Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > Parts for Sale/Wanted
Parts for Sale/Wanted Post your Parts Wanted, and non commercial bmw related items for sale. We ask that companies selling goods become a Sponsor to advertise your goods.
Old Tue, Sep-25-2018, 09:36:40 PM   #41
Default Re: Feeler: Group Buy Gosling Racing & Independent Designs Front and Rear Brace
If you've got the Vemo or Vemo+, throw it in the trash.
If you've got the very reputable OEM AB Elek, you've got the same part as the BMW one.
I'm not aware of any other TPSs.
_
Old Tue, Sep-25-2018, 09:43:42 PM   #42
Turb02
Turb02's Avatar
DERP...I had too many windows open and responded to the wrong thread... my bad. Deleting my other post.
NOT NARDO
Active Autowerke Stage 2.5-AA Headers-Supersprint-Meisterschaft-Vorsteiner-Brembo-AC Schnitzer-BBS-CSL
6MT swapped-RTD shifter-Amber Gang
Jump to top Turb02 is offline   Reply With Quote
Old Tue, Sep-25-2018, 10:29:43 PM   #43
OldFanatic
19 yr BMWCCA Member
OldFanatic's Avatar
Reputation: 0 OldFanatic is on a distinguished road
a lot of talk about the elongated mounting spots in the rear brace bracket. sure it's not a one piece bolt-in racing brace. and yes that would be best. if anyone felt need to, they could spot weld it in.
but lets not forget the BMW brace too has elongated slots..
2003 TiAg - OE CSL WHEELS - OE CSL BRAKES - AA SPORT TUNE - AA PULLEYS - AS 40% SSK- VCSL TRUNK - VCSL DIFFUSER
SUPERSPRINT EXHAUST
- BMW PERFORMANCE CF STRUT BRACE - BILSTEIN PSS9s - GRUPPE M CF INTAKE - CF RACE LIP - 4.10 M DIFF - CSL RACK - GROUP N MOTORMOUNTS
-SANS SUNROOF-
Jump to top OldFanatic is offline   Reply With Quote
Old Wed, Sep-26-2018, 08:27:08 PM   #44
WALKD_U
WALKD_U's Avatar
Responds from Gosling himself...
With regards to additional information requested please find the pdf attached
As to a few of the questions highlighted on the group buy.
The rear brace is designed and proven to support the axle carrier panel from vertical loads.
In doing so the torsional loads the axle is exerted to during spirited driving is greatly reduced due to the reduced twist customers can expect a better drive due to the stiffer rear chassis giving a positive affect on handling, in turn giving the driver more confidence.
We have taken on board with regards to the slot sizes in turret mounts and reduced them despite not having affect on the performance of the brace kit. The slots were designed specifically to aid installation as a result all of our customers have reported fitment was easy.
The kit has been design overall to provide effective results in prolonging and strengthening the chassis, without the need for welding and be as easy to install as possible.
Please remember this kit was designed by engineers with long term experience with the e46 chassis along side an aerospace engineer.
We are currently working on putting together a few vids to show visual proof of brace effectiveness.
We hope this is enough to inform potential buys
Attached PDF Content
SPECIFICATIONS
E46 AXEL PANNEL BRACE KIT
1
SPECIFICATIONS
General information
• Full tig welded design using stainless steel fasteners
• Made in Cds tube for durable strong product
• Full bolt in kit with no welding required
• All fixtures and fittings included in this kit
• Standard colour supplied in gloss black
• Ideal for full coil over conversions
• Suited to road and circuit cars alike
• This kit can be combined with the generation 3 gts cage, to make the ultimate track day
set up (see A2)
Kit contents (see A1)
1x brace
2x turret mounts
1x top bar
2x tension rods
2x high tensile cnc machined axel bolts
1x m12x1.5 tap
1x extra-long pilot drill bit
1x bolt pack containing all nuts bolts and washers
Why buy a Gosling Racing brace kit?
