Old Thu, Apr-04-2019, 04:54:03 PM   #21
alwaysbored786
Reputation: 0 alwaysbored786 is on a distinguished road
Default Re: At my wits end, misfire issue, OBDII monitors incomplete...
Originally Posted by Steve M3 View Post
Which tune do you have? If it's the OE CSL tune for the box, I've heard that it has problems showing emissions readiness on some state computers.
Or is it simply not showing ready because you keep clearing the misfire CEL and you don't have time to go through a drive cycle before it comes back?
I have a custom tune from TTFS. I've driven only 15 miles since i cleared the codes, but all the other monitors are ready except evap and O2. I'll keep driving it to see if I can get them to ready up and if the misfire happens again.
Current Stable:
2006 ZCP M3, Interlagos Blue/Black, 6MT
1998 M3 Coupe, Black/Black, 5MT, 28K miles
1996 M3 Coupe, Techno Violet/Hurricane, 5MT
Gone but not fogotten:
1997 M3 Coupe Techno Violet/Mulberry 5MT, 2004 Noble M12 GTO 3R 6MT, 1996 XJ Red/Tan AT, 1995 M3 Coupe Silver 5MT, 1988 325e Black/Black 5MT, 2002 330ci Blue/Grey 5MT, 2003 ZHP Sedan Black/Black 6MT, 2003 M3 Imola Red/Black 6MT
Jump to top alwaysbored786 is offline   Reply With Quote
Old Sun, Apr-07-2019, 02:01:03 AM   #22
CSLM3Wannabi
Update?
2005 BMW M3 ZCP Nardo Gray | ESS VT2-550 | Dinan Throttle Bodies | 6MT Swap | Active Autowerkes Headers + Section 1 w/ 100 cells | Miltek Section 2 and 3 | KW V2 w/ GC camber plates and Eibach Front and Rear Swaybars | Porsche 996 BBK upgrade w/ OEM ZCP rotors | Umnitza V4 Angel Eyes | Euro bumper w/ Morimoto led fogs | 1 piece Carbon Lip | VIS XTS Full carbon hood | SCZA Carbon Fiber CSL Trunk | Carbon Fiber CSL Diffuser | Square ZCP Wheels |
Old Mon, Apr-08-2019, 12:53:29 PM   #23
alwaysbored786
update for everyone, i didnt have time to swap O2's, and im pretty confident they are in the correct spot, so im going to try other items before swapping them willy nilly.
I have NOT had any misfires since replacing FPR and Filter, HOWEVER, Evap and O2 monitors are still showing incomplete. I have done 2-3 drive cycles over 50 miles...i may be doing the drive cycle incorrectly though, hence them not readying up?
I did take the car for a drive and these are the trims:
for trims, on cold start:
- Short term FT 1: -15.6
- Short term FT 2: -25.5
These numbers bounce around between -12 to -18 for FT1, and -17 to -29 on FT 2 while driving and warmed up (at operating temp for oil & coolant)
While driving, i was checking FT 2, it went anywhere from +4 to -26, When idling Hot, the Short term FT's are the same as when idling cold. Long term trims on both banks remain +1.6.
O2 sensors on all banks are running proper voltage going between 0.4 to .89 volts.
I think I may actually be able to hear a vacuum leak near the fuel rail, gonna get a smoke tester and smoke test this ***** out. Need one for the E36 as well, so worthy purchase.
Current Stable:
Old Tue, Apr-09-2019, 06:58:04 PM   #24
alwaysbored786
I just changed spark plugs, and i noticed all of them have a little oil on the threads, the terminal and components are oil free. I did notice Cyl 4 & 6 coil packs had dirty connections on the inside where it meets the plug. I cleaned it out as best as I could. As for the plugs, its clear every cyl is running rich.
I did notice some weird fuel thing when revving to 4.5k (once at operating temp), not sure if this is normal or not, video shows what im talking about. Its a video of live data.
I noticed misfiring for maybe 10 sections after the car was started for 1 min.
short term Fuel trims are still rich
https://photos.app.goo.gl/GBGf7YZKXzHqVaaX6
free gif upload
Current Stable:
Old Wed, Apr-10-2019, 12:06:43 AM   #25
mrgizmo04
mrgizmo04's Avatar
free gif upload
You need to refresh the coils, that thing in the picture looks fried.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Wed, Apr-10-2019, 02:10:44 AM   #26
alwaysbored786
at 128k miles, i might as well. Which coil packs do you think I should go with,
Bosch, Eldor, Delphi?
Current Stable:
Old Wed, Apr-10-2019, 02:13:15 AM   #27
mrgizmo04
mrgizmo04's Avatar
All equal. Get from FCP euro and then have lifetime warranty and can replace for free.
'05 M3 6MT coupe
Old Wed, Apr-10-2019, 02:16:17 AM   #28
alwaysbored786
Anyone use these coils? FCP says they dont fit e46 m3, but seems like plenty of folk used them
https://www.fcpeuro.com/products/bmw...sch-0221504470
Current Stable:
Old Wed, Apr-10-2019, 02:56:56 AM   #29
mrgizmo04
mrgizmo04's Avatar
Not sure about those specifically, but I know bigjae uses coils from 330 which are much cheaper than m3, maybe he can chime in.
'05 M3 6MT coupe
Old Sat, Apr-13-2019, 07:42:34 PM   #30
alwaysbored786
I talked to the shop, and they think its a fuel pump.
I looked at my receipts and I bought my walbro off amazon from an unauthorized walbro seller, So i think my pump is fake, potentially giving fueling issues.
I bought the radium kit with a new walbro, will put that in once its here.
Current Stable:
Discussing At my wits end, misfire issue, OBDII monitors incomplete... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
