Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > Parts for Sale/Wanted
Parts for Sale/Wanted Post your Parts Wanted, and non commercial bmw related items for sale. We ask that companies selling goods become a Sponsor to advertise your goods.
Old Tue, Mar-26-2019, 11:27:14 PM   #1
Hender107
Reputation: 0 Hender107 is on a distinguished road
Default ZCP Steering wheel trim
Refinished trim set with the following process:
1. Simple green scotch bright pad along with 600 & 800 sandpaper to strip original finish completely
2. 2 Coats of primer with wet sanding in between coats
3. 3 coats of a metallic grey which is a near identical match, the best I've found thus far, can’t tell a difference unless you hold them right next to each other. All coats had wet sanding in between
4. 3 coats of matte clear coat with wet sanding and one final coat that gives it the factory finish
I spend about a week doing this process, it allows the paint to properly cure between each step and sanding, I've found this process gives the best results that beats buying the pieces new for over $400 from ecs or elsewhere, asking $200 shipped.
Jump to top Hender107 is offline
Rate Seller View Rating
Old Tue, Mar-26-2019, 11:28:24 PM   #2
Hender107
Jump to top Hender107 is offline   Reply With Quote
Old Wed, Mar-27-2019, 12:20:05 AM   #3
///M Dream
Real Madrid C.F.
///M Dream's Avatar
Reputation: 0 ///M Dream is on a distinguished road
Default Re: ZCP Steering wheel trim
Willing to take a worn out ZCP steering wheel trim + 125?
Current: 2006 Interlagos Blue ZCP ///M3
Past: F80 M3. E46 330i ZHP. B8 S4. E92 M3. E46 M3.
Jump to top ///M Dream is online now   Reply With Quote
Old Wed, Mar-27-2019, 01:19:30 PM   #4
Hender107
I can probably do something like that for a fellow IB zcp owner. PM sent
Old Wed, Mar-27-2019, 03:09:19 PM   #5
mcfreid
Reputation: 0 mcfreid is on a distinguished road
If that trade falls through, I'm interested. Will also consider taking the refinished trim of M Dream's set after you complete your magic.
Jump to top mcfreid is offline   Reply With Quote
Old Wed, Mar-27-2019, 03:42:45 PM   #6
Hender107
Sounds good, this thread will serve as a running list unless the demand becomes more than expected, which I doubt.
Old Wed, Mar-27-2019, 04:22:06 PM   #7
SQ13
If I send you my worn trim, would you be willing to refinish it and send it back? If so, curious how much you’d charge.
Old Wed, Mar-27-2019, 04:53:51 PM   #8
Hender107
Originally Posted by SQ13 View Post
If I send you my worn trim, would you be willing to refinish it and send it back? If so, curious how much youd charge.
At some point, Id be willing to do that. Id like to have one done that I can post pics of and you can see before you buy it, so you know what your getting. Mainly to avoid unhappy customers, bc Ill be honest, its more of an art than a science at this point especially with the metallic paint on a curved surface.
But if mcfried has a worn set hes gunna swap me youll have first dibs on that once pics go up.
Old Wed, Mar-27-2019, 05:25:27 PM   #9
sapote
This is a great service to the members with scratched wheel trims. Factory did a lousy job on the ZCP steering wheel in my opinion. I like the rubbery texture of the cheaper e46 normal steering wheel which have not scratched off after 18 yrs.
Old Fri, May-10-2019, 03:06:59 PM   #10
Hender107
New trim available..
Discussing ZCP Steering wheel trim in the Parts for Sale/Wanted Forum - Post your Parts Wanted, and non commercial bmw related items for sale. We ask that companies selling goods become a Sponsor to advertise your goods. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
