Old Fri, Aug-04-2017, 01:48:36 AM   #1
Barish_76
Barish_76's Avatar
Reputation: 0 Barish_76 is on a distinguished road
Default Passing emmision readiness test with 02 sensors off
Hey guys Im moving to Ontario Canada and I hear they do emmision testing where scan tool is hooked up and they look for Emmision monitors ready on the scan tool. I have the rear 02 sensors turned off with my TTFS tune and Im wondering if anyone has run into this problem and what is the solution?
Thanks
VF480 kit
Jump to top Barish_76 is offline   Reply With Quote
Old Fri, Aug-04-2017, 02:49:27 AM   #2
toy4to
Lemonade Tycoon
Reputation: 0 toy4to is on a distinguished road
Default Re: Passing emmision readiness test with 02 sensors off
If you have the test done and you fail both times for monitors not ready, you can still have the two speed idle test done. My car is also supercharged and I recently had my e-test done. With an AA tune, I was able to have the regular obd2 test pass successfully.
Jump to top toy4to is offline   Reply With Quote
Old Fri, Aug-04-2017, 03:23:39 AM   #3
95bullet
95bullet's Avatar
Reputation: 0 95bullet is on a distinguished road
I am in Toronto and tune my car myself to pass emissions. If you have any issues with the ttfs tune pm me and I'll help you out.
Jump to top 95bullet is offline   Reply With Quote
Old Fri, Aug-04-2017, 04:26:33 AM   #4
Barish_76
Barish_76's Avatar
Two speed idle test done? How will that help me pass the 02 sensors not showing ready though?
VF480 kit
Old Fri, Aug-04-2017, 11:21:58 AM   #5
toy4to
Lemonade Tycoon
Just fail the obd2 scan tests two times, then they'll do the two speed idle test. By fail, I mean that the tests will indicate those monitors are not ready. They'll ask you to come back the next day and after 40km has been driven. Once again, those same monitors will not be ready when tested. They will then do a two speed idle test.
Old Fri, Aug-04-2017, 07:18:03 PM   #6
Barish_76
Barish_76's Avatar
Ok now I understand but may I ask when they do a two speed idle test the car will be idling and will they not clearly smell the fumes from the exhaust with no cats on it and know Im catless?
VF480 kit
Old Fri, Aug-04-2017, 08:03:34 PM   #7
Napalm
Reputation: 0 Napalm is on a distinguished road
I have always wondered if turning the check engine light/rear O2s off can also set the monitor - or if it simply disables the light, and leaves the monitor un-ready.
I asked TTFS once, and couldn't get a straight answer.
I guess you guys are confirming that the monitors stay 'un-ready' with these ECU tunes?
2006 Carbon Black ///M3 ZCP
Jump to top Napalm is offline   Reply With Quote
Old Sat, Aug-05-2017, 11:51:32 AM   #8
Barish_76
Barish_76's Avatar
Yes it seems the monitors say unready with the rear 02 sensors being off.
VF480 kit
Old Sat, Aug-05-2017, 11:59:29 AM   #9
toy4to
Lemonade Tycoon
Yes, confirmed, they will show up as 'not ready.'
BTW, where will you be moving to?
Old Sat, Aug-05-2017, 12:02:15 PM   #10
toy4to
Lemonade Tycoon
I didn't know you were castless. I'm not sure how your emission levels will be. I'm running a euro setup and it's different than your setup.
Discussing Passing emmision readiness test with 02 sensors off in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
