Old Mon, Jun-10-2019, 07:49:34 PM   #1
sapote
Default VANOS M3 vs non-M E46
M3 VANOS system is simpler and less parts than non-M.
M3 spline shafts have helical and straight splines, but non-M shafts has two helical splines (internal and external) in opposite direction. The function of the helical shaft is to convert linear to rotational motion, and so why the non-M has the complicated internal and external cut helical splines instead of one helix and one straight?
Old Mon, Jun-10-2019, 08:24:17 PM   #2
Default Re: VANOS M3 vs non-M E46
You tell us mr. vanos wizard
_
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" + 200 cell HFC OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer delete CSL battery
Bilstein HD B6/Eibach 325/600lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing Mason clutch pedal + brass bushing TMS black pedals delrin brake pedal bushing
Old Tue, Jun-11-2019, 03:29:32 AM   #3
mrgizmo04
mrgizmo04's Avatar
Is that rhetorical and you'll tell us tomorrow?
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Wed, Jun-12-2019, 01:37:12 AM   #4
sapote
Non M VANOS operating oil pressure is low, thus the piston oil volume displacement must be small to avoid low oil supply issue. This means the total piston travel is short (i.e. 15mm). In order to convert 15mm linear to 20 degrees cam rotation, it makes sense to have two helical gears on the spline shaft – outer to the hub and inner to the cam to gain more cam rotation.
To meet the goal of fast acceleration car, the M3 VANOS has to response much faster than non M. This requires high pressure oil and a high gain system response. To achieve high gain, either with larger piston or longer stroke (i.e. 30mm). They chose longer piston stroke for a more compact module. To convert 30mm linear motion to 30 degrees cam rotation, there is no need for a double helical splines. Instead simply one helical and one straight on the shaft.
M3 has small solenoid because it only operates on a momentary basic: turned on a short time then switched off to hold the piston at a commanded position, and so little heat is generated.
Non M has larger powerful solenoid to handle the heat dissipation due to operating at a continuous current to hold the piston at a commanded position, instead of switched on and switched off as M solenoid.
Old Wed, Jun-12-2019, 02:12:20 AM   #5
tjkenny15
tjkenny15's Avatar
Thank you Mr. Wizard
2005 BMW M3 INDIVIDUAL - Estoril Blue
Jump to top tjkenny15 is offline   Reply With Quote
Old Wed, Jun-12-2019, 02:23:42 AM   #6
icecream
Registered Apples
icecream's Avatar
Sapote,
You're an interesting fella.
Old Wed, Jun-12-2019, 03:45:30 AM   #7
Drewster
Drewster's Avatar
I'm just waiting for the day Doogan and sapote discover each other...
Old Wed, Jun-12-2019, 04:09:07 AM   #8
mrgizmo04
mrgizmo04's Avatar
Lol
'05 M3 6MT coupe
Discussing VANOS M3 vs non-M E46 in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
