Old Wed, Mar-08-2017, 03:45:02 PM   #1
Oldylr
Reputation: 0 Oldylr is on a distinguished road
Default Anyone able to run VIN to check rod bearing TSB?
Looking at an '02, wanted to know if the rod bearing TSB had been done. I called the local dealer and all they could tell me about was the airbag recall. Can anyone check for me?
Jump to top Oldylr is offline   Reply With Quote
Old Wed, Mar-08-2017, 04:16:45 PM   #2
Slowmobile
Na Na Na Na Na Na Na Na
Reputation: 0 Slowmobile is on a distinguished road
Default Re: Anyone able to run VIN to check rod bearing TSB?
Have you tried BMWs official recall page thing? I am not sure if it would show whether or not it has been done by might as well give it a try.
Legen... Wait For It... ///M
Jump to top Slowmobile is offline   Reply With Quote
Old Wed, Mar-08-2017, 04:19:22 PM   #3
Oldylr
Yea, it only brings up the air bag recall. Apparently the passenger side has been done but not the driver's side yet
Old Wed, Mar-08-2017, 04:34:22 PM   #4
K0nArtist
Reputation: 0 K0nArtist is on a distinguished road
What's the VIN?
Jump to top K0nArtist is offline   Reply With Quote
Old Wed, Mar-08-2017, 04:36:10 PM   #5
Oldylr
Wbsbl934x2jr18234
Old Wed, Mar-08-2017, 04:37:34 PM   #6
K0nArtist
Rod bearings done at 27,267
Old Wed, Mar-08-2017, 04:39:07 PM   #7
Oldylr
Thanks!!
Old Wed, Mar-08-2017, 11:06:34 PM   #8
cmenard
Reputation: 0 cmenard is on a distinguished road
Same question. Mind checking one more? WBSBL93432JR16079
Thanks
Jump to top cmenard is offline   Reply With Quote
Old Wed, Mar-08-2017, 11:14:16 PM   #9
Wilusk89
Drago
Reputation: 0 Wilusk89 is on a distinguished road
Thanks
Claim Number: 982720
Repair Order Number: 131471
Repair Order Date: 10/05/2004
Claim Mileage: 21,416
Authorization Number: 0
Claim Center ID/Loc ID: 15268-01
AG Dealer Code: 15268
Defect Code: 0011940100
Defect Description: E46 S54 Replacing connecting rod bearing shells and connecting rod bolts if necessary
Defect Dealer Comments: SIB #11-04-04 LC 422 M3 S54 CON ROD RECALL \ --0011940100-- \ R&R CON ROD BEARINGS AND BOLTS WP2,72FRU
Item Type Item Code Item Description Qty Claimed Qty Accepted
Sublet 4 OIL,LUBRICANTS ETC
Labor 0055115 REPL.ROD BEARINGS,BOLTS+PROGR.DME 72 72
Part 11131437237 Gasket Steel 1 1
Part 11410395192 Parts kit, bearing shells 1 1
Part 11247834310 Connecting rod bolt 12 12
Jump to top Wilusk89 is offline   Reply With Quote
Old Wed, Mar-08-2017, 11:16:24 PM   #10
cmenard
Greatly appreciated!
Discussing Anyone able to run VIN to check rod bearing TSB? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
