Old Mon, Jun-10-2019, 07:22:34 PM   #31
JaredMV
Amateur Weekend Mechanic
JaredMV's Avatar
Default Re: At wits end bleeding coolant
I didn't read the thread so disregard if this has been mentioned before or debunked, but I believe it was terraphantom that said the M3 cooling system is self-bleeding and the only reason we have a bleeder screw is because the same hose is used in non-M's.
JaredMV's M3 Touring Build: http://www.m3forum.net/m3forum/showthread.php?t=604213
Originally Posted by Jaredomin View Post
8k shipped. Lmk thanks
Jump to top JaredMV is online now   Reply With Quote
Old Mon, Jun-10-2019, 07:23:37 PM   #32
sapote
Ur cooling system sucks
M3 or non-M?
I found M3 coolant system is 10X better than non-M, both material and design.
Old Mon, Jun-10-2019, 08:05:47 PM   #33
HassanEido
HassanEido's Avatar
Lebanon
Lightbulb Re: At wits end bleeding coolant
I never ever bled mine. Ever. It self bleeds and I never had a problem with air bubbles or coolant hoses collapsing
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Tue, Jun-11-2019, 03:33:47 AM   #34
mrgizmo04
mrgizmo04's Avatar
I don't bleed it either, even after major overhaul, no issues.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Tue, Jun-11-2019, 07:17:12 AM   #35
sapote
OP car is a non M car and coolant system needs bleeding.
Old Wed, Jun-12-2019, 04:23:44 AM   #36
mrgizmo04
mrgizmo04's Avatar
Why is a non-M car being discussed in M3 forum? Who authorized this?
'05 M3 6MT coupe
Old Wed, Jun-12-2019, 07:47:51 AM   #37
stash1
'04 AW/IR...some mods
Old Wed, Jun-12-2019, 12:27:47 PM   #38
mcfreid
Reputation: 0 mcfreid is on a distinguished road
Took some pics this morning of the vacuum that is being pulled by the system. There's no way this is normal, right?
Jump to top mcfreid is online now   Reply With Quote
Old Wed, Jun-12-2019, 03:01:09 PM   #39
sapote
Photos say don’t show much. If no overheating, no lost coolant, then don’t worry but continue checking coolant weekly.
Old Thu, Jun-13-2019, 05:11:25 AM   #40
mrgizmo04
mrgizmo04's Avatar
Originally Posted by stash1 View Post
AND it's a not safe for work thread...
'05 M3 6MT coupe
bleeding, coolant
Discussing At wits end bleeding coolant in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
