Old Fri, Mar-10-2017, 03:07:44 PM   #41
Flow
Flow's Avatar
France
Default Re: Anyone able to run VIN to check rod bearing TSB?
Originally Posted by K0nArtist View Post
2/10/2005 at 14,293 miles recall done.
May I ask in what tool you look this up ?
AIR and ISPA Light have no information concerning this.
Just wondering
Edit : I'm using AOS online FWIW.
2004 M3 TiAg / LSB SMG
Old Fri, Mar-10-2017, 03:44:17 PM   #42
///NotEvnMyBDay
///NotEvnMyBDay's Avatar
Reputation: 0 ///NotEvnMyBDay is on a distinguished road
Can someone do a quick check? I also wonder since a lot of the parts on my engine are labeled 2003, but my car was built in 2001....
Thanks in advance!
WBSBL93462JR13483
2002 E46 M3 - CB on Imola
1987 635csi - Black on Natur
1987 635csi - Black on Lotusweiss
Jump to top ///NotEvnMyBDay is offline   Reply With Quote
Old Fri, Mar-10-2017, 04:59:59 PM   #43
K0nArtist
Reputation: 0 K0nArtist is on a distinguished road
Thanks in advance!
WBSBL93462JR13483
Looks like your car had the engine replaced in 2003 due to spun bearing. And it had the bearings replaced on the new engine in 2004 at 30,950.
Jump to top K0nArtist is offline   Reply With Quote
Old Fri, Mar-10-2017, 05:14:22 PM   #44
///NotEvnMyBDay
Well that answers that....I always wondered.
Thanks a ton!
Old Fri, Mar-10-2017, 05:28:40 PM   #45
K0nArtist
This is information your dealers should be providing you guys if you own the car.
Old Fri, Mar-10-2017, 05:45:53 PM   #46
yosshaa
Proud ZCP Owner
yosshaa's Avatar
Reputation: 0 yosshaa is on a distinguished road
11/16/2004 at 8,919 miles recall done.
Retail date on that far is 11/22/2002
Weird, the carfax doesn't show this record which is fine because carfax misses things but it doe report a 10,000 mile inspection on 11/10/2004... no millage was reported.
Probably should call the dealership directly and see if I can get any details out of them.
never mind, called the dealership directly and they confirmed.
Thanks again!
2006///M3-ZCP-SMG-IB/Dove
43,779 E46 M3's produced for NA
26,202 E46 M3 Coupes
2,410 E46 M3 Coupes with ZCP Package
843 US / 54 CA ZCP in Interlagos Blue
366 US / 21 CA ZCP in Interlagos + SMG
154 US / 6 CA ZCP in Interlagos with N5TT (Dove Gray)
76 US / 2 CA ZCP in Interlagos + N5TT (Dove Gray) + SMG
WTB 1 Rear mint ZCP wheel no tire or center cap needed P/N 36112282999
Jump to top yosshaa is offline   Reply With Quote
Old Fri, Mar-10-2017, 08:41:19 PM   #47
Jazzkat
Reputation: 0 Jazzkat is on a distinguished road
+1 on this. i figured out where most of the dealer performed "maintenance" happened on my car. Local to me. Paid a visit to a service advisor and got full history that was not detailed on Carfax.
Jump to top Jazzkat is offline   Reply With Quote
Old Fri, Mar-10-2017, 11:50:20 PM   #48
michalt95
Reputation: 0 michalt95 is on a distinguished road
Would you be able to check for wbsbr93432ex21977 ?
Thanks in advance!
Jump to top michalt95 is offline   Reply With Quote
Old Mon, Mar-13-2017, 03:10:20 AM   #49
Newswartz
Newswartz's Avatar
Reputation: 0 Newswartz is on a distinguished road
Can anyone check mine as well?
Wbsbl93413jr20732
http://www.m3forum.net/m3forum/image.php?type=sigpic&userid=215618&dateline=15216  66489
Dinan Samco RPI Rogue UUC
iForged Mason Turner Rogue Brembo
AKG Redish Spal ST StatusGruppe
TurboToys Beisan Bilstein VinceBar
Jump to top Newswartz is offline   Reply With Quote
Old Mon, Mar-13-2017, 04:00:59 AM   #50
emin911
Reputation: 0 emin911 is on a distinguished road
I cant seem to find any info on my either, if someone can please look it up if its not too much trouble. Thank you
WBSBL93404PN55099
Jump to top emin911 is offline   Reply With Quote
Discussing Anyone able to run VIN to check rod bearing TSB? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
