Old Sat, Feb-17-2018, 08:59:05 PM   #1
wildpig
wildpig
Reputation: 0 wildpig is on a distinguished road
Default need brake pad change shop recommendation tampa new port richey area..
So my m3 now finally need a brake pad change. this is the first brake change I am getting after driving it since 2012. lol... I really baby it so that's why the brake lasted that long.... so it finally making some screeching noise once a while braking.
Is there anything special about the brake change that needs to be done at some special places or could i just bring it to any decent place or cheap place ie just4brake? any recommendation? don't really want to go to stealers...
Also does anyone has an indy shop recommendation in the palm harbor, new port richey tampa area?
Jump to top wildpig is offline   Reply With Quote
Old Sat, Feb-17-2018, 09:10:22 PM   #2
lmtfi
lmtfi's Avatar
Default Re: need brake pad change shop recommendation tampa new port richey area..
You "baby" the car so you don't have to change brake pads?
You wait for a screeching sound to tell you when to change pads?
You might try actually looking at your pads...you know....once every few years.
Old Sat, Feb-17-2018, 09:30:13 PM   #3
wildpig
wildpig
well, I do have my oil change regularly every year at least once....
didn't baby it to not have to change brake that long but just because I don't drive things rough in general....lol....
so still back to the original question.... any special things to watch for or just bring it to any decent brake place? recommendation?
also any good indy in the tampa, palm harbor, new port richey area?
Old Sat, Feb-17-2018, 09:37:28 PM   #4
Mantii
Reputation: 0 Mantii is on a distinguished road
Why not diy? Super easy and you’ll probably save $400 or more. I don’t do everything myself either, but some things are easier than others, brakes are one of them.
Jump to top Mantii is offline   Reply With Quote
Old Sat, Feb-17-2018, 10:02:37 PM   #5
wildpig
wildpig
$400 for brake pad change? where is this?
would this be good enough?
front: https://www.autozone.com/brakes-and-...11_421240_1610
rear: https://www.autozone.com/brakes-and-...71_421240_1610
i guess i should change all 4 and not just the one that squeaking? it's been about 30k miles since i got the car.....
Old Sat, Feb-17-2018, 11:22:26 PM   #6
Danwilz
Reputation: 0 Danwilz is on a distinguished road
This guys Trolling right?
Jump to top Danwilz is offline   Reply With Quote
Old Sat, Feb-17-2018, 11:23:09 PM   #7
SG/IRM3
Flyguy
SG/IRM3's Avatar
Reputation: 0 SG/IRM3 is on a distinguished road
You probably need rotors as well.
Mike K.
2005 M3
Jump to top SG/IRM3 is offline   Reply With Quote
Old Sun, Feb-18-2018, 12:48:58 AM   #8
SQ13
No
https://www.ecstuning.com/b-genuine-...34112282416kt/
Old Sun, Feb-18-2018, 12:52:47 AM   #9
ThunderMoose
diy - very simple job.
#67 2017 NASA TX TT3 Champion
Old Sun, Feb-18-2018, 04:18:51 AM   #10
wildpig
wildpig
hmm I will youtube up a video and see... I guess it will take a half afternoon?
Discussing need brake pad change shop recommendation tampa new port richey area.. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
