Old Thu, Jun-06-2019, 05:56:41 PM   #1
Fresh1179
Fresh1179's Avatar
Reputation: 0 Fresh1179 is on a distinguished road
Default Overheating in Traffic—Aftermarket Radiator Daily Performance
My car has been getting dangerously close to the red during everyday driving. I know that the manual says that operation between the two dots is normal. This is above that. I have bled the system, there is no air. The most likely culprit is the clutch fan. My aux/pusher fan is performing well.
That begs the question, will an aftermarket “performance” radiator help with DAILY driving temps. This would be installed in conjunction with an electric fan. The car will see the track, but as we unfortunately know, it will see many more miles in traffic. The car is at 105k now so I’m looking at a complete cooling system overhaul. The ambient temperatures in N.C. are in the mid-90’s and VIR will see similar temps. I am looking at Mishimoto and their fan (along with replacement of the other cooling components). Does anyone have experience with this setup (or similar) in a high temp ambient temp area on a daily basis? Track experience would be great as well. Thanks!
Enjoy Every Sandwich-Warren Zevon
Jump to top Fresh1179 is offline   Reply With Quote
Old Thu, Jun-06-2019, 06:11:50 PM   #2
Ramp1
Ramp1's Avatar
Reputation: 0 Ramp1 is on a distinguished road
Default Re: Overheating in Traffic—Aftermarket Radiator Daily Performance
Most people on here will tell you that new OE parts will be more than fine for daily and it's true...these cars don't overheat in daily traffic until something is old or worn out. I would check the fan clutch, replace if needed along with the fan blades.
If you want an aftermarket rad then Koyorad or Zionzville (sp?) are both really good but new OE rad is also perfect. I've been running a Koyorad for the past year with no mechanical fan at all to see how well the rad works with just the front pusher and I have only gone up to 88c in hot weather sitting in traffic and then the pusher kicks in and drops it back down to 82-83c.
Jump to top Ramp1 is offline   Reply With Quote
Old Thu, Jun-06-2019, 06:12:25 PM   #3
Drewster
Drewster's Avatar
The clutch fan is the primary problem. I personally went with a SPAL fan and it helped with overheating in traffic, even on the stock rad.
After that I replaced the old stock radiator with Koyorad which helped even further, but I suspect it's right on par with a fresh OE BMW Radiator. There are mixed reviews on Mishimoto
The most noticeable improvement I had in on-track cooling was actually my CSF oil cooler.
Old Thu, Jun-06-2019, 06:14:38 PM   #4
tjkenny15
tjkenny15's Avatar
For your application, I would avoid the Mishimoto fan. Not strong enough to cool the motor in the South.
I think your best look is the CSF rad. and a SPAL fan setup.
In the meantime, run the heat and cabin fan on your car if you start to overheat.
2005 BMW M3 INDIVIDUAL - Estoril Blue
Jump to top tjkenny15 is offline   Reply With Quote
Old Thu, Jun-06-2019, 06:22:14 PM   #5
Steve M3
My coupe will sit in traffic all day long without overhearting.
My wagon starts to tick up in traffic now that it's starting to get warm outside.
The weird thing is that the wagon has a newish water pump, fan clutch and fan where as the coupe is still on original components. I've been wondering if it's an airflow issue due to the non-m front bumper cover or if it has something to do with half of the radiator shroud missing for the csl box. This combo never got hot in my convertible, which is why I'm leaning towards airflow issues.
If your car is stock, I would say to start with the basics as your car shouldn't overheat if your cooling system components are in proper working order.
Old Thu, Jun-06-2019, 06:30:23 PM   #6
.'s Avatar
Reputation: 0 . is on a distinguished road
I suspect you have more problems than just the clutch fan. This probably won't be a popular opinion around here but I haven't ran a clutch fan in close to 4 years on this car (without the addition of an extra electric fan in its place just the stock aux fan) and more before that on my previous e36 m3. Never had an overheating issue even in prime florida summer heat which I'm sure is worse than you see in NC. I see stop and go traffic almost daily and oil temps will climb slightly above 205 but water always stays right in the center never seen it move to the right like yours. My cooling system is also fairly old too though I'm getting ready to replace it. If you're getting past the right dot you have serious cooling system issues imo and I'd be looking to replace the radiator and water pump asap. I don't think you're going to get any extra benefit from an aftermarket rad and should stick to OE.
2001 E46 M3 - Slicktop Manual Coupe - Alpine White on Imola Red
Engine: Karbonius CSL airbox, Lang Racing stage 2.5 head, Schrick 288/280 cams & followers, Lang Racing rod journal widening kit w/ CP 12:1 87.5mm pistons & Carrillo rods, Kassel CSL DME & MAP conversion, 36lb injectors, Paul Claude tune, TMS Power Pulleys, SS V1 stepped headers & catless section 1, SS 2.5” twin-piped resonated section 2, SGT scza section 3.
Drivetrain: DKM Stage 2 Clutch, RTD V2 mini shifter, RE trans mounts, Motorsport 4.10 R&P, Revshift 80A diff bushings.
Suspension/Brakes: Bilstein PSS9's, RE RSM's, UUC sway bars, BW camber arms, TMS monoball RTABs, ZCP rotors, BW solid caliper guide bushings, PFC 08's, Motorsport Hardware 75mm stud kit.
Interior: Cobra Nogaro seats, BMW Performance shift knob/e-brake/pedals, OE alcantara boots, mason clutch pedal, Xtrons 9" headunit w/ carplay
IG: Zach_e46M
Jump to top . is online now   Reply With Quote
Old Thu, Jun-06-2019, 06:39:30 PM   #7
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Sounds like your clutch fan is bad as stated. I live in the hot Las Vegas desert and we see summer temps from 100-120 degrees. I'm running a Koyorad radiator, Spal 2082 electric fan controlled by a PWM unit and the Aux Fan still in place. Coolant ratio of 80/20 water vs coolant which cools better in really hot climates. I've tested coolant ratio's over the last few years and this works the best with approx 10-15 degrees difference. I recently changed my water pump, T-stat, pulleys, radiator and fan. Yesterday it was 106 degrees and my coolant temps were 195 idling in traffic.
Take a look at my build thread with pictures and links.
http://www.m3forum.net/m3forum/showpost.php?p=1067958636&postcount=217
Thread about the Spal 2082 Electric Fan
http://www.m3forum.net/m3forum/showthread.php?t=599479
Old Thu, Jun-06-2019, 07:01:58 PM   #8
Fresh1179
Fresh1179's Avatar
I agree with you %100. I’m changing out all the old components when I take the old radiator out anyways so hopefully that will be an added bonus.
Old Thu, Jun-06-2019, 07:03:09 PM   #9
Andrebxp
Reputation: 0 Andrebxp is on a distinguished road
Run less antifreeze and more water if you live in an area where it doesn't get very cold.
Jump to top Andrebxp is offline   Reply With Quote
Old Thu, Jun-06-2019, 07:03:29 PM   #10
Fresh1179
Fresh1179's Avatar
Thank you! I’m going to take a look at this tonight. This is looking like a pretty good solution along with replacement of the other cooling components.
Discussing Overheating in Traffic—Aftermarket Radiator Daily Performance in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
