Old Sat, Apr-13-2019, 10:18:01 PM   #31
Drewster
Drewster's Avatar
Default Re: At my wits end, misfire issue, OBDII monitors incomplete...
Originally Posted by alwaysbored786 View Post
I talked to the shop, and they think its a fuel pump.
I looked at my receipts and I bought my walbro off amazon from an unauthorized walbro seller, So i think my pump is fake, potentially giving fueling issues.
I bought the radium kit with a new walbro, will put that in once its here.
So you're cool buying fuel pumps willy nilly, but not swapping sensors?
Old Fri, Apr-19-2019, 01:50:31 PM   #32
alwaysbored786
Reputation: 0 alwaysbored786 is on a distinguished road
Traced the O2's with wiring pulled and all, they are in correct locations.
In other good news....
My car decided to behave for 2 days, CEL randomly cleared itself, and the evap monitor decided to ready up, meaning I could pass emissions, unfortunately, this happened at night, no stations open in the evenings. The next day after work, I went to GT Peace (my local shop), drove right up, left the car on, asked them to take it to do emissions leaving the car on.
They took it, came back....good news and bad news, bad news...CEL came on and she started misfiring on all cylinders....good news, IT HAPPENED AFTER IT PASSED EMISSIONS! wooo!
Got my new registration stickers and im legally on the road again. Fuel pump arriving Wednesday, will be changing it something next week. Got some mineral oil for my smoke tester, and I will be testing that soon.
Question:
Is it normal behavior for the engine to have a very slight idle bump (almost imperceivable) when you depress the clutch? Makes me think vacuum leak is somewhere perhaps.
Current Stable:
2006 ZCP M3, Interlagos Blue/Black, 6MT
1998 M3 Coupe, Black/Black, 5MT, 28K miles
1996 M3 Coupe, Techno Violet/Hurricane, 5MT
Gone but not fogotten:
1997 M3 Coupe Techno Violet/Mulberry 5MT, 2004 Noble M12 GTO 3R 6MT, 1996 XJ Red/Tan AT, 1995 M3 Coupe Silver 5MT, 1988 325e Black/Black 5MT, 2002 330ci Blue/Grey 5MT, 2003 ZHP Sedan Black/Black 6MT, 2003 M3 Imola Red/Black 6MT
Jump to top alwaysbored786 is offline   Reply With Quote
Old Fri, Apr-19-2019, 03:38:52 PM   #33
Kenny167
Reputation: 0 Kenny167 is on a distinguished road
Question:
I believe this is pretty normal, seeing as you're changing the rotating mass and therefore the load on the engine by releasing the clutch, transmission's input shaft, and half shaft from the engine.
I'm really curious about your misfiring issues. Have you checked the vacuum line for your fuel pressure regulator? While doing my manual swap I discovered that mine was just sorta set on the hose, there wasn't any kind of secure attachment. Probably explains the exceptionally random stalling I had when in idle and hitting bumps...
Edit: Didn't read all posts. Looking back throught this, I'd say that the issue has to lie with the tune. IIRC, there was 2 different kinds of setups with O2 sensors on the M3, the headers with cats in them, and then the setup with cats in the section 2 of the exhaust. Is it possible that the tuner enabled one or the other and it's incorrect? I know there's a different fuel routine for the cat warmup procedure, which I believe runs a richer mixture while the cats are coming up to temp. Could this be the culprit?
Here you can see the different options, including the cat protection (what I was referring to), and the "rear O2's", again what I was talking about. Maybe this stuff is worth checking?
https://imgur.com/I5vWvjw
Jump to top Kenny167 is offline   Reply With Quote
Old Tue, Apr-23-2019, 11:22:22 PM   #34
alwaysbored786
Unsure what TTFS enabled when he did my tune, i may have to go back to him again to double check.
I just did a smoke test, found no leaks, replaced the fuel pump with radium kit unit, genuine walbro gss342, still misfires.
about to light this damn car on fire...
Current Stable:
Old Wed, Apr-24-2019, 02:11:05 AM   #35
CSLM3Wannabi
Get a rental and let me have it for a day man. Iím sure I can help you out.
2005 BMW M3 ZCP Nardo Gray | ESS VT2-550 | Dinan Throttle Bodies | 6MT Swap | Active Autowerkes Headers + Section 1 w/ 100 cells | Miltek Section 2 and 3 | KW V2 w/ GC camber plates and Eibach Front and Rear Swaybars | Porsche 996 BBK upgrade w/ OEM ZCP rotors | Umnitza V4 Angel Eyes | Euro bumper w/ Morimoto led fogs | 1 piece Carbon Lip | VIS XTS Full carbon hood | SCZA Carbon Fiber CSL Trunk | Carbon Fiber CSL Diffuser | Square ZCP Wheels |
Old Wed, May-01-2019, 01:46:32 PM   #36
alwaysbored786
Im ready to do this, ive given it a good faith effort, and stumped some mechanics already. Lmk what a good time is to drop it off, duly appreciate the help!
Current Stable:
Old Tue, May-14-2019, 04:58:25 PM   #37
alwaysbored786
Update:
CSLM3Wannabi very graciously and kindly was able to taken my car in for a couple of days to use some of his guru diagnostic technician powers to figure out wtf is wrong with my car.
Smoke test, vanos test, all sorts of tests, cleaning TB's, cleaning IACV, new vacuum hoses from FPR, still misfired. Car idles and drives WAYYYY smoother after he cleaned my TB's and IACV, night and day difference, so happy this was done! However, car would still do the startup misfire.
He tried a spare DME laying around with a factory tune mapped to my car, zero misfires. It was tested over a period of 4 days and multiple (read: 30+) startups, never misfired at all, we believe it is the tune. Once my original DME went back in with the tune from TTFS, it had the same startup misfire right away.
TTFS is having me check the DME circuit board for leaking capacitors as a last check to see if that is potentially causing the issues, so i'll be checking that. If not, i will be going back to TTFS to have them fix my tuning issues.
Again, huge shout out to CSLM3Wannabi, without his help, i'd still be twiddling my thumbs trying to figure this damn this out.
Current Stable:
Old Tue, May-14-2019, 05:17:20 PM   #38
Kenny167
Update:
Hey look I was on the right track
I don't think it's leaking capacitors, because why would it change when the engine warmed up? I guess the idle is controlled differently but I doubt that's the issue.
The reason I say that is because the oxygen monitor shows incomplete, which tells me that in one way or another the ECU is getting bad info, or it's getting info and interpreting it as bad. This is likely due to the coding of the ECU (not the tune, but coding), which would explain why it worked with the other ECU.
If I were you, I'd check the different parameters I mentioned previously (mainly the cat protection and SAP cat heating) and see what's different between your ECU and the one you dropped in. If they're different, fix it, and if not, then continue the search...
Old Tue, May-14-2019, 09:45:12 PM   #39
CSLM3Wannabi
You are more than likely correct, sir. Being that there are no issues once the warmup cycle has finished it is most likely a coding issue. However, the coding, I assume was done along with the tuning, leaving the tuner responsible for the repair. Last thing I want to do is mess with someone elseís work. Just happy I could be of assistance.
Old Tue, May-14-2019, 10:01:17 PM   #40
Care to explain what can be ďcodedĒ on the mss54 rather than tuned? Iím quite certain thereís no distinction of that sort on this dme.
Discussing At my wits end, misfire issue, OBDII monitors incomplete... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
