Old Fri, Apr-19-2019, 07:00:44 PM   #51
bryce2113
Reputation: 0 bryce2113 is on a distinguished road
Default Re: e46 M3 Special Tool Rental thread
Anyone have a subframe/differential bushing removal tool available to rent? I am doing subframe reinforcement over the next couple weeks and am replacing all the bushings while at it, including differential bushings with poly and need the tool to remove.
Please PM me if you have something available or suggestions for tool rental. Otherwise I may have to buy the Schwaben Subframe & Differential Bushing Tool from ECS?
Thanks in advance.
Jump to top bryce2113 is offline   Reply With Quote
Old Wed, May-15-2019, 08:18:59 PM   #52
M3_Pilot
I have an RTAB tool for rent. Located in Southern California.
2004 Jet Black/Cinnamon 6MT
@jet.m3
Old Thu, Jun-20-2019, 12:57:27 PM   #53
jbfrancis3
Reputation: 0 jbfrancis3 is on a distinguished road
Looking for ARP bolt stretch gauge for rent, please let me know and I will get in touch.
'05 M3 Convertible, Carbon Black/Cinnamon.
Jump to top jbfrancis3 is offline   Reply With Quote
Old Fri, Aug-09-2019, 12:35:14 AM   #54
stukreit
Reputation: 0 stukreit is on a distinguished road
Default Re: e46 M3 Special Tool Rental thread: INPA dl pointer or CD
I am struggling with a botched install of INPA on my laptop. All the links and instructions that I have
found online are dodgy and at best entertain me with small progress but no enchilada.
So I am stupid. Time for a fresh install.
Seeking a recently known good pointer to the INPA packages or file share, or a CD to install. Even better,
if you're in the SF Bay Area (I'm in Palo Alto) I'll buy you coffee or enchiladas to help me get
this thing working.
I have done the plumbing and wiring for SMG relocate. I need INPA to burp and train the SMG.
There's a recent Burkhart pump motor on it and I can hear it run, but the cog icon is lit on the dash
and obdii error codes P0760, P0978 are presenting "solenoid circuit C"
Jump to top stukreit is offline   Reply With Quote
Old Sat, Aug-10-2019, 11:38:06 PM   #55
mrgizmo04
mrgizmo04's Avatar
this thing working.
Stuart, convert to manual...I kid (maybe).
Just texted you.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sun, Aug-11-2019, 01:00:03 AM   #56
bigjae1976
this thing working.
Thereís a good DIY on E90 Post to install INPA.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Sat, Aug-17-2019, 11:58:54 PM   #57
BlazenXLT
We've had one yes, what about second breakfast?
BlazenXLT's Avatar
Reputation: 0 BlazenXLT is on a distinguished road
Anyone with an airbag reset tool?
Jump to top BlazenXLT is offline   Reply With Quote
Old Sun, Aug-18-2019, 12:23:48 AM   #58
INPA can do it.
Old Thu, Aug-29-2019, 07:38:06 PM   #59
albino09
Engineer
Need to rent an RTAB tool in the Nashville area. Will pay for shipping and a deposit.
Old Wed, Sep-04-2019, 04:19:01 AM   #60
02_LSB
My vanos tools are back if anyone needs them.
LSB/Black. Brembo, TC Kline Double Adjustable, Full Supersprint, Beisan, Rod bearings, RACP plates + Bar + Too much Polyurethane....itís a money pit, donít buy one.
Jump to top 02_LSB is offline   Reply With Quote
Discussing e46 M3 Special Tool Rental thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
