Old Fri, Jun-07-2019, 04:32:55 PM   #31
HassanEido
HassanEido's Avatar
Lebanon
Default Re: Overheating in Traffic—Aftermarket Radiator Daily Performance
Originally Posted by Andrebxp View Post
Any particular reason not to use more water, or water wetter?
Coolant has anticorrosion additives and acts as a lubricant to ur water pump. I wouldn't run a higher mix of water unless extreme heat. A higher mix of water does absorb more heat than coolant but at a cost.
Regarding water wetter, why fix an issue with a bandaid rather than addressing the root cause and be done?
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Fri, Jun-07-2019, 04:57:45 PM   #32
Water wetter does have negative issues long term, too.
Old Fri, Jun-07-2019, 05:30:15 PM   #33
Drewster
Drewster's Avatar
For what it's worth, Koyorad ships with a big warning saying that using water wetter or similar products will void the warranty.
I ran with a majority distilled water and regretted it due to corrosion all over my cooling system.. I still need to flush it /sigh
Old Sat, Jun-08-2019, 05:52:00 PM   #34
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Yep mine came with this warning. I’m running 80/20 mix and so far it’s working good.
Old Sun, Jun-09-2019, 05:16:58 AM   #35
Cronenberged
Cronenberged's Avatar
Reputation: 0 Cronenberged is on a distinguished road
Running only a Spal puller w/CSF radiator. My needle never goes above center. I also completely overhauled the cooling system.
Formerly known as ///M3_Letty
Jump to top Cronenberged is offline   Reply With Quote
Old Sun, Jun-09-2019, 05:48:01 AM   #36
SeanE46
SeanE46's Avatar
Reputation: 0 SeanE46 is on a distinguished road
Armenia
Originally Posted by Fresh1179 View Post
Trust me guys, I’ve been running the heat in my black on black car in 85-99 degree heat. I’m not too happy about it. It seems like there is no consensus on the best setup. I’m going in there to replace everything from a maintenance standpoint anyways in the cooling system. I’m just trying to determine which radiator/fan setup I’m going with. IN AN ABUNDANCE OF CAUTION, and with the knowledge that the car will see the track in high ambient temps, I’m going to go with a SPAL fan and a new aftermarket radiator, probably the Koyo or CSF radiator, most likely the Koyo. I’m also going to switch up my coolant ratio.
Go OEM like they’re telling you, I went oem with my first m3 and I was very happy
2001 M3 6MT TiAg Coupe SOLD
2002 M3 6MT TiAg Coupe SOLD
2004 M3 SMG Silver Grey CURRENT
Jump to top SeanE46 is offline   Reply With Quote
Old Mon, Jun-10-2019, 01:07:48 AM   #37
Metro81
Reputation: 0 Metro81 is on a distinguished road
Seems like a capacity issue to me if the fans are operating as intended. Either water pump not cycling the fluid effectively or rad has lost quite a bit of efficiency - or maybe both. As others have suggested, properly functioning oil cooler can help bring down water temp, but seems to me that refreshing rad/pump maybe a good start.
TTFS | CPI | RE | APEX | PFC | KW | GC | BimmerWorld | Hard Motorsports | Status Gruppe | n15DESIGN | RaceWerks
Jump to top Metro81 is offline   Reply With Quote
Discussing Overheating in Traffic—Aftermarket Radiator Daily Performance in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
