Old Wed, May-23-2018, 04:54:36 PM   #41
rubthefurrywall
Reputation: 0 rubthefurrywall is on a distinguished road
Default Re: e46 M3 Special Tool Rental thread
Hi, does anybody have a tool for ECU live diagnostics? I am located in california bay area
Jump to top rubthefurrywall is offline   Reply With Quote
Old Thu, May-24-2018, 07:25:47 AM   #42
mrgizmo04
mrgizmo04's Avatar
I have a schwaben handheld tool. What are you looking to do? PM me.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Thu, May-24-2018, 10:07:17 PM   #43
rubthefurrywall
PM sent - I am chasing down the infamous p01637/p0121/p0221 drive by wire issues. Swapped TPS by oil filter and at throttle actuator, EML/SES light went away for 100mi and had full power/throttle then came back on. I'm picking up a used good pedal to see if its that before I fully swap the throttle actuator
Old Thu, Oct-18-2018, 09:11:09 PM   #44
UFoh
Reputation: 0 UFoh is on a distinguished road
Vouching for DJAM3, I rented his timing tools to do the beisan fixes with no problems
Jump to top UFoh is offline   Reply With Quote
Old Wed, Nov-07-2018, 03:27:00 AM   #45
s54nuub
s54nuub's Avatar
Reputation: 0 s54nuub is on a distinguished road
Does anyone have the torque angle wrench needed for the rod bearing job? This is the last thing I need to find before I can do it.
Jump to top s54nuub is offline   Reply With Quote
Old Wed, Nov-07-2018, 03:28:54 AM   #46
bigjae1976
I have a snap on digital torque wrench.
http://www.m3forum.net/m3forum/showthread.php?t=602708
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Wed, Nov-07-2018, 11:16:38 AM   #47
Why didn't you submit it for this thread?
Old Wed, Nov-07-2018, 01:10:56 PM   #48
bigjae1976
Not 100% sure this is ready for prime time. I want to try renting it out a couple of times to see how it goes.
Old Wed, Nov-07-2018, 01:26:22 PM   #49
I have the same torque wrench, and would never rent it out
Old Wed, Nov-07-2018, 03:42:38 PM   #50
bigjae1976
I have two of these, one that I donít rent out. Donít like it as much to do lug nuts but itís awesome for angle torque pulls. Iíd rather have a clicker for the lug nuts.
Discussing e46 M3 Special Tool Rental thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
