Old Thu, Jun-06-2019, 05:54:38 PM   #11
sapote
Default Re: At wits end bleeding coolant
Originally Posted by mcfreid View Post
Please help. God please help me.
Can't -- He only drives E46 M3.
A week ago I filled up the cooling system till the coolant ran out of the bleeder valve. Then I closed the valve and reservoir cap, ran the engine till the coolant got up to temperature...
This is bad -- with the excess coolant in the tank (high enough to overflow out of the bleeder) and less air, the higher pressurized coolant could bust the tank and other components.
This time when I went to drive, the coolant light turned on letting me know that the coolant was low. I pulled over to double-check the level and it was full.
Since OP didn't say the light was on before the work, and the tank was not replaced in this work, therefore I don't think the tank level sensor at fault.
Overheated because it was not bled correctly with air pocket still in there.
My method for E46 not M3:
1) with cold engine, fill tank to max level, cap removed
2) run engine and rev up to 3000 rpm a few times, then open the bleeder for air to get out, and top up the tank to max level. close bleeder. Repeat step 2 again. Shut engine off. Don't run the run more than 7 minutes to avoid heated coolant overflow.
3) top up tank to max; close tank cap and do a test drive with heater turn on. If there is hot air from heater then it's good.
Old Thu, Jun-06-2019, 06:29:17 PM   #12
jdamore44
Reputation: 0 jdamore44 is on a distinguished road
Originally Posted by sapote View Post
Can't -- He only drives an E30 M3.
Overheated before it was not bled correctly with air pocket still in there.
Fixed.
1983 320iS - SOLD
1997 328iS Sport - SOLD
2003 Steel Grey Metallic M3 6MT Coupe, Black Interior
Jump to top jdamore44 is online now   Reply With Quote
Old Thu, Jun-06-2019, 06:46:56 PM   #13
mcfreid
Reputation: 0 mcfreid is on a distinguished road
Originally Posted by sev View Post
What brand is it? I had the *EXACT* same issue on my 330cic and drove myself nuts changing the sensor and bleeding it. And every time it warmed up the light would come on. There was 0 air in the system.
I was reading on e46 fanatics that a batch of behr expansion tanks were defective and from the factory the float was installed upside down. So the magnet that triggers the sensor is not in the correct position.
I put in a OEM tank and it worked perfectly on first bleed.
Man, I'm really hoping now this is not the issue. The expansion tank I installed was this one (Modine) https://www.fcpeuro.com/products/bmw...em-17137787039
Jump to top mcfreid is online now   Reply With Quote
Old Thu, Jun-06-2019, 06:52:10 PM   #14
mcfreid
I believe this is exactly what I did the first time (when the car started to overheat) and when the coolant level was physically observed to be low. Note, the coolant light was *not* on at that time despite the coolant level being way low. I then filled up the tank to between min and max and bled, then drove off. *Then* the coolant light turned on making me think the coolant level was low. Pulled over, and filled up the coolant tank till the coolant spilled out of the bleeder valve. Drove awhile, and bled the air from the bleeder valve. The coolant light stayed on.
Now that I think about it... That the coolant level light was *not* on when the car started to overheat and when the coolant was actually noticed to be too low. And that the coolant level light is now on when the car is not overheating and when the coolant level appears too full... This all does point to either the sensor or the float being bad : \
Old Thu, Jun-06-2019, 06:57:23 PM   #15
sev
Reputation: 0 sev is on a distinguished road
try temporarily putitng your old one back and see if the issue goes away. it sucks to do but only way to tell.
Sev - 05 M3, Silver Grey 6 speed/Black Nappa, 01 Z3 Mcoupe, S54 Titanium Silver/Black Nappa
Jump to top sev is offline   Reply With Quote
Old Thu, Jun-06-2019, 07:36:36 PM   #16
sapote
Need detail. How did you bleed with tank level below max?
Pulled over, and filled up the coolant tank till the coolant spilled out of the bleeder valve. Drove awhile...
Do you know driving with tank filled up too high is bad?
Now that I think about it... That the coolant level light was *not* on when the coolant was actually noticed to be too low. And that the coolant level light is now on when the coolant level appears too full... This all does point to either the sensor or the float being bad : \
Never heard a single case that they mistakenly added an inverter into the sensor. I bet the system was not bled properly that's all.
Old Thu, Jun-06-2019, 07:43:42 PM   #17
mcfreid
Capped off the radiator, ran the car until the coolant came up to temperature, let the engine cool down, unscrewed the bleeder valve to let out the excess air.
Yes - however I wasn't trusting that it *actually* was filled full as I expected there was air in the system which was stopping the coolant level from dropping in the reservoir (based on the coolant light turning yellow when the car ran).
Certainly possible too - any ideas on what I should do now to fix it? If it's not the sensor, then that means that the coolant level really is low and that there's just excess air in the system which is preventing the coolant from dropping in the reservoir. How would you suggest I get that air out of the system?
Old Thu, Jun-06-2019, 08:16:08 PM   #18
sev
I dont think its the sensor ts not the sensor.. (at least it wasnt in my case)
Easy way to tell if it's the sensor is to swap the sensor from your washer fluid reservoir. Its the same exact sensor.
With this ordeal that I had, i had to dump the system and refill/bleed it a few times. Honestly its pretty easy to do. If you turn on the heater, fill the system, even while its off, until the coolant comes out of the bleed screw, its usually 95% filled. I only had run it a heat/cool cycle once, bleed it again and its been good the last year...
Old Thu, Jun-06-2019, 08:52:49 PM   #19
mcfreid
That's how it was in my m3 as well - super simple. That's why I'm so flummoxed now that I'm dealing with the wagon.
Old Thu, Jun-06-2019, 08:54:50 PM   #20
sev
more food for thought.. I know this isnt the same brand, but looks like this is a common issue
bleeding, coolant
Discussing At wits end bleeding coolant in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
