Old Wed, Jun-12-2019, 06:49:23 PM   #1
fawcetteng
Reputation: 0 fawcetteng is on a distinguished road
Default special tool for vanos pressure?
my local independent shop has never done a vanos in house before. he kept if for months saying he was waiting on a special tool from BMW to set or check pressures for the vanos. I had never heard of this before. is he full of it? by the end of it he has told me the tool came twice and each time it was broken, now he is returning the car saying the vanos doesn't need done.
2003 M3 coupe with 110,000 miles on it.
Jump to top fawcetteng is offline   Reply With Quote
Old Wed, Jun-12-2019, 06:52:49 PM   #2
Drewster
Drewster's Avatar
Default Re: special tool for vanos pressure?
What did you ask them to do with it? You don't need to read the pressure to take care of hub tabs, etc.
I would be looking elsewhere.
Old Wed, Jun-12-2019, 07:12:06 PM   #3
fawcetteng
at their suggestion I asked them to "rebuild the vanos"
Old Wed, Jun-12-2019, 07:54:42 PM   #4
Drewster
Drewster's Avatar
Yup.. time to go elsewhere. Sounds like they don't have a clue.
Where are you located?
Old Wed, Jun-12-2019, 11:14:51 PM   #5
nervous24
Reputation: 0 nervous24 is on a distinguished road
I 100% agree that itís time to go elsewhere, however, if one was to check the vanos pressure you need a gauge that reads to 100 bar (1450psi) or something close to that, I forget. As already mentioned that is not required to lockdown your vanos.
Not that you need one, but Lang Racing sells a suitable gauge for $250.
2003.5 Carbon Black ///M3 @_weaponM
SMG>CAE (1st no drop swap) | MCS | SuperSprint | Rogue | Turner | Bimmerworld | Vorshlag | Hyperco | AKG | PFC | Status Gruppe | Apex | Beisan
Jump to top nervous24 is online now   Reply With Quote
Old Thu, Jun-13-2019, 01:56:08 AM   #6
idntknow2005
idntknow2005's Avatar
Reputation: 0 idntknow2005 is on a distinguished road
I sell a set up let's let's you read the vanos pressure. My setup 75 dollars. I have sold a few of them on here.
2001 E46 ///M3 - LSB+ on Cinnamon - Full Restored
Jump to top idntknow2005 is offline   Reply With Quote
Old Thu, Jun-13-2019, 05:10:34 AM   #7
mrgizmo04
mrgizmo04's Avatar
Check driver rear tire pressure, if it's above 0, no need to worry about rod bearings...
I kid.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Thu, Jun-13-2019, 02:35:00 PM   #8
fawcetteng
I took the car back last night, no vanos rebuild done. the "tool" he is talking about is some sort of switches to activate the vanos solenoid which he says needs activated to pull it apart according to his factory bmw work instructions.
Old Thu, Jun-13-2019, 02:40:03 PM   #9
Drewster
Drewster's Avatar
Everything is right here
http://www.beisansystems.com/procedu..._procedure.htm
Old Thu, Jun-13-2019, 04:54:08 PM   #10
mrgizmo04
mrgizmo04's Avatar
Definitely do NOT need that tool.
Per what Drew posted, follow Beisan's instructions for a DIY, or find a different shop who has worked on S54 vanos.
'05 M3 6MT coupe
Discussing special tool for vanos pressure? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
