Old Sat, Apr-27-2019, 12:02:47 AM   #31
sapote
Default Re: I think it's the SMG pump...hopefully not.
Solid RED wire connected to relay pin6, jump it directly to the right fender pump post if you like -- don't run motor more than 20 sec or it could overheated.
(pin2 of the relay (RED/Yellow wire) can be the 12V supply to be used if you can verify it has power -- it should normally.)
Old Sat, Apr-27-2019, 04:23:25 AM   #32
fastsoup
Reputation: 0 fastsoup is on a distinguished road
Ahhh...got it. So key on, engine off, connect the solid red wire to red/yellow wire. If I hear the pump prime...this tells me?
Jump to top fastsoup is offline   Reply With Quote
Old Sat, Apr-27-2019, 01:11:00 PM   #33
Texaz3
You are getting power to the motor. If the motor runs and you are STILL can't shift, could be pump, pressure accumulator, etc. But likely both are fine and its the motor.
At your mileage, it is likely the motor is bad regardless, so I would replace it anyway, especially with your problem/symptoms.
Old Sat, Apr-27-2019, 03:19:12 PM   #34
fastsoup
OK bare with me as I don't want to f*ck this up. Red to red/white, hear the motor, hop in the car and try to start car or just see if I can get it into gear?
Old Sat, Apr-27-2019, 03:49:42 PM   #35
terry_s54
Reputation: 0 terry_s54 is on a distinguished road
Greece
Hi bmw family!
Hello from Greece.
I just put a new smg pump motor from smgsociety.
I order the product to slove the problems-error codes they say on their page that eliminates them.
We put the motor and for surprise us the problems shown at the first ride.
Untit it wont engage gears anymore.I got diagnosis my car and i have the error codes 53,56,57
I have changed
1. new gps sensor 2.new slave cylinder 3.new clutch kit 4.new accumulator 5.new fluid 6.new temperature sensor.
NO leaks anyware. complete all SMG adaptions.
And for last part we put the motor he send to us witch is very weak and smaler testing on the bench with 12v supplier comparing my old motor .The car drives much better with the old motor.
I paid 375€ for nothing.That product is useless.
Jump to top terry_s54 is offline   Reply With Quote
Old Sat, Apr-27-2019, 08:00:38 PM   #36
SMG cog light
Originally Posted by terry_s54 View Post
Hi bmw family!
Hello from Greece.
I have changed
CODE:
53 (0x35) low level of pressure reached HE
hydraulic pump relay faulty
electric motor faulty
pressure sensor faulty
leakage in hydraulic system
short-circuit
open circuit
SOLUTIONS:
replace hydraulic pump relay
replace electric motor
replace pressure sensor
fix the leak
check wiring harness and plug connector
CODE:
56 (0x38) Switching-on time of hydraulic unit
preload pressure of the accumulator to low
leakage in hydraulic system during high temperatures
external leakage
hydraulic oil filling level to low
air in the hydraulic system
temperature sensor faulty
short-circuit
open circuit
SOLUTIONS:
replace accumulator
switch to HIGH Performance hydraulic oil
fix the leak
refill hydraulic oil
bleeding
replace temperature sensor
check wiring harness and plug connectors
CODE:
57 (0x39) Misuse of hydraulic unit
external leakage
short-circuit
open circuit
SOLUTIONS:
replace accumulator
fix the leak
bleeding
Jump to top SMG cog light is offline   Reply With Quote
Old Sun, Apr-28-2019, 01:33:12 AM   #37
DRockM3
Reputation: 0 DRockM3 is on a distinguished road
Hey fastsoup, I'm the one with the Burkhart kit locally in Van. PM me here or email me if you decide to go that route. I also have extra salmon relays and a few other parts if you need to borrow for diagnosis.
- D
Jump to top DRockM3 is offline   Reply With Quote
Old Sun, Apr-28-2019, 04:29:55 PM   #38
fastsoup
- D
Nice...appreciate that. I went and bought a salmon relay yesterday from the dealer ($27) and wiring to jump the red to red/white to test the motor, went to the shop and he parked my car inside
I guess I can't complain...better inside than outside all weekend. Will have to try tomorrow morning. I'll be in touch.
Old Sun, Apr-28-2019, 05:52:26 PM   #39
Aeko
Aeko's Avatar
Reputation: 0 Aeko is on a distinguished road
Hi bmw family!
Hello from Greece.
I have changed
The problem sounds like you are throwing parts at it without doing a thorough diagnosis of the issue. Did you start with checking codes? Did you check and replace the salmon relay?
If you wanna make REAL donuts, run Crisco in your diff.
Jump to top Aeko is online now   Reply With Quote
Old Mon, Apr-29-2019, 12:02:49 PM   #40
terry_s54
Greece
Yes my friend.At start before the new smg society motor i cad codes 56 and 177 during high temperatures. After the new motor install i have 53, 56,57, 177 codes and no shifting at all. I changed and the relay.
Discussing I think it's the SMG pump...hopefully not. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
