Old Sat, May-18-2019, 04:05:08 AM   #31
Blaikenstein
Blaikenstein's Avatar
Reputation: 0 Blaikenstein is on a distinguished road
Default Re: Ross performance s54 harmonic balancer
So how do you plan on quantifying the improvement? S54 damper doesn't fail all that often. Even if it was a 100k mile maintenance item, $560 every 100k isn't that big of a deal vs the same amount of money on a completely unknown product.
I had asked earlier if a dyno would show any changes, not necessary in power but potentially smoothen the delivery. I have a mechanics stethoscope that I can maybe connect to my phone? Or if any of the engine sensors would be able pick anything up. Let me know if you have any ideas.
In regards to it being an unknown part you guys are all in luck. My weekends are better then most peoples vacations. My car sees regular massive elevation changes at high altitudes on extended road trips. Iím honestly an ideal test mule.
Iíll be doing a valve adjustment and some timing work tomorrow so Iíll take a look at the current damper.
Jump to top Blaikenstein is online now   Reply With Quote
Old Sat, May-18-2019, 05:34:33 AM   #32
digger
if there are bad crank harmonics then the valvetrain and crankshaft move relative to each other so it could show on the dyno as its the same as the cam timing being a bit off. i would not trust a chassis dyno though its not repeatable or reliable enough. something that is properly controlled like a instrumented engine dyno would see a difference. realsitically it will be smoothness of the engine at high rpm that all you might notice but that is subjective. my guess is youd need to be above the stock rpm levels to see any quanifiable difference
1996 e36 M3 Evo
Jump to top digger is offline   Reply With Quote
Old Sun, May-19-2019, 04:33:37 AM   #33
Blaikenstein
Stock damper looks fine.
I knocked out a valve adjustment and redid my timing so today wasnít the day to do the damper. Also need to hunt down angle torque wrench
Old Sat, May-25-2019, 02:50:30 AM   #34
Blaikenstein
Default Ross performance s54 harmonic balancer
Laser or perforated embossed logo on the box
Quality control sticker with employee initials
Excellent packaging for the long haul
Pulley and damper are locked in cardboard
It doesnít have 360* timing marks
Old Sat, May-25-2019, 07:00:40 AM   #35
STAATS
STAATS's Avatar
Looks pretty trick hopefully it gives up the goods. Definitely in for long term feedback...
STAATS
Old Thu, Jun-13-2019, 06:07:36 AM   #36
ASAed330
SLOW 330
ASAed330's Avatar
Reputation: 0 ASAed330 is on a distinguished road
Can you check if the BMW TDC tool fits into the harmonic dampener? It didn't fit into the ATI harmonic dampener.
Jump to top ASAed330 is offline   Reply With Quote
Old Thu, Jun-13-2019, 01:12:29 PM   #37
midnighted
Reputation: 0 midnighted is on a distinguished road
Probably a dumb question, but I assume this is for non-SC cars?
Jump to top midnighted is online now   Reply With Quote
Old Thu, Jun-13-2019, 01:37:50 PM   #38
Blaikenstein
Not a dumb question at all, boosted engines need all the help they can get. This unit replaces the stock one and I would think itíll work just fine unless your sc needs a different pulley.
Old Thu, Jun-13-2019, 01:39:44 PM   #39
Blaikenstein
For sure, Iíve been busy with my subframe but Iíll be focused on getting the damper project moving once I recover.
Are you asking if the pin physically fits into the hole? I can check that pretty easily
Old Thu, Jun-13-2019, 01:40:03 PM   #40
midnighted
Yeah thatís why I asked. The ESS kit I have uses a different crankshaft pulley. Wasnít sure if that could be replaced on this dampener.
Discussing Ross performance s54 harmonic balancer in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
