Old Tue, Jul-17-2018, 05:46:23 PM   #1
Apps
Reputation: 0 Apps is on a distinguished road
Default DataLogged VANOS low pressure
I have an s54 swapped e39 that I daily. Since the swap I have been experiencing rough/irregular running below ~2500rpm and at idle. I have not had a VANOS check procedure run because I use Renovelo ByteLogger to datalog the major VANOS parameters from the DME.
Using datalogging I see that the exhaust and intake struggle to follow the target vanos positions below 3000rpm. Especially in a circumstance where I was crusing and then put the clutch in and coasted to a stop - i.e. rpm dropped to idle suddenly.
Intake is harder to say because it moves so little at low engine speeds that it's not clear. Additionally I get intake and exhaust position control DTC's...many for exhaust over a given time and few for intake - again related to the amount of movement on intake side at low rpm.
I should mention in the past 1500 miles I replaced all VANOS seals with Beisan parts, replaced oil pump disk with Beisan unit, replaced solenoid pack with Beisan unit, cleaned valve body per Beisan instruction, installed Beisan rattle kit, and of course timed the VANOS. The VANOS max and min angles confirm that the timing range is correct/adequate.
My theory is that the accumulator has begun to fail and thus the extra volume/pressure needed at low rpm is not available to make VANOS adjustments. Based on the position of the accumulator it makes sense that the VANOS oil pump is low output and only passed a certain rpm (~3000rpm) does it have the capacity to provide nominal pressure at needed flow rate for the VANOS actuation to function.
I'm writing this thread to see if anyone agrees with this concept before I go ahead and buy a new accumulator based on this hypothesis.
Thoughts?
edit: Fixed pictures to attachments
Jump to top Apps is offline   Reply With Quote
Old Tue, Jul-17-2018, 06:42:01 PM   #2
Default Re: DataLogged VANOS low pressure
I don't have any useful thoughts on the question at hand, but how is the s54 e39? Been thinking that might be the fate of my 530i......
Old Tue, Jul-17-2018, 07:28:32 PM   #3
Drewster
Drewster's Avatar
I'd be curious to see the improvement/ lack thereof after you change the accumulator... but I'd imagine VANOS under 3000 RPM falls into the "does it make that much of a difference"
Old Wed, Jul-18-2018, 02:14:19 AM   #4
Apps
Obiodan - I'm enjoying it though there have been some CAN communication gremlins and mechanical obstacles to overcome (biggest is major machining of the oil pan...most frustrating the spacial constraints for the fuel regulator and filter without changing all of the fuel tank feed and return lines to m5 versions...)
Drewster - believe it or not the effect is substantial...at a minimum it makes you feel like a fool with low rpm gear changes because the motor stumbles as soon as the VANOS stops following the target - i.e. vanos control pressure has dropped
Old Wed, Jul-18-2018, 02:34:12 AM   #5
Apps
Thinking out loud:
My feeling is this is pump/flow related based on the ability of the VANOS to precisely follow the target at higher RPM. If this was a piston or valve body leak I would have expected the lack of precision to remain even at higher rpm.
From that perspective it seems the only components are the regulating valve, accumulator and the pump itself. The pump is fairly simple and as long as the 4 rotary pistons are installed it "should" be hard to screw up.
If the regulating valve was set too low then again we would never build enough pressure to adjust...hence not affected greatly by rpm other than the point where the vent orifice is overwhelmed by supply flow.
Final the accumulator should be supplying flow for vanos movements when the pump cannot output the required flow...as is likely at low rpm.
Old Wed, Jul-18-2018, 04:58:46 AM   #6
mrgizmo04
mrgizmo04's Avatar
Originally Posted by Apps View Post
Thinking out loud:
Possibly the pressure is not keeping up. I have a used working accumulator if you want to try it, I know new they are like 3-400.
PM me.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Tue, Jul-31-2018, 07:58:11 PM   #7
Apps
Pictures Fixed...since that was the critical info to look at it maybe this will elicit additional feedback
Old Tue, Jul-31-2018, 11:06:19 PM   #8
kokgo20
kokgo20's Avatar
Sounds like you are in a need of a new accumulator.
My engine needed one around 20K miles ago
Build thread
Old Wed, Aug-01-2018, 12:33:27 AM   #9
Apps
Thanks for the confirmation, I actually ordered one a week or so ago, installed tonight and datalogging tomorrow. I'll report back with findings to prove if this is truly the reason for my low rpm vanos position control issues.
Curiously how many miles did your motor have at the time?
Old Thu, Aug-02-2018, 10:15:59 PM   #10
ZiMMie
Reputation: 0 ZiMMie is on a distinguished road
Germany
Updates?
Sent from my Redmi Note 5 using Tapatalk
#E36S54 #CSLWannabe #TTFS @Mykesf
Jump to top ZiMMie is online now   Reply With Quote
Discussing DataLogged VANOS low pressure in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
