Old Sat, Jun-08-2019, 01:55:47 PM   #21
Trans3900
Reputation: 0 Trans3900 is on a distinguished road
Default Re: SMG * 0 bar * Help me find a correlation
Yes, because the cog light comes on right away withing 1 min. No way is over heating that fast I get error code56. I had pulled this code on INPA with out driving it and just by turning switch On kind of frustrating
Jump to top Trans3900 is offline   Reply With Quote
Old Sun, Jun-09-2019, 05:40:22 AM   #22
SMG cog light
That round piece with the slot is the coupler for the electric motor shaft to the smg toothed gear pump. Take it out and clean it very well. You will notice that the side that goes to the smg pump tooth gear has a wider/bigger slot and side that mates to the motor has a smaller/slimmer slot.
Make sure they are mated well to both shafts and make sure you put a lot of the hi-temp performance grease onto it just like the original grease that you cleaned off from it.
Jump to top SMG cog light is offline   Reply With Quote
Old Tue, Jun-11-2019, 05:14:25 AM   #23
Trans3900
I did cleaned it but i didn't put High Temp Grease , The Motor Primes, after i start the car cold, the Cog light comes on, Would that be the reason why the light comes on?
Old Tue, Jun-11-2019, 06:12:33 PM   #24
SMG cog light
Grease is required for all coulping/moving parts. It reduces friction and prevents the motor from seizing and getting stuck. You can burn out your motor if it gets stuck, due to lack of grease. There is grease for your drive shaft, grease on your axles. Grease on your hubs and bearings. There is even tons of grease on the original smg pump coupler. the new kit even comes with grease. Why you would not install it the way it was intended is beyond me.
Old Tue, Jun-11-2019, 11:48:10 PM   #25
Trans3900
yes, you are right , i will removed and put the grease on it
Discussing SMG * 0 bar * Help me find a correlation in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
