Old Sun, Dec-29-2013, 05:53:03 PM   #11
ZCPIBM3
Reputation: 0 ZCPIBM3 is on a distinguished road
Default Re: DIY: E46 M3 detailed subframe reinforcement, gear fluid changes, and bushing refr
Love this.
Keep up the good work!
2006 M3 ZCP Interlagos Blue
Jump to top ZCPIBM3 is offline   Reply With Quote
Old Sun, Dec-29-2013, 07:32:20 PM   #12
TimAstro
Reputation: 0 TimAstro is on a distinguished road
Default Re: DIY: E46 M3 detailed subframe reinforcement, gear fluid changes, & bushing refres
Incredibly detailed! Very fine DIY sir.
2006 M3 Tiag/Black 6MT - Euro Header/US Section w/ AR25ís - Agency Power sec 3 - TTFS Tune - Morimoto H1 BiXenon Retrofit - Renn Motorsports RS51's on Conti DW - OE Bushing Refresh - Fortune Auto 500 Coilovers 10k/12k Swift Springs - 320hp/250tq - (currently parked awaiting a vf570 kit and massive overhaul)
Jump to top TimAstro is offline   Reply With Quote
Old Sun, Dec-29-2013, 09:43:45 PM   #13
mystick
mystick's Avatar
Reputation: 0 mystick is on a distinguished road
Netherlands
Great diy, thnx for sharing and all the hard work.
Only once , you live
M3 ESS VT2 500
Jump to top mystick is offline   Reply With Quote
Old Sun, Dec-29-2013, 09:48:03 PM   #14
bimmerfan08
bimmerfan08's Avatar
No problem guys. Thanks for the comments. Please feel free to share any comments/offer advice if I have missed anything or have misleading information so I can correct the DIY. You guys are my proofreaders.
Old Sun, Dec-29-2013, 10:48:28 PM   #15
ThunderMoose
Am I the only one that reads bimmerfan's DIY's for enjoyment?
I am in the middle of his valve adjustment DIY while I wait for my shim removal tool to arrive.
#67 2017 NASA TX TT3 Champion
Old Sun, Dec-29-2013, 10:56:39 PM   #16
bimmerfan08
I always end up knowing a ton of more info about the car on the other end of completing a DIY. So much information gets lost or mixed up on this forum. I just try to sort through and find the good bits to make DIY processes simple and straightforward for readers and future DIYers.
Old Sun, Dec-29-2013, 11:15:43 PM   #17
LSBE46M3
Reputation: 0 LSBE46M3 is on a distinguished road
Bookmarked for future use. Thanks!
Jump to top LSBE46M3 is offline   Reply With Quote
Old Sun, Dec-29-2013, 11:30:47 PM   #18
Dal
Dal's Avatar
Reputation: 0 Dal is on a distinguished road
bookmarked!! thank you!
Jump to top Dal is offline   Reply With Quote
Old Sun, Dec-29-2013, 11:37:38 PM   #19
m3 hal
Very nice and thorough DIY!
For the trans fluid draining part I would add that one should always remove the fill plug first and then the drain plug.
Old Sun, Dec-29-2013, 11:51:04 PM   #20
bimmerfan08
Noted and changed. Thanks
Discussing DIY: E46 M3 detailed subframe reinforcement, gear fluid changes, and bushing refresh in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
