Old Sun, Jul-15-2018, 04:55:18 PM   #1
Boz123
Reputation: 0 Boz123 is on a distinguished road
Default Rattling at 2500 rpm upwards
Hi guys Iíve currently got a 2004 m3 over the last few months itís got a rattle happening from 2500rpm to about 3200rpm on light throttle . I originally thought it was the head gasket so did a compression test to find itís only down on compression in 1 cylinder the very back one . Down about 20 psi from the rest.. I recently checked my valve clearances as well and had 1 valve out which was also for that cylinder on the intake side so got new shim an corrected the gap . Has any one got any ideas where I need to be looking for this rattle as itís really annoying and Iím wanting to sell the car soon. Cheers
Jump to top Boz123 is offline   Reply With Quote
Old Sun, Jul-15-2018, 05:04:45 PM   #2
///M3 MD
Reputation: 0 ///M3 MD is on a distinguished road
Default Re: Rattling at 2500 rpm upwards
Can you describe the rattle? If itís a random irregular cadence it could be ďpingingĒ or detonation in the cylinder with low compression. I had the noise under light throttle b/t 2500-3500rpm. Turned out I was down on compression on all cylinders.
How do your plugs look?
2002 Carbon Black/Black 6MT ///M3
Mods: (Mike Miller Maintenance schedule) - Euro Headers - Resonated Section 1 - Dinan Section 3
TTFS Custom Tune
Autosolutions 30% SSK - RE Poly Trans mounts - AKG Poly diff bushings, RTABs and FCABs
Dinan 'Stage 1' Suspension
Jump to top ///M3 MD is offline   Reply With Quote
Old Sun, Jul-15-2018, 05:14:22 PM   #3
Boz123
It sounds like a marble in a jar sort of,or a metallic rattle if that makes sense , if I put my foot down it doesn’t do it at all only on gentle throttle. Plugs all look good no irregular colours or oil etc
Old Sun, Jul-15-2018, 05:18:57 PM   #4
mrgizmo04
mrgizmo04's Avatar
Was the shim you adjusted too thick and you went to a thinner one? Just trying to see if your compression would increase from the valve adjustment itself if the valve was staying open. Did you redo the compression test after the adjustment? And 20psi is a BIG diff.
+1 on recording of the noise.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sun, Jul-15-2018, 05:24:33 PM   #5
Boz123
Yes I put a thinner shim in the feeler gauge 0.007 wouldnít fit in it originally and yes I no thatís a big difference it was down 40 psi before I did the shim but obviously something somewhere isnít right . Iím no mechanic either btw lol
Old Mon, Jul-16-2018, 07:04:56 AM   #6
mrgizmo04
mrgizmo04's Avatar
Originally Posted by Boz123 View Post
Yes I put a thinner shim in the feeler gauge 0.007 wouldnít fit in it originally and yes I no thatís a big difference it was down 40 psi before I did the shim but obviously something somewhere isnít right . Iím no mechanic either btw lol hit:
Could you record the noise? Does it happen when car is cold or after it warms up?
Could be several things - vanos, water pump, or rod knock (as Eric found out after bullet proofing his vanos and checking the water pump).
'05 M3 6MT coupe
Old Mon, Jul-16-2018, 09:15:01 AM   #7
Boz123
I will try pal it happens all the time tbh although I would say defo more noticeable once warmed up. Thank you for all your help so far btw
Old Mon, Jul-16-2018, 09:39:35 AM   #8
Boz123
Donít no how to upload a video from my phone lol
Old Mon, Jul-16-2018, 02:14:29 PM   #9
mrgizmo04
mrgizmo04's Avatar
Youtube
'05 M3 6MT coupe
Old Mon, Jul-16-2018, 04:39:16 PM   #10
HassanEido
HassanEido's Avatar
Lebanon
Three things rattle on this car. A spun bearing, vanos, and a rattle snake. That's pretty much it.
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Discussing Rattling at 2500 rpm upwards in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
