Old Fri, May-31-2019, 02:59:02 PM   #1
Mpowerzz
Reputation: 0 Mpowerzz is on a distinguished road
Default Wipers not parking
Was driving home last night in the rain, had the wipers set to the intermittent setting, then the wipers start sticking on the middle of the windshield . It works fine on the other settings , normal , fast.. So got home and turn off the wipers. It stuck in the middle, So I shut off the car, moved it manually to the bottom. Tried the wipers again now instead of being stuck in the middle, its a few inches above the park position. Maybe its the relay?
Jump to top Mpowerzz is online now   Reply With Quote
Old Fri, May-31-2019, 04:00:55 PM   #2
04yfz
Default Re: Wipers not parking
Relay should fix that.
Pat
Old Fri, May-31-2019, 04:19:58 PM   #3
Mpowerzz
I hope so, back in the day it was less than $30, Now its $79. I just ordered one.
Old Tue, Jun-11-2019, 02:12:36 PM   #4
Mpowerzz
I changed the relay, same problem. What should I do now, Check the whole wiper assembly?
Old Thu, Jul-11-2019, 03:21:04 PM   #5
Mpowerzz
Well the wipers just gave out, I could hear the motor running, the wipers barely move, You think something got loose and just need to be tighten?
Old Thu, Jul-11-2019, 08:47:52 PM   #6
Toxic0n
I'd take them of and look. Pop the black caps off you should be able to see. 15mm nuts and you can take the actual arms off if you need to. I wonder if something got stripped or misaligned when you tried to move them manually.
Ground Control, Mason Engineering, HRE, ACS, Rogue Engineering
Jump to top Toxic0n is offline   Reply With Quote
Old Thu, Jul-11-2019, 09:00:30 PM   #7
Mpowerzz
I think something got stripped, I ordered another assembly, I read the diy to take it out and replace. It don't look too hard to do.
Old Sat, Jul-13-2019, 02:10:29 PM   #8
Mpowerzz
Just changed out the whole assembly. Wasn't too hard. Just need a 24 mm deep socket for the nut on the wiper arm. Now I have wipers again.
Discussing Wipers not parking in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
