Old Mon, Jun-10-2019, 01:15:21 AM   #1
CraigMak
CraigMak's Avatar
Reputation: 0 CraigMak is on a distinguished road
Default Very Rough Idle
So, I just took my car out for a drive today and when I was at a stop light idling I felt that it almost died.
Then on my way back home it suddenly went into limp mode and and the idle became very rough. It sounds and feels like something is off balance. Any idea what would cause this?
________________________________________________
2001 BMW M3 Vert Imola Red|Black Grills&Vents|Custom German Plate|19" Deep Dish Rims|CF Roundel|
1998 BMW 328i |M3 Bumper|Chrome Grill|Clear Corners|eyebrows|Trunk Lip|Euro Fogs|German Plate|
Jump to top CraigMak is offline   Reply With Quote
Old Mon, Jun-10-2019, 01:27:02 AM   #2
brandong2025
brandong2025's Avatar
Reputation: 0 brandong2025 is on a distinguished road
Default Re: Very Rough Idle
I just had the same thing happen too me last week. One of my coils whent out an was causing a misfire. I would say buy a scanner if you don't already have one and scan it.
Sent from my SM-G965U using Tapatalk
Jump to top brandong2025 is offline   Reply With Quote
Old Mon, Jun-10-2019, 01:41:37 AM   #3
CraigMak
CraigMak's Avatar
Thanks, that's what I initially thought it might be. I thought I had a scanner but couldn't find it.
Old Mon, Jun-10-2019, 01:43:55 AM   #4
erickrayos
read codes coz It could be literally quite a few thing that is causing the misfire.
Old Mon, Jun-10-2019, 02:17:20 AM   #5
CraigMak
CraigMak's Avatar
Any recommendation on a code reader? Will the $30 eBay special work just fine as long as it has BMW codes? What do the more expensive ones offer that I might care about?
Old Mon, Jun-10-2019, 05:40:39 AM   #6
mrgizmo04
mrgizmo04's Avatar
Get an obd2 bluetooth adapter and buy the obdfusion app. It's great for clearing codes, basic troubleshooting, can do logging, dashboards of readouts, monitor readiness check, etc.
That said, you can borrow and get a free scan of codes at autozone and the like.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
'04 S2000
All DIY: VANOS, WPC rod bearings, full SS (SS stepped V1 headers, catted S1, resonated S2, SS sport), AFD E85 Proflex kit, Ohlins R&T/Hyperco 375f Swift 672r/GC street tops and camber plates, ST40 355 pfc08, 330 ZHP steering rack, diffsonline 4.1 diff with rem polish, E60 short shifter lever, AKG black diff bushings/subframe bushings, Rogue rtab, Sachs clutch/flywheel, rear main, Beyer driveshaft, valve adjustment, cooling refresh.
Old Mon, Jun-10-2019, 07:46:39 AM   #7
CraigMak
CraigMak's Avatar
Yeah, I know autozone does it for free but I don't think I want to be driving my car around the way it is.
Old Mon, Jun-10-2019, 02:37:14 PM   #8
If you want to diagnose if it’s a coil/which it is for free, unplug them on at a time. When you find the one that doesn’t change the idle, that’s the problem cylinder. Swap the coil with another cylinder to see if it’s the coil or plug that failed.
Old Mon, Jun-10-2019, 08:42:58 PM   #9
CraigMak
CraigMak's Avatar
If you want to diagnose if itís a coil/which it is for free, unplug them on at a time. When you find the one that doesnít change the idle, thatís the problem cylinder. Swap the coil with another cylinder to see if itís the coil or plug that failed.
Thanks! Yeah, I did see that procedure on youtube. Looks pretty straight forward and easy. I'm probably just going to buy the whole kit to replace spark plugs and ignition coils as well as any tools I need. Even buying tools it will probably cost less than taking it to a shop. Then I have the tools forever.
My idle seems a lot rougher than the video. The guy had a glass of water resting on the engine to show how rough it was when he was switching the coil in and out. Mine seems more like 2 coils are dead.
Old Sun, Jun-16-2019, 08:01:39 PM   #10
CraigMak
CraigMak's Avatar
I just pulled some codes today. It's looking like it's not going to be as easy as replacing my ignition coils. I got the following:
P0301: CYLINDER 1 MISFIRE
P0302: CYLINDER 2 MISFIRE
P1341: MULTI CYLINDER MISFIRE WITH FUEL CUT OFF
I cleared the codes and started it up with the reader in place and it immediately kicked out codes:
P0303: CYLINDER 3 MISFIRE
P0304: CYLINDER 4 MISFIRE
I looked at live data and it gave me:
FUEL SYSTEM 1: OL_FAULT
FUEL SYSTEM 2: OL_FAULT
So it's looking like something to do with fuel pump or fuel injectors? I've never had to replace either and it's an 01' with 165K miles. Any insights on these codes? What should I look at next?
Discussing Very Rough Idle in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
