Old Thu, Jun-13-2019, 12:46:24 AM   #391
t3ddftw
The BlueBus Guy
t3ddftw's Avatar
Reputation: 0 t3ddftw is on a distinguished road
Default Re: Interest in a fully integrated A2DP Bluetooth solution?
Originally Posted by rjc32000 View Post
Any update on release date? I just signed up and look forward to this product.
I'm hesitant to give an exact date right now because I've had to keep pushing it back for a multitude of reasons (Sorry, everyone!)
Here are the time tables I'm hoping to stick to:
1 Week: Complete the Rev C layout & send it off to the fab house
+ 1 Week: Build and send out test modules to the beta users after validating the design myself
+ 2 Weeks: Ensure no hardware bugs & begin taking actual orders from pre-order users
+3 - 4 weeks: Production manufacturing and assembly
I currently have about 250 pre-orders, so I will be hiring someone to do the final assembly and testing, since I have a full time job to attend to. I expect to ship at least 100 units per week once they all come in.
2006 M3 ZCP 6MT Interlagos Blue on Cinnamon interior
Mods
Engine: Full Beisan Systems VANOS rebuild
Transmission: CDV Delete
Exterior: Smoked Corners | Black Side & Kidney Grills | Painted Reflectors
My Build/OCD thread
I made a Bluetooth module for our cars!
Jump to top t3ddftw is offline   Reply With Quote
Old Thu, Jun-13-2019, 01:11:50 PM   #392
How does one get on the pre order list?
Old Thu, Jun-13-2019, 01:43:32 PM   #393
GeorgeH
BMW Fan
Reputation: 0 GeorgeH is on a distinguished road
ditto
Current Garage... '00 R11S, '09 HP2S, '12 R12GSA, '00 Gray 332iT, '00 Black 323iT (wife's), '02 Alpine 325iT (Eileen, Track Wagon), '02 Japan Rot 325iT, '04 Gray 325iT, '04 IR ZHP Sedan
Instagram @ HillPerformanceBimmers
Email to George@HillPerformance.com
Jump to top GeorgeH is online now   Reply With Quote
Old Fri, Jun-14-2019, 02:14:10 PM   #394
krambjas
Reputation: 0 krambjas is on a distinguished road
Sorry if you've answered this already. I know you changed things a bit to use the OEM BMW mic. Does this hook up to and use the OEM Bluetooth antenna module that sits in the back of the between seats console?
Jump to top krambjas is offline   Reply With Quote
Old Fri, Jun-14-2019, 02:56:44 PM   #395
t3ddftw
The BlueBus Guy
t3ddftw's Avatar
Originally Posted by GeorgeH View Post
ditto
I could have sworn ZiMMie answered you guys, but I'm not seeing it. https://www.bluebus.dev has the pre-order form
Nope, I'm not using a BT module which supports an external antenna. In our testing, it seems the only time there is a signal issue is when you have the phone in your back pocket while driving, and that's uncomfortable anyways.
Thanks!
-Ted
Mods
My Build/OCD thread
Old Fri, Jun-14-2019, 05:21:27 PM   #396
ZiMMie
Reputation: 0 ZiMMie is on a distinguished road
Germany
Originally Posted by t3ddftw View Post
I could have sworn ZiMMie answer your guys, but I'm not seeing it. https://www.bluebus.dev has the pre-order form
Thanks!
-Ted
I initially did but deleted it to post a lengthy post and then got side track at work.
For the people on the pre-order list, you will not be disappointed.
For starters sound quality is better than anything on the market for our platform.
Sent from my Redmi Note 5 using Tapatalk
#E36S54 #CSLWannabe #TTFS @Mykesf
Jump to top ZiMMie is offline   Reply With Quote
Old Fri, Jun-14-2019, 05:47:36 PM   #397
t3ddftw
The BlueBus Guy
t3ddftw's Avatar
Sounds like you finally got your PCBs finished -- awesome!
Mods
My Build/OCD thread
Old Fri, Jun-14-2019, 06:59:46 PM   #398
rbg
Reputation: 0 rbg is on a distinguished road
What is the music bitrate when you stream over bluetooth? Also is the circuit of DAC proprietary or it is more like a one from TI datasheet? Thank you and again great job you've done!
Jump to top rbg is offline   Reply With Quote
Old Fri, Jun-14-2019, 07:15:11 PM   #399
t3ddftw
The BlueBus Guy
t3ddftw's Avatar
The module defaults to AAC for streaming as it has better frequency response than SBC. It achieves a max bit rate of about 250 kbps.
The DAC implementation matches pretty well with the TI datasheet. The project is open source, so you can actually see the implementation here on page 2: https://cadlab.io/project/1479/maste...ZUJ1cy5zY2g%3D
The PCB layout is also available there.
The circuit has changed a bit since this commit, as I have removed the TS5A22364 switch and moved to the PCM5122 DAC, rather than the PCM5102. The only difference is that there is software control via SPI/I2C, so I can fiddle with the registers of the DAC to achieve the best setup with the greatest control.
Mods
My Build/OCD thread
Old Mon, Jun-17-2019, 03:34:23 PM   #400
Whitehawk8
Whitehawk8's Avatar
Reputation: 0 Whitehawk8 is on a distinguished road
Well now that I've read through more updates I can't wait. Please tell me it'll be here soon!!!
Side note: Not 100% sure if I already signed up for a preorder. is it okay if I simply submit another order?
2003 M3 StahlGrau Metallic | Beisan | JB Racing | Koni | CMP | TMS | OEM SSK
Jump to top Whitehawk8 is offline   Reply With Quote
a2dp, bluetooth, ibus
Discussing Interest in a fully integrated A2DP Bluetooth solution? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
