Old Fri, Jun-07-2019, 03:40:05 AM   #81
Race M3
They don't think it be like it is, but it do.
Race M3's Avatar
Reputation: 0 Race M3 is on a distinguished road
Default Re: Warm Start Problem
Any updates?
Jump to top Race M3 is offline   Reply With Quote
Old Fri, Jun-07-2019, 02:31:00 PM   #82
wolffbimmer
Reputation: 0 wolffbimmer is on a distinguished road
I got the fuel pump put in yesterday. I went over my GF's after and it sat for a good 5-6 hours while it was hot out and it started right up no issue. It almost always did it when I left there. So far so good but I'll know more during the next week of leaving work and how it behaves.
Jump to top wolffbimmer is offline   Reply With Quote
Old Mon, Jun-10-2019, 02:56:09 PM   #83
IggyP
Reputation: 0 IggyP is on a distinguished road
What did you do at your girlfriends house for 5-6 hours ehh ??
jk, wish everything works out for you so I could get my car fixed also
Jump to top IggyP is offline   Reply With Quote
Old Tue, Jun-11-2019, 04:06:46 AM   #84
arkow
Reputation: 0 arkow is on a distinguished road
Same here, its driving me crazy, I read so much about this issue and found out there are different solutions that fixed this problem..I have 2 codes that I didnt think were related but now I might have coolant temp sensor that's bad, the code is p0128- coolant thermostat temp below.... I replaced water pump and thermostat (OEM) so I know it's not that, it must be the coolant temp sensor which may be causing this issue.
Jump to top arkow is offline   Reply With Quote
Old Tue, Jun-11-2019, 04:11:53 AM   #85
mrgizmo04
mrgizmo04's Avatar
Yes, very likely
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Thu, Jun-13-2019, 02:38:55 PM   #86
IggyP
I reread the entire thread and it sounds like I will just take the hit and replace the fuel pump.
Old Thu, Jun-13-2019, 03:10:03 PM   #87
wolffbimmer
Mine has still been fine in several situations where it would have normally done the no start. I'll report back if it happens but so far it's been fine. The cheapest place to get it is on Ebay. It's 383 or so shipped. Genuine bmw and comes with the gasket. Be very careful putting the new pump through the new gasket, if you get it pinched you'll have fuel smell and leak when full. Also make sure your tank is at least at 1/4 tank or lower.
Old Thu, Jun-13-2019, 06:04:46 PM   #88
Toxic0n
Glad that it sounds like the problem is now solved. Zimmie called it in post #2 haha.
Ground Control, Mason Engineering, HRE, ACS, Rogue Engineering
Jump to top Toxic0n is offline   Reply With Quote
Old Thu, Jun-13-2019, 06:07:45 PM   #89
wolffbimmer
And as I said KUDOS to him. I really didn't think it would cause the issue.
Old Thu, Jun-13-2019, 06:25:49 PM   #90
IggyP
Well I'm next, will order new fuel pump next week. Thank you Wolffbimmer and everyone else!
Discussing Warm Start Problem in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
