Old Thu, May-23-2019, 07:57:00 PM   #51
ameretta
ameretta's Avatar
Reputation: 0 ameretta is on a distinguished road
United Kingdom
Default Re: SMG Shift Knob Design
I'm in, no pads, the machining marks look perfect.
Jump to top ameretta is offline   Reply With Quote
Old Fri, May-24-2019, 04:32:03 PM   #52
Will ZCPM3
Sparty On
Will ZCPM3's Avatar
Reputation: 0 Will ZCPM3 is on a distinguished road
Hey Guys,
Definitely working on a lower ring as well. Maybe paddles will be next. I should hopefully have another update in about a week or so.
Instagram
Jump to top Will ZCPM3 is offline   Reply With Quote
Old Fri, May-24-2019, 09:51:42 PM   #53
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Originally Posted by Will ZCPM3 View Post
Hey Guys,
Love it!
It might be interesting if you used the same radius that you used on the bulbous top part of the knob, and used that radius (but inverted) to create a scalloped sort of chamfer around the lower ring. (hopefully that makes sense).
IG: DrM3anM3
Mods: Genuine OE CSL Bumper, Both Karbonius and Streamline CSL Airboxes, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized HJS Race Catted section 1, SS 2.5" Twin-Piped Oversized Custom section 2, Custom Oversized Supersprint muffler, Catcam's Billet 280/272 cams, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, Brembo GT6 (front) + GT4 (rear) BBK, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune, SMG Pump Relocated.
OE CSL Bootlids, Supersprint Headers/Exhaust thread, New Supersprint Oversized Twin-Piped Section 2, HTE Tuning Group-Buy OE CSL Wheel
Old Wed, Jun-12-2019, 10:47:48 PM   #54
Will ZCPM3
Sparty On
Will ZCPM3's Avatar
Another quick update. I received the anodized samples back. It is a clear hard anodization. It does change the color a bit, but tool marks are still visible. It will really help prevent scratching and scuffing. The last image is a prototype of the gator ring, so it is a bit rough looking.
Instagram
Old Wed, Jun-12-2019, 11:19:41 PM   #55
kokgo20
kokgo20's Avatar
Would love to see SMG peddles design like this
Build thread---------- INSTAGRAM ------------ROTREX REBUILD-------------Now offering custom digital gauges
2004 SMG PY/BLK - 600 TCKline - CPI Headers & resonated Sec1- Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - SDW monoball RTABs - AKG subframe bushings - Multi color AEs - FR-X 3.0 Projectors - Smoked Side markers - Euro bumper - V1 with hard wire & Stealth one - M Track Mod - ZCP steering rack - Dual LI - CSL Style diffuser - SCZA Exhaust - E9x Door handle LED retrofit - SCZA CSL bootlid - VEI systems custom air vent A/F & boost gauge - VEI custom air vent Water temp & oil pressure guage- Active Prima plus + HTE performance tune - Custome fab intercooler - Mishimoto Radiator & Oil cooler - H&R front Sway - UUC camber arms - keyless & push to start system - clear bra - interiors red stitching contrast - Apex PS7s - 16" Spal fan
Old Thu, Aug-01-2019, 10:33:20 PM   #56
Dr M3an M3
Dr M3an M3's Avatar
^Same here.
Just received a sample of the first batch of these to test out. Formal review to come, but initial thoughts -- This shift knob is VERY well designed and manufactured. Fit and finish is phenomenal. Weight feels fantastic. Looks OE(+), but feels much higher quality than the stock knob. Comfortable too, no sharp edges, the texture feels great in the hands (I am a very tactile person) and without any sticky gel that could leak from the inserts like on the stock knob. Honestly blown away. After the first drive, It would be hard to go back to stock without feeling like I am putting a cheap plastic knob on in its place. Installation is as easy as it gets. It comes with 2 set screws (well thought out design), but the tolerance is so tight that they were not needed in my case. There is zero cross-movement or wiggle. If BMW engineered the VANOS tabs with this exact of a fitment tolerance, we would have never had VANOS tab shearing issues. Super impressed.
Pictures and full review after in a couple weeks. Initial impressions though, totally nailed it.
IG: DrM3anM3
Old Tue, Aug-06-2019, 09:08:46 PM   #57
ameretta
ameretta's Avatar
United Kingdom
Please let me know when the knob is available, the knob in my CSL is in desperate need of replacement, but i'll hold off for this one.
Old Tue, Aug-06-2019, 09:27:23 PM   #58
LemonOne
Reputation: 0 LemonOne is on a distinguished road
I wish someone made a shift knob like this with illuminated ///M logo (like the classic BMW manual shift knob ZHP)
Jump to top LemonOne is offline   Reply With Quote
Old Tue, Aug-06-2019, 09:34:35 PM   #59
Sandeep1212
Sandeep1212's Avatar
Reputation: 0 Sandeep1212 is on a distinguished road
You can just put a manual knob and boot on. It has the same connection point. I was thinking about doing that just because I hate how the smg knob looks. Also not a fan of this one here.
2003.5 TIAG Black 6MT Gone
2003.5 Carbon Black Laguna Seca Blue SMG Current
Supersprint V1/Supersprint straight pipe sec 1/ Supersprint X-pipe/OEM Muffler/Eventuri Intake/TCKline Single Adjustable 500lbs Front 600lbs Rear/TCKline Camber Plates/Turner Adjustable Rear Control Arm/Turner Monoball RTABs/Turner Monoball FCABS/ Whiteline Front Sway / Brembo GT 6 piston Front 4 Piston Rear/OEM CSL Trunk/ CSL rep 1 piece lip
Jump to top Sandeep1212 is offline   Reply With Quote
Old Tue, Aug-06-2019, 09:44:53 PM   #60
Dr M3an M3
Dr M3an M3's Avatar
It would be cool if the top engraving was illuminated on the new SMG knob that the OP designed, but honestly....He hit this out of the park, as is. I still cannot get over how well this knob feels tactilely. Every time I get in my car, forgetting the knob has been changed, I let out a gasp of "oh my god" when my hand grabs the shifter to put into neutral to start the car. The feel has totally ruined the stock paddles too; which now feel cheap and flexible. Hoping a set of paddles can accompany this new shifter. I can never go back to my stock shifter. Previous to this, the Storm Motorwerks one was the only viable option that I liked for SMG -- This one is better (IHMO).
Also, it's great that there isn't any worry of white sticky gel leaking out (like you have with the inserts in the stock knob). Thus far, in 105+ degree heat, it hasn't gotten too hot to where it couldn't be touched either. Honestly, I fucking love this shifter. Fitment and finish is better than the OE knob.
The charcoal grey one I received was supposed to be bright silver (to match the brushed aluminum trim I have)...but the charcoal has since grown on me and matches the steering wheel trim and SMG surrounding trim basically perfectly. Would look stellar in an Imola interior car with dark shadow trim.
IG: DrM3anM3
Discussing SMG Shift Knob Design in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
