Old Fri, Jun-15-2018, 10:33:47 PM   #1
t3ddftw
t3ddftw's Avatar
Reputation: 0 t3ddftw is on a distinguished road
Default Interest in a fully integrated A2DP Bluetooth solution?
Hey all,
I've begun working on a bluetooth module for my car that will fully integrate with the I-Bus, allowing me to see audio meta data on my nav screen (or Business CD) as well as retain all OE controls. On top of that, I'm thinking about adding some goodies to the module, such as:
* Logging where the car goes (based on the GPS info sent over I-Bus)
* Logging any time the vehicle is overrevved while cold (> 3k RPM while under 65C)
* Keeping the clock in sync with GPS time
* Adding OBC data to the "CD" view of the Nav Screen, so you can see audio metadata _and_ OBC data.
* Allowing you to set the Pin and display name of the Bluetooth module
Long term goals include making an app to allow you to retrieve all logged data and control device settings. I also plan on checking with the E39 and E38 communities to see if they would be interested. The I-Bus is pretty similar on these platforms, so supporting other vehicles should be trivial.
Is there any interest for something like this from the community? I'm about halfway to an MVP, so now's the time to gauge interest.
I should add that If there's interest, the price point I'm targeting is < $200 USD.
Update 2019-03-25: The pre-order website is up at https://www.bluebus.dev
-Ted
2006 M3 ZCP 6MT Interlagos Blue on Cinnamon interior
Mods
Engine: Full Beisan Systems VANOS rebuild
Transmission: CDV Delete
Exterior: Smoked Corners | Black Side & Kidney Grills | Painted Reflectors
My Build/OCD thread
Jump to top t3ddftw is online now   Reply With Quote
Old Fri, Jun-15-2018, 11:10:12 PM   #2
heinzboehmer
heinzboehmer's Avatar
Reputation: 0 heinzboehmer is on a distinguished road
Default Re: Interest in a fully integrated A2DP Bluetooth solution?
Definitely interested
Jump to top heinzboehmer is offline   Reply With Quote
Old Fri, Jun-15-2018, 11:16:12 PM   #3
benzthis
benzthis's Avatar
Reputation: 0 benzthis is on a distinguished road
Bring it.im interested.
Jump to top benzthis is offline   Reply With Quote
Old Fri, Jun-15-2018, 11:19:50 PM   #4
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Looking forward to more information, as I am not sure I fully understand all of what this does, but it sounds like something I'd be interested in once I learn more about what it does and the capabilities/purpose. New products for this platform are always welcome.
IG: DrM3anM3
Mods: Genuine OE CSL Bumper, Both Karbonius and Streamline CSL Airboxes, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized HJS Race Catted section 1, SS 2.5" Twin-Piped Oversized Custom section 2, Custom Oversized Supersprint muffler, Catcam's Billet 280/272 cams, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, Brembo GT6 (front) + GT4 (rear) BBK, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune, SMG Pump Relocated.
For Sale: BNIB OE CSL Wheels
Camshaft Group-Buy, OE CSL Bootlids, Supersprint Headers/Exhaust thread, New Supersprint Oversized Twin-Piped Section 2
Old Fri, Jun-15-2018, 11:23:20 PM   #5
speedblind_az
Reputation: 0 speedblind_az is on a distinguished road
I'm in. I had a GROM in my M5 and will eventually add something similar to my M3. Happy for something better.
Jump to top speedblind_az is offline   Reply With Quote
Old Fri, Jun-15-2018, 11:51:11 PM   #6
t3ddftw
t3ddftw's Avatar
The basic gist is that the module will plug into the vehicle and "replace" the CD player functionality with Bluetooth instead. It will also display the Title, Album and Artist on either the Business CD screen or the Nav Screen. All of the OE buttons (Pause/Play, Forward, Backwards, Steering wheel, etc) will be retained so that you can control playback.
It'll be like a what DICE was for iPods back in the day.
A couple other things I forgot to mention:
* The project firmware and hardware will be fully Open Source under the BSD license.
* The firmware will be upgradable, so as I develop features, you can deploy them to your modules (likely via USB cord).
* I'm toying with the idea of integrating the OE microphone so that I can delete the stock TCU and still take phone calls via the car speakers.
Mods
My Build/OCD thread
Old Fri, Jun-15-2018, 11:56:04 PM   #7
R1pilot
Reputation: 0 R1pilot is on a distinguished road
Interested
Jump to top R1pilot is offline   Reply With Quote
Old Fri, Jun-15-2018, 11:56:08 PM   #8
t3ddftw
t3ddftw's Avatar
As far as I know, the GROM adapters won't show you metadata on the CD / Nav display, right?
If so, that would definitely make my module an improvement.
Mods
My Build/OCD thread
Old Sat, Jun-16-2018, 12:53:38 AM   #9
Paulo M
I have a Grom, and it works well. Unfortunately the connection is glitchy as hell. Gotta pause then play, reset mode on nav, etc.
If yours has the functionality of a firefly minus the exposed wires, And auto self charging like a Grom (turns off completely with no charging) then I’m in.
BREMBO APEX DIXIS
Old Sat, Jun-16-2018, 01:19:17 AM   #10
t3ddftw
t3ddftw's Avatar
If yours has the functionality of a firefly minus the exposed wires, And auto self charging like a Grom (turns off completely with no charging) then Iím in.
That Firefly looks gross. I already have a semi-successful I-Bus project (https://github.com/tedsalmon/DroidIBus) where I was able to hash out the bugginess of interfacing with the I-Bus.
What do you mean by this, though?
Do you mean, have the unit turn off when the key is removed?
Mods
My Build/OCD thread
a2dp, bluetooth, ibus
Discussing Interest in a fully integrated A2DP Bluetooth solution? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
