Old Wed, Mar-06-2019, 04:13:36 PM   #41
Laguna01///M3
PapaSmurf
Laguna01///M3's Avatar
Reputation: 0 Laguna01///M3 is on a distinguished road
Default E46 M3: Favorite Wheel Setups
Originally Posted by Speed Monkey View Post
Whuuut? No HRE love on this Forum? Alrighty then, here is my sled riding on some OG 547Rs - hah.
My newly refinished OG 540s. Waiting for weather to clear to mount them up.
Work performed by Mark Perrault in CAli. (They're mocked up in this iphone shot, hence no bolts)
Photo @ Khan_Art
IG @ WBucco
Jump to top Laguna01///M3 is online now   Reply With Quote
Old Wed, Mar-06-2019, 04:24:27 PM   #42
gearhead55
gearhead55's Avatar
Reputation: 0 gearhead55 is on a distinguished road
Default Re: E46 M3: Favorite Wheel Setups
Originally Posted by . View Post
I think I've decided on 350/750. I'd put them on my current PSS9's temporarily till I can have FCM built a separate set of dampers and swap them over. I've been telling myself I want I get rid of my current wheels asap since I bought the car and just keep putting in on the back burner due to suspension limitations not allowing me to run a 10" wheel up front.
Nice. Iím going with 448/840 with my FCM build. I run the 18x10 265 up front with PSS9s and no clearance issues though, Iím surprised youíre running into a problem with that.
Originally Posted by Serious View Post
nah this one dude on the forum said it was all good. I'm sure he knows what he's talking about.
Jump to top gearhead55 is offline   Reply With Quote
Old Wed, Mar-06-2019, 04:51:59 PM   #43
.'s Avatar
Reputation: 0 . is on a distinguished road
Originally Posted by gearhead55 View Post
Nice. I’m going with 448/840 with my FCM build. I run the 18x10 265 up front with PSS9s and no clearance issues though, I’m surprised you’re running into a problem with that.
I've never tried its just something I've read would be a problem a while back. ET25? Also curious on how much camber I assume you're running stock top hats if you're using the bilstein springs?
2001 E46 M3 - Slicktop Manual Coupe - Alpine White on Imola Red
Engine: Karbonius CSL airbox, Lang Racing stage 2.5 head, Schrick 288/280 cams & followers, Lang Racing rod journal widening kit w/ CP 12:1 87.5mm pistons & Carrillo rods, Kassel CSL DME & MAP conversion, 36lb injectors, Paul Claude tune, APE Flex fuel kit, TMS Power Pulleys, SS V1 stepped headers & catless section 1, SS 2.5Ē twin-piped resonated section 2, SGT scza section 3.
Drivetrain: DKM Stage 2 Clutch, RTD V2 mini shifter, RE trans mounts, Motorsport 4.10 R&P, Revshift 80A diff bushings.
Suspension/Brakes: Bilstein PSS9's, RE RSM's, UUC sway bars, BW camber arms, TMS monoball RTABs, ZCP rotors, BW solid caliper guide bushings, PFC 08's, Motorsport Hardware 75mm stud kit.
Interior: Cobra Nogaro seats, BMW Performance shift knob/e-brake/pedals, OE alcantara boots, mason clutch pedal, Xtrons 9" headunit w/ carplay
IG: Zach_e46M
Jump to top . is online now   Reply With Quote
Old Wed, Mar-06-2019, 04:56:16 PM   #44
gearhead55
gearhead55's Avatar
Et 25, no spacers. -3.5 ish camber, GC street plates. The wheels fit and I’ve tried quite a few 265 width tires with no problems.
Old Wed, Mar-06-2019, 04:59:25 PM   #45
.'s Avatar
Et 25, no spacers. -3.5 ish camber, GC street plates. The wheels fit and Iíve tried quite a few 265 width tires with no problems.
Ah ok I guess my only real need is camber plates then not springs at least for now. Then I can finally get rid of these ugly black VMR's
IG: Zach_e46M
Old Wed, Mar-06-2019, 05:09:04 PM   #46
Are we talking about street setups or track setups?
I have zero desire for an et25 on the street (or anything wider than a 9" wheel up front).
Old Wed, Mar-06-2019, 05:20:38 PM   #47
.'s Avatar
Preferably I'd like to have a separate setup for each eventually. But other projects keep side tracking me. When I get to it the 10" et25 squared will be track and likely a staggered setup for street.
IG: Zach_e46M
Old Wed, Mar-06-2019, 05:28:19 PM   #48
gearhead55
gearhead55's Avatar
I have no problem with a 265 up front on the street (on either 9.5 or 10in wheels). PSSs donít even tramline that much.
Old Wed, Mar-06-2019, 06:43:04 PM   #49
Good
@GOOD_M3
Good's Avatar
EXTERIORV÷RSTEINER CSL BUMPER | MILE END CSL 1X1 DIFFUSER & FLIPPERS
ENGINE ▌TUNED BY PAUL-CLAUDE | KARBONIUS CSL AIRBOX (ALPHA N), OE SNORKEL + CSL DUCTING | VANOS BEISAN LOCKDOWN
TRANSMISSION ▌SMG HCU RELOCATED & REBUILT W/ NEW SEALS, ACCUMULATOR & BURKHART KIT
SUSPENSIONTURNER MOTORSPORT 30MM FRONT SWAY BAR | KW V3 COILOVERS | ROGUE RSM | GROUNDCONTROL STREET CAMBER PLATES | SDW RTABS
EXHAUSTSUPERSPRINT EXHAUST ~ OVERSIZED STEPPED V1 HEADERS | RACE CATTED SEC 1 | STOCK2 | SPORT (GEN 2) SEC 3
BRAKES ▌CSL/ZCP ROTORS | PORSCHE 996 BREMBO CALIPERS | SS LINES
WHEELS ▌OEM CSL BBS 19" | 75MM ECS/TMS WHEEL STUDS
Instagram: https://www.instagram.com/good_m3/?hl=en
Youtube: https://www.youtube.com/channel/UCOW...3N7QDfZ5NSzriA
Journal: http://www.m3forum.net/m3forum/showthread.php?t=599036
Old Wed, Mar-06-2019, 08:54:31 PM   #50
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Originally Posted by Good View Post
Lovely....
It's really hard to beat CSL wheels. Just looks perfect.
Anyone out there know if OE CSL wheels will fit properly with Brembo GT6 (6pot fronts) and GT4 (4pot rears) with Brembo's 355 type 3 rotors? Would prefer to run without spacers, but I think they become necessary with these wheels and BBK. Trying to decide if I want to go the OE CSL wheel route or the 18" Arc-8 route once my brakes are in.
EDIT: Looks like the OE CSL wheels work just fine (I assume with spacers):
IG: DrM3anM3
Mods: Genuine OE CSL Bumper, Both Karbonius and Streamline CSL Airboxes, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized HJS Race Catted section 1, SS 2.5" Twin-Piped Oversized Custom section 2, Custom Oversized Supersprint muffler, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, Brembo GT6 (front) + GT4 (rear) BBK, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune, SMG Pump Relocated.
Camshaft Group-Buy, OE CSL Bootlids, Supersprint Headers/Exhaust thread, New Supersprint Oversized Twin-Piped Section 2
Discussing E46 M3: Favorite Wheel Setups in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
