Old Tue, Jun-11-2019, 05:59:07 PM   #11
evanr614
Reputation: 0 evanr614 is on a distinguished road
Default Re: Trouble installing rear axle
Originally Posted by mrgizmo04 View Post
CV joints telescope a bit. Are you able to move the end of the CV in and out and make sure it is in the extended position?
Yeah it will move into it's extended postition. I finally decided to pull the axle out of the hub and do a more accurate measurement of the old and the new. This new axle shaft is in fact shorter...problem solved I suppose, but still very confusing as far as the part numbers and everything go, it should fit...
Jump to top evanr614 is offline   Reply With Quote
Old Tue, Jun-11-2019, 07:09:51 PM   #12
Kdubski
Kdubski's Avatar
For the 2nd time, you purchased the wrong side axle shaft. Driver and passenger sides are different lengths.
Old Tue, Jun-11-2019, 08:17:48 PM   #13
evanr614
Pump the brakes man, I know this. I didnít feel it was necessary but here you go, the part number on the axle I bought. It is for the passenger side.
Discussing Trouble installing rear axle in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