Using our extensive knowledge on the e46 chassis, we have proven this kit to work well in the
most demanding environments, this kit will prolong/prevent axel carrier panel damage and
compliment the look of your boot space.
Our kits significantly increase rigidity to both the axel carrier panel and shock absorber
mounts, dissipating shock and stress throughout the brace. With the addition of adjustable
tension rods you are able to ensure the best possible fitment.
2
FAQ
Q, will this kit work with subframe plates ?
A, yes
Q, can I use this kit to prevent carrier panel damage?
A, yes this kit is ideal to prevent damage occurring
Q, will this kit affect my seats ?
A, no this kit will not affect any of the seating
Q, is this kit hard to install ?
A, although the up most effort has been made to make this kit easy and simple to
install, we still recommend professional fitting
Q, I live outside of the uk, can I still buy a brace kit ?
A, yes, shipping is available all over the world
Q, I own a convertible, will this kit fit ?
A, unfortunately not, however convertibles have stronger chassis and have less need
for our brace kit
Shipping Information
Dimensions for shipping (mm) 950x320x140 product weight(kg) 4.6
2005 AW/IR M3
BMB Stage 4
940whp/765wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Instagram
M3HNGRY
Old Thu, Sep-27-2018, 07:45:58 AM   #45
ksa74f
ksa74f's Avatar
Reputation: 0 ksa74f is on a distinguished road
Scotland
1. WALKD_U - 1 Front and Rear Brace
2. lore2486 - 1 Rear Brace
3. FANTASTICVOYAGE - 1 Rear Brace
4. tr4ck_m3 - 1 Rear Brace
5. MP (Facebook) - 1 Rear Brace
6. m3_pilot - Rear Brace
7. DJ Syxx - Front Brace
8. ksa74f - Rear brace
9.
10.
Cheers Kev
Jump to top ksa74f is online now   Reply With Quote
Old Thu, Sep-27-2018, 03:53:33 PM   #46
WALKD_U
WALKD_U's Avatar
And for those who are tripping about the slots. Mason Engineering Brace has slots built into their bars for awhile now...
For attended purpose, they work just fine. Not sure what the grip is all about. I'm about to put this on my 1000hp/800tq M3...
2005 AW/IR M3
BMB Stage 4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Instagram
M3HNGRY
Old Sat, Sep-29-2018, 12:07:26 AM   #47
tr4ck_m3
Buildjournal
tr4ck_m3's Avatar
Reputation: 0 tr4ck_m3 is on a distinguished road
almost there!
IG: @tr4ckM3
B-Spec Tune
2002 BMW E46 M3 6MT | B-Spec Tune + ProFlex Commander E70 315whp/242wtq
2013 BMW F30 335i 8AT | BM3 E30 Stg 2 Tune 367whp/457wtq
Jump to top tr4ck_m3 is offline   Reply With Quote
Old Sat, Sep-29-2018, 02:28:53 AM   #48
bimmerrodg
bimmerrodg's Avatar
Reputation: 0 bimmerrodg is on a distinguished road
9.bimmerrodg - 1 Rear brace
10.
Jump to top bimmerrodg is offline   Reply With Quote
Old Mon, Oct-01-2018, 01:38:54 AM   #49
Nicholas1996
Reputation: 0 Nicholas1996 is on a distinguished road
Greece
10.Nicholas1996-1 Rear Brace
Thats 10!
Topaz Blau
PTE 6266 on E85
AEM Infinity
Tuned by Ian @Bend Calibration
Jump to top Nicholas1996 is offline   Reply With Quote
Old Mon, Oct-01-2018, 01:40:08 AM   #50
WALKD_U
WALKD_U's Avatar
It's a party!!! I will pm everyone after diner!
2005 AW/IR M3
BMB Stage 4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Instagram
M3HNGRY
Discussing Feeler: Group Buy Gosling Racing & Independent Designs Front and Rear Brace in the Parts for Sale/Wanted Forum - Post your Parts Wanted, and non commercial bmw related items for sale. We ask that companies selling goods become a Sponsor to advertise your goods. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
