Old Mon, Jun-10-2019, 06:12:24 PM   #1
sapote
Default VANOS disk new holes and upper guide works
I had my original VANOS disk drilled with smaller holes. New smaller holes with D=0.384, centered on circle R=0.797. The driving tabs width = 0.380, therefore the new smaller holes mated to tabs with 0.004 clearance. Original holes D=0.419 with clearance = 0.039, or about 10X larger. At 72K miles the disk holes and tabs looked perfect. I also removed both cam sleeves bolts, cleaned and added medium Loctite torqued to 9 ft-lbs.
Also replaced the worn upper chain guide with Beisan solid guide. The old guide top surface worn only 0.002 by the moving chain, but the lower surface worn 0.100 by rubbing with the lower guide. I believe one of the reason for this significant wear is lack of oil lubricant in this intimate mating surfaces between the two guides. Once lapped down together the surfaces have no gap for oil. I think by drilling two small holes and chamfered (marked red circles) through this surface would provide oil for these surfaces which are dried otherwise under the tensioner force. The stock unit is hollow and so the drilled holes might not carry the oil effectively, but the solid Beisan should be more effective with the drilled oil holes. To remove the guide long bolt #7, the metal coolant pipe mounting bracket 10mm bolt needs to be remove and pushed out a little (Beisan procedure omitted this) . I found the bolt original gasket was aluminum O-ring but the RealOEM listed as copper as shown in this link. Can someone confirm this?
https://www.realoem.com/bmw/enUS/sho...diagId=11_2992
Jump to top sapote is online now   Reply With Quote
Old Mon, Jun-10-2019, 11:51:32 PM   #2
mrgizmo04
mrgizmo04's Avatar
Default Re: VANOS disk new holes and upper guide works
I think I remember mine being copper
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Tue, Jun-11-2019, 02:06:45 AM   #3
Boosted 1
Reputation: 0 Boosted 1 is on a distinguished road
The ones I took off were copper, so were the replacements
Jump to top Boosted 1 is offline   Reply With Quote
Old Thu, Jun-13-2019, 11:08:15 PM   #4
sapote
Everything installed but I removed the new Beisan guide for mod and the guide bolt aluminum washer to confirm it's aluminum, and it is as shown in pix.
I will drill the oil holes for the chain guide today.
Btw, I couldn't find my 32mm 1/2 socket for the chain tensioner in the set, but I had one in the massive 3/4 socket set. I was surprised that the huge ratchet and socket fitted even with the radiator lower hose connected.
Old Fri, Jun-14-2019, 02:28:24 AM   #5
sapote
Drilled oil holes on the guide at 45* angle to help oil flow:
Discussing VANOS disk new holes and upper guide works in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
