Old Tue, May-21-2019, 09:05:41 PM   #21
SMG cog light
Default Re: SMG Pump Maintenance/Troubleshooting: Complete Guide
Originally Posted by Distinct70 View Post
I had the exact same experience. Some cog light coming up just after install and then it’s been perfect ever since.
It seems perfect to the naked eye. You can only know for sure if you do the pressure decay test. If your pressure holds longer that 15 minutes then you have a good system. If your motor is priming every 4 minutes then you have an internal leak. You wont get a cog light you wont feel the difference; but your electric pump motor is prematurely wearing while your car drives fine. I had a member of the forum do a pressure decay test just to verify his pump repair is in good standing and his pressure is holding for over 19 minutes in between primes.
Jump to top SMG cog light is offline   Reply With Quote
Old Wed, May-22-2019, 06:28:38 PM   #22
nightrunner
Reputation: 0 nightrunner is on a distinguished road
I hope someone can help me. So once a month my COG light will come on and will stay on for a day or two then turn off on its own. What is weird is that the car drives fine, shifts normal and I have absolutely no issues while its cog light is on.
My question is, does anyone know why the light would come on but car drive normal?
I want to get his figured out before I end up stuck on the side of the road. Thanks in advance for any help.
STOCK 02 E46 M3 SMG....FOR NOW.
04 ACURA TSX 6SPD..BEATER
Jump to top nightrunner is offline   Reply With Quote
Old Wed, May-22-2019, 07:42:18 PM   #23
SMG cog light
The best thing to do is to get the codes read. Prevent it from getting worse if you can get it fixed at it's earlier stages.
Old Wed, May-22-2019, 09:49:53 PM   #24
nightrunner
I will go get this checked out this weekend. Thank you for the reply.
Old Thu, Jun-06-2019, 06:10:39 PM   #25
2003wmb
Reputation: 0 2003wmb is on a distinguished road
I came across some information on the hydraulic pump actuation, pressure sensor, SMG service functions, longitudinal and lateral acceleration sensors and Clutch position sensor(PLCD)
Jump to top 2003wmb is offline   Reply With Quote
Old Thu, Jun-06-2019, 07:03:25 PM   #26
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
FYI- These two links do not work.
6. Replace electric motor. This is the main component of the smg in my opinion. Since dead motor means no pressure. Motors can last up to 100k+ mi. If they die before that; that is because your accumulator or internal leak caused it to run more often than it should and results in worn commutator. You can remove the outside metal cover and vacuum the carbon dust every year or every other year and inspect the commutator and brushes.
New motor $300-$500 (might be cheaper to get it rebuilt)
https://www.smgsociety.com/product/h...-motor-smg-ii/
7. Hydraulic pressure sensor. (see smg wki for more details) A failed pressure sensor will contribute to erratic pump operation so test this every 2 years or replace it since it is only $89.
https://www.smgsociety.com/product/p...e46-m3-smg-ii/
Old Thu, Jun-06-2019, 07:17:03 PM   #27
SMG cog light
LINKS UPDATED. Thanks.
Old Thu, Jun-06-2019, 07:26:26 PM   #28
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Welcome and Thanks for this thread!
Old Thu, Jun-06-2019, 07:28:11 PM   #29
SMG cog light
Nice. I added this link to the main page.
Old Sat, Jun-08-2019, 05:59:01 PM   #30
2003wmb
SMG cog light
I was looking at the the GOOD_M3 2.0 E46 M3 Build/Journal
and in one of the images it looks like the pressure sensor next to the temp sensor has 3 wires. Is this the pressure sensor or some other sensor? I'm curious because I thought the pressure sensors are a two wire sensor. Maybe newer model?
http://www.m3forum.net/m3forum/showt...=599036&page=5
Discussing SMG Pump Maintenance/Troubleshooting: Complete Guide in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
