Old Thu, Jun-06-2019, 05:57:47 PM   #1
HassanEido
HassanEido's Avatar
Lebanon
Default Vanos pressure woes and solutions
So the past few days I've been battling vanos issues fixing a couple of friends cars in our local community. And I think I've got some interesting information for u guys so I thought I'd share.
-The first car got cammed(280 272 cat cams).
After the cam install we did a vanos test and it failed intake advance at 340ms. So we measured the vanos pressure and it was 60bars(115 required). We changed the vanos pressure valve and it went up to 80 bars. Still down on pressure. The owner had forgotten to install the pressure relief valves in the cat cams from his original cams. We did that and retimed the car and the pressure gauge needle was pegged at 160 bars lol. We had to dial it back to 115. Success.
-the second car has stock cams, but had unknown vanos oil pressure and was suffering an abysmal low end, no codes.
We measured its pressure it read 40 bars.. 40! It then proceeded to go down to a record breaking 20 bars when at operating temp. Yep u read that right. We changed vanos pressure valves and max it got was 60 bars. Still way way way down. We ordered a set or vanos seals thinking we will need those.
Just for kicks we installed a known to be good solinoid pack, started the car expecting nothing special, to my surprise the pressure was pegged at 140 again on a cold start then started to go down to 90bars at idle and 115 bars at 2k rpms.
Conclusion :if your new pressure valve doesn't get the vanos oil pressure up to spec, try the vanos solinoid pack also. If you're getting cams, make sure u have cam shaft relief valves in there before u install them.
The seals we ordered are going in the drawer for now... No need for those now.
Cheers
Hassan
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Thu, Jun-06-2019, 06:07:50 PM   #2
Drewster
Drewster's Avatar
Default Re: Vanos pressure woes and solutions
I'd imagine a good clean of the valve body would also help - every time I clean mine out I can tell a difference in how the engine responds.
Old Thu, Jun-06-2019, 06:11:25 PM   #3
sapote
How do you measure the pressure and where did you tap in for the pressure gauge?
The vanos high pressure relief valve is on the left side of the vanos housing, and so i'm lost on the said cam's relief valve.
Old Thu, Jun-06-2019, 06:16:09 PM   #4
Drewster
Drewster's Avatar
Most measure at the accumulator's banjo fitting. This diagram shows the valve in the camshafts (11)
Old Thu, Jun-06-2019, 06:24:59 PM   #5
HassanEido
HassanEido's Avatar
Lebanon
This
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Thu, Jun-06-2019, 06:42:04 PM   #6
Drewster
Drewster's Avatar
Yes - accumulator *line* banjo fitting.. not at the accumulator lol
Old Thu, Jun-06-2019, 07:43:49 PM   #7
sapote
This diagram shows the valve in the camshafts (11)...
Diagram?
Old Thu, Jun-06-2019, 08:10:38 PM   #8
dutchhome
Reputation: 0 dutchhome is on a distinguished road
Can you point me to the gauge and fittings I should use to do this? I'm replacing cams and followers soon along with all vanos repairs and upgrades and I'd love to check and set this pressure properly.
Fwiw, my vanos solenoid pack blew up on me - there is now a hole where some orange seal used to be? I haven't removed it yet to inspect but spits out oil if I start the car (no codes thrown though).
Jump to top dutchhome is online now   Reply With Quote
Old Thu, Jun-06-2019, 08:17:36 PM   #9
.'s Avatar
Reputation: 0 . is on a distinguished road
If you want an easy solution and don't mind the extra money you can buy a gauge setup ready to go like this: https://store.langracing.com/bmw-s54...e-testing-kit/
Or you can make your own with an equivalent gauge, a spare banjo bolt you can drill and tap the top of, and one or two adapters/reducers to get the gauge thread down to size of the banjo bolt hole you just drilled.
2001 E46 M3 - Slicktop Manual Coupe - Alpine White on Imola Red
Engine: Karbonius CSL airbox, Lang Racing stage 2.5 head, Schrick 288/280 cams & followers, Lang Racing rod journal widening kit w/ CP 12:1 87.5mm pistons & Carrillo rods, Kassel CSL DME & MAP conversion, 36lb injectors, Paul Claude tune, APE Flex fuel kit, TMS Power Pulleys, SS V1 stepped headers & catless section 1, SS 2.5 twin-piped resonated section 2, SGT scza section 3.
Drivetrain: DKM Stage 2 Clutch, E60 Shifter, RE trans mounts, Motorsport 4.10 R&P, Revshift 80A diff bushings.
Suspension/Brakes: Bilstein PSS9's, RE RSM's, UUC sway bars, BW camber arms, TMS monoball RTABs, ZCP rotors, BW solid caliper guide bushings, PFC 08's, Motorsport Hardware 75mm stud kit.
Interior: Cobra Nogaro seats, BMW Performance pedals, OE alcantara boots, mason clutch pedal, Xtrons 9" headunit w/ carplay
IG: Zach_e46M
Jump to top . is offline   Reply With Quote
Old Fri, Jun-07-2019, 06:39:47 AM   #10
Nambo
Reputation: 0 Nambo is on a distinguished road
I love happy endings
Jump to top Nambo is offline   Reply With Quote
Discussing Vanos pressure woes and solutions in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
