Old Sat, Jun-08-2019, 06:01:03 PM   #31
2003wmb
Reputation: 0 2003wmb is on a distinguished road
Default Re: SMG Pump Maintenance/Troubleshooting: Complete Guide
SMG cog light
It is a 2006 MY.
Jump to top 2003wmb is offline   Reply With Quote
Old Sun, Jun-09-2019, 05:13:13 AM   #32
SMG cog light
Originally Posted by 2003wmb View Post
SMG cog light
I was looking at the the GOOD_M3 2.0 E46 M3 Build/Journal
and in one of the images it looks like the pressure sensor next to the temp sensor has 3 wires. Is this the pressure sensor or some other sensor? I'm curious because I thought the pressure sensors are a two wire sensor. Maybe newer model?
http://www.m3forum.net/m3forum/showt...=599036&page=5
Yes. That round sensor is the hydraulic pressure sensor.
Jump to top SMG cog light is offline   Reply With Quote
Old Sun, Jun-09-2019, 06:54:07 AM   #33
gigika
Reputation: 0 gigika is on a distinguished road
Wales
...in the end, all of you guys forgot one thing more. SMG speed setting. I now drive mine how many 10 years ALWAYS in position 1. Forget stupid "snow setting or something". The lowest setting all the time, the lowest fatigue for the system. ...and the car drives just fine without no problems and also bliping every time when shifting (no stupid CSL softwares and so)
Jump to top gigika is offline   Reply With Quote
Old Sun, Jun-09-2019, 05:19:40 PM   #34
2003wmb
Hi SMG cog light
I have not taken a pump apart that's why I'm asking these questions.
So do the older models have a 2 wire pressure sensor and only the newer have a 3 wire sensor? or do all SMG II pumps have a 3 wire sensor? I was looking online at the senor and it seems to look like 2 wire sensor.
thanks for your response.
Old Sun, Jun-09-2019, 06:17:40 PM   #35
SMG cog light
This post was irrelevant to the thread.
Old Sun, Jun-09-2019, 06:21:41 PM   #36
SMG cog light
Hi SMG cog light
All of the pumps I have worked on have 3 wires going to the hydraulic pressure sensor. I also rarely have to replace that sensor because it does not fail as often as the temperature sensor. But if you are doing a full pump recondition/rebuild then I recommend that you replace both sensors and all of the seals and the accumulator and the motor. The only thing that doesn't fail or is built well are the actual solenoid valves. Just the solenoid valves seals fails.
Old Mon, Jun-10-2019, 04:09:51 AM   #37
2003wmb
SMG cog light thank you for clarifying my question about the pressure sensor.
Old Mon, Jun-10-2019, 01:02:02 PM   #38
oceansize
Kwisatz Haderach
oceansize's Avatar
I just ordered the SMG relocation kit (built by some members on this forum) and burkhart SMG repair kit. I have zero issues other than I need a new project and since my pump is original and at 99k miles I figured this would suffice. I will be replacing the o-rings and sensors and what not as well.
I will take all related temperature and pressure measurements before and after and report back. I've got the schwaben scanner, autoenginuity, DIS, and INPA so I will see what each reports as a crosscheck of the various tools. Should be fun.
2003 M3 Convertible SMG w/Hardtop | GC Coilovers and Camber Plates | ESS VT1-475 Gen 3 Supercharger | Stoptech Brakes
Apex ARC-8 19" Hypersilver | CSL SMG (and 255) Tune | RE Diablo Exhaust w/ SS Tips | RE Rasp Pipe
Storm Motorwerks SMG Paddles | Two Tone Black/Grey Interior | Alcantara E-brake Boot
Very Recent Maintenance: FCABs | FCAs | RTABs | Motor Mounts | PS Hoses | Inner/Outer Tie Rods | End Links | Vanos Solenoid |
Driveshaft R&R | Flex Disc | Fan Clutch | Trans Fluid | Diff fluid
Old Tue, Jun-11-2019, 10:07:42 PM   #39
SMG cog light
Your data will very much be appreciated, especially the pressure decay data.
Old Tue, Jun-11-2019, 10:28:51 PM   #40
rovert604
rovert604's Avatar
Default SMG Pump Maintenance/Troubleshooting: Complete Guide
Mine goes from 66 bar to 47 bar in just under 5 minutes. I can’t remember if that was pre Burkhart motor or dying OEM motor. But that shouldn’t affect the accumulator or hydraulic seals anyways.
I know currently with any one shift, the SMG motor is adding pressure with no delay.
--Trevor in 604--
Vancouver, BC, Canada
Discussing SMG Pump Maintenance/Troubleshooting: Complete Guide in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
