Old Sun, Sep-07-2014, 01:37:19 PM   #31
CharlaybitM3
I dont like DSC
CharlaybitM3's Avatar
Reputation: 0 CharlaybitM3 is on a distinguished road
Default Re: Ultimate Alignment Specs?
Originally Posted by Mr. Wolfe View Post
So slight toe in will track better and be more suitable for the highway and toe out will make the car more lively, but more of a handful, correct?
Mr. Wolfe
Correct. Toe out is preferable for the track as it quickens/sharpens turn in to corners. On the road it'll make the car twitchy though. It will also increase your tire wear.
"Not putting miles on your M3 is like not having sex with your girlfriend so she'll be more desirable to her next boyfriend..." -Someone Awesome
Originally Posted by TMS951 View Post
I like it on mine, tips didn't line up perfect, but good enough. Its off a newer car that makes more power so I know it makes more power on my car.
You can make a custom flange to connect it to your stock header with JB weld.
Sound is an 8/10, I was expecting it to sound like a V8 since its a V8 exhaust. It doesn't, anybody know why this is? Does it have to do with how I installed it?
Jump to top CharlaybitM3 is offline   Reply With Quote
Old Sun, Sep-07-2014, 01:43:37 PM   #32
CharlaybitM3
I dont like DSC
I should add that is for front axle. Toe in is preferable for the rear axle in any situation besides drifting
Old Sun, Sep-07-2014, 01:58:34 PM   #33
bigjae1976
Indeed, just mentioned it because the op said he was looking for the ultimate aggressive street alignment.
My reading comprehension temporarily failed me.
But the key for an aggressive street alignment is the toe. I've killed a set of RS3s in about half the time running 1/4" toe out on the front vs 0" toe. I would also say that there is little value in running toe out on the track unless you are running a low speed configuration.
What I used to do with the Vorshlag plates is align the car at my tracks settings (-3.5, 1/8" toe out each side), mark the camber plate and then find out how much camber I would need to get 1/16" toe in on each side. If your shock towers are good to go then, on Vorshlag plates, go from max camber to close to min camber. It was great because I just show up at the track, jack up a corner, loosen 5 nuts, slide the strut inward, and tighen down. Repear on other side. Done.
Vorshlag does make good camber plates (IMO crap everything else) that are apparently designed to do this. Not sure what other brands are doing.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Sun, Sep-07-2014, 02:00:39 PM   #34
bimmerfan08
bimmerfan08's Avatar
I've been told if the car has more negative camber than factory and is to remain street driven but experience some track days and spirited driving, then 0 total toe up front and minimal toe-in in the rear. This will minimize tire wear with increased camber while not making the car too fluttery.
Old Sun, Sep-07-2014, 02:02:15 PM   #35
bimmerfan08
And if it helps...my thread about getting 25k+ miles on my PSS tires was with the alignment settings I posted in this thread.
Old Sun, Sep-07-2014, 03:00:47 PM   #36
bigjae1976
Spot on. Rear toe should be close to OEM spec.
The reason why you run toe in at the rear is when the rear end squats under acceleration, the rear wheels will toe out. So if you run zero toe in the rear...better keep that DSC on! What you want is to allow the rear wheels to be at most at 0 toe under max rear suspension travel. Luckily BMW figured that out for us assuming we are on the OEM suspension. This will help you straighten the car up if you encounter oversteer.
OT...this is a big reason why the E9X platform is a superior handling car. The E9X toes in at the rear under acceleration which provides stability. The OEM specs about 1/2 the rear toe on the E9X as the E46.
Old Sun, Sep-07-2014, 03:13:19 PM   #37
EricSMG
40 something
Mr. Wolfe
Exactly, although I would replace the word lively with difficult. With zero/out front toe the car will never drive straight and tram line badly over bumps and grooves. There will also be no performance gain although it will feel more responsive just off center.
There seems to be two camps: those that want a stable wheel and those that want to give constant attention to it.
2004 E46 M3 6MT SG/Black
Old Sun, Sep-07-2014, 03:42:46 PM   #38
aspa
Reputation: 0 aspa is on a distinguished road
I don't find it difficult at all. But yeah, it's totally a personal taste issue. I also like my food super salty and most people would say "that's inedible it's way too salty". Nope, it's just right!
I have some toe out right now in my "track" alignment so that when I push the strut tops in to reduce camber I wind up with the correct toe in. That is, toe was set at -2.5 camber to be the ideal toe in, and then I pull the struts out to -3.2 for the track and get a slight toe out.
I thought it would suck on the road, but it's totally fine for me. Yes it tramlines and yes you have to be steering constantly. I don't mind that. It's way less than my 911 did (305 tires = terrible tramlining).
For me personally the worse thing is the way a car with toe in doesn't respond to small steering changes on center. It has a small "dead zone" and I just hate the feeling of that. I want immediate response any time I adjust the wheel, even slightly.
Jump to top aspa is offline   Reply With Quote
Old Sun, Sep-07-2014, 03:44:18 PM   #39
aspa
Interesting!
Part of why the 911 is still so much better than the Cayman is the sophisticated multi-link suspension in the rear end that does roughly the same thing : toe in under compression. (whereas the Cayman has those crap Mac-struts in the rear).
Old Sun, Sep-07-2014, 04:41:01 PM   #40
samo6556
samo6556's Avatar
Reputation: 0 samo6556 is on a distinguished road
-3.2 front camber
-.05 toe front.
-2.1 rear camber
.19 toe rear.
2003 Jet Black BMW M3.
Motion Control 2-way,4.10,Ground control sways,Flossman gtr hood,Flossman CSL Trunk,V-CSL bumper,Supersprint stepped headers,Supersprit mids,Supersprint race,Dinan throttle bodies, Karbonious CSL intake ,PFC BBK ,Fall Line pulleys,Apex EC-7 ,Recaro Profi Xl, OEM CSL Roof.
Jump to top samo6556 is offline   Reply With Quote
Discussing Ultimate Alignment Specs? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
