pump Fuel AA Charged
552rwhp Dynodynamics 13psi Race Fuel AA Charged
Jump to top Saintly is offline   Reply With Quote
Old Sat, Jun-28-2008, 02:07:07 PM   #5
zracer196
Reputation: 0 zracer196 is on a distinguished road
Gixxer,
How is your car? Enjoying it? I think you had the kit finally installed a month ago...Correct?
Have fun!
1999 Viper GTS - Silver with Blue Stripes / 1 of 22 / Borla Cat Back
2006 Yamaha R6 - Bone Stock - FOR SALE
2007 KTM XCF 250 - R2 Suspension / Fasst Bars / FMF Ti Pipe / Ohlins Damper
Jump to top zracer196 is offline   Reply With Quote
Old Sat, Jun-28-2008, 02:43:23 PM   #6
ActiveAutowerke
Simply Genius
ActiveAutowerke's Avatar
Reputation: 0 ActiveAutowerke is on a distinguished road
Two dme's is not possible.
The E46 M3's DME has a rolling EWS code. So if you remove the EWS and attempt to crank the car you will have to get it realigned. This would be more of a headache to keep realigning your DME's.
Turning off EWS is not possible on the S54's DME.
As saintly mentioned just adding better octane is fine since the DME will adapt.
Jump to top ActiveAutowerke is offline   Reply With Quote
Old Sat, Jun-28-2008, 04:02:05 PM   #7
///JTM3
Reputation: 0 ///JTM3 is on a distinguished road
What about if you had your own Auto Logic tool, and you can realigne the EWS when ever you want..
Jump to top ///JTM3 is offline   Reply With Quote
Old Sat, Jun-28-2008, 05:28:26 PM   #8
JTrejo
Reputation: 0 JTrejo is on a distinguished road
Guatemala
how much is a motec?
Jump to top JTrejo is offline   Reply With Quote
Old Sat, Jun-28-2008, 06:16:32 PM   #9
white333
function over form
white333's Avatar
Reputation: 0 white333 is on a distinguished road
Here is one for you; why not make it so that on the dme you could switch between two maps via a switch? Think of it like this. When your car goes into limp mode have that mode be your race setting! If the audi guys could do this than why not us?
"No passion so effectually robs the mind of all its powers of acting & reasoning as fear" Edmund Burke
Jump to top white333 is offline   Reply With Quote
Old Sat, Jun-28-2008, 06:23:22 PM   #10
AMG ETR
Reputation: 0 AMG ETR is on a distinguished road
Why wouldn't you just have 2 maps on the 1 ECU? I know of a tuner near me that can tune your car on pump and race and make the race gas file turn on when you press the sport button (or any other button for that matter)!! Very cool
Evan
Jump to top AMG ETR is offline   Reply With Quote
Member Map Hyolee E36 M3 (1992-1999) 104 Fri, Feb-22-2019 01:21:30 PM
re-map kings E36 M3 (1992-1999) 15 Thu, Apr-03-2008 05:04:34 PM
Active Autowerke Completes Level 1 SC kit & Customer Dyno's Custom Race Gas Map*VIDS* ActiveAutowerke Forced Induction (F/I) 2 Thu, Oct-11-2007 05:43:59 AM
Re-Map Dommo80 E36 M3 (1992-1999) 0 Sun, May-14-2006 06:55:53 PM
Add yourself to the map Ketsugo E46 M3 (2001-2006) 30 Sun, Oct-16-2005 03:09:03 PM
Discussing Is this crazy and even doable? Have two DME's, one with pump map, and other race map in the Forced Induction (F/I) Forum - Discuss the ever growing F/I options here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
