Old Sun, Jul-15-2018, 07:43:01 PM   #661
Originally Posted by MrVond View Post
anyone used this as the clutch switch?
61319231129
my pedal assembly came with it
That's the non-M switch, won't work.
You need 61319122700
Old Mon, Jul-16-2018, 03:59:56 AM   #662
MrVond
The Phanto///M
Reputation: 0 MrVond is on a distinguished road
Finally got my bellhousing modified. Went with using plugs as opposed to the caps
[2006 E46 M3 | Competition Package | Interlagos Blue | Black | AFE Intake | Enkei MT1 | SMG ---> 6MT]
[2011 E90 M3 | Competition Package | Jet Black | Extended Fox Red | AFE Intake| AFE Exhaust | DCT GTS]
Jump to top MrVond is offline   Reply With Quote
Old Tue, Jul-17-2018, 04:08:25 PM   #663
Blaikenstein
Blaikenstein's Avatar
Reputation: 0 Blaikenstein is on a distinguished road
Seeing the bellhousing threaded vs machined for a circlip got me thinking the bellhousing could turn into a diy project. I know a hole still has to be drilled out but I think thatís very doable with a drill press and tap.
As a side note the smg has to go up in value as more and more people do the swap. Itís really not a bad transmission
Jump to top Blaikenstein is online now   Reply With Quote
Old Tue, Jul-17-2018, 04:14:01 PM   #664
MrVond
The Phanto///M
i work for an aerosapce company. it is a very easy way to do it, IMO. you just need to center the holes well.
SMG isnt bad at all, only did the conversions since my unit cannot be adapted via INPA
Old Tue, Jul-17-2018, 04:29:10 PM   #665
ATB88
Reputation: 0 ATB88 is on a distinguished road
You really think enough people are doing this that good SMG cars will start to become rare?? I feel like this forum represents only a small microcosm of E46 M3 owners, no?
Jump to top ATB88 is online now   Reply With Quote
Old Tue, Jul-17-2018, 07:02:10 PM   #666
Blaikenstein
Itís admittedly a long shot but with this becoming easier and more garage friendly I would think the swaps will become more common. I think the smg trans represents a historical change in motor sports. That said bmwís arenít Porscheís so the value likely isnít there.
Swap it, drive it, love it
Old Wed, Jul-18-2018, 10:11:52 PM   #667
MrVond
The Phanto///M
Just a little sanity check here for my swap.
I have a ZCP; and donít need cruise control. This means that I donít have to bother with pin 2 on the clutch switch and I have nothing to wire to the DME?
Old Fri, Jul-20-2018, 08:40:21 PM   #668
I would still wire it. DME makes some calculations based in clutch status even if youíre not using cruise. A real manual ZCP would still have that wiring in place
Old Fri, Jul-20-2018, 10:17:04 PM   #669
PHARMDVIPER
Reputation: 0 PHARMDVIPER is on a distinguished road
I didn't and my car drives fine
Jump to top PHARMDVIPER is offline   Reply With Quote
Old Sat, Jul-21-2018, 01:24:14 AM   #670
“Drives fine” and drives properly are two different things. I’ve driven with that sensor disconnected enough to know that there are subtle driveability differences. ZCP is not special in that regard. It should take all of 10 seconds to wire it. I don’t get the desire to avoid that.
