Old Tue, Feb-26-2019, 04:16:34 PM   #21
bryce2113
Reputation: 0 bryce2113 is on a distinguished road
Default Re: Directory of 3D parts to DIY 3D print/machine
Here's my current - and I can't emphasize this enough - work in progress.
Shape is pretty much there, mounting may change
https://www.thingiverse.com/thing:3453651
Very helpful, thanks. Is this file just for the passenger side? I'll give it a go and report back.
I'm still contemplating how I want to mount the ducts. I like Obi's version of mounting to the frame/crash support for easy bumper removal. I'm also toying with making a version that replaces the fog lights. Essentially a duct that clips into the factory mounts for the fog lights.
Jump to top bryce2113 is offline   Reply With Quote
Old Tue, Feb-26-2019, 05:57:50 PM   #22
Drewster
Drewster's Avatar
If you flip it in your slicer it *should* fit the driver's side, but that file is for the passenger (US).
I was messing with it last night, and the top *barely* clears the bumper mount/ frame, but the mounting holes are probably a bit too far back.
I'm going to try moving the mounts forward about 4cm which should make it easy to have a bracket coming off the stock duct mount, but depending on how picky you are it might be rivet-able to the bumper as-is. If you print it, I'm curious to see your feedback since the fitment is probably slightly different on each car.
Old Thu, Feb-28-2019, 08:23:23 PM   #23
zerotosixty
Search Nazi
zerotosixty's Avatar
Reputation: 0 zerotosixty is on a distinguished road
Any designs better then using tennis balls?
Lords of M3Forum official member
ZeroToSixty's car journal
Originally Posted by Why m3 View Post
Not everybody Is into tracking because you guys other to each of their own
Originally Posted by cowboyM3 View Post
Again, just like several of you have proved and myself: it's going to be nothing but a $hitshow until our science is to the height to which we can prove something's there and the time it gets there.
Until then, we must prevent these mistaken pregnancies in the first place
Jump to top zerotosixty is offline   Reply With Quote
Old Thu, Feb-28-2019, 09:31:50 PM   #24
Drewster
Drewster's Avatar
Old Wed, Mar-20-2019, 04:59:08 PM   #25
aznbo187
XIII
aznbo187's Avatar
Going to give this a try! Are the mounting holes the circular protrusions?
Any adjustments you think it might need? I can make those before I try the first print.
no.13
Old Thu, Mar-21-2019, 03:26:55 PM   #26
Drewster
Drewster's Avatar
Just the mounting adjustments I mentioned! Some support might not hurt under the large ramp to the outlet, if your printer can swing it
Discussing Directory of 3D parts to DIY 3D print/machine in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
