Old Fri, Sep-14-2018, 08:58:15 PM   #111
///M3_Michael
///M3_Michael's Avatar
Reputation: 0 ///M3_Michael is on a distinguished road
Default Re: Torque Spec thread
Quite possibly the greatest thread in the history of threads! That 98 page doc is amazing and timely as I'm currently doing Giubo, CSB and shocks/struts/springs
Thank you!
2003 ///M3 6MT Slicktop | Phoenix Yellow | Black Nappa | Koni Yellow / Eibach Pro kit | GC Street Plates | 18" Apex ARC-8 | Fabspeed Headers | Fabspeed catted Section 1 | SGT Resonated Section 2 | RE El Diablo | buildjournal B-spec V2.1 tune | Infinity | JL Audio
Jump to top ///M3_Michael is offline   Reply With Quote
Old Sun, Oct-28-2018, 09:36:29 PM   #112
Red Rider
Red Rider's Avatar
Reputation: 0 Red Rider is on a distinguished road
Front king pin nut (46mm) 214 ft lbs (wheel bearing replacement)
Jump to top Red Rider is offline   Reply With Quote
Old Wed, Jan-16-2019, 05:17:20 AM   #113
Avplayer
Avplayer's Avatar
Reputation: 0 Avplayer is on a distinguished road
Excellent link. Used this today when I was tightening up my front diff bolt
No more clunking
Jump to top Avplayer is offline   Reply With Quote
Old Wed, Feb-13-2019, 03:13:13 AM   #114
ctdriver86
Reputation: 0 ctdriver86 is on a distinguished road
Hey Guys, does anyone know if there is a torque sequence for the main crankshaft caps? I can't seem to find info. THanks!
Jump to top ctdriver86 is offline   Reply With Quote
Old Sat, Mar-09-2019, 12:33:20 PM   #115
TTKlaus
Reputation: 0 TTKlaus is on a distinguished road
Originally Posted by Flow View Post
Hey everyone !
In addition to the torque spec thread that is stickied in this section, I thought I would do a little PDF files with the actual drawings and torque values.
Easy to read, print, and have in the garage.
Describing torques with this is a lot easier than writing the name of the actual part and torque value.
Here you go for the download : DOWNLOAD (updated 2017/3/3)
Please do not hesitate to comment for anything that could correct / make the file better !
Stay up to date !
Simple give me your email address using this link : http://goo.gl/forms/P19InSMaob
and I will send you update warnings about the file
Change log
Code:
2016 April 8
- Corrected drive shaft center bolt (connecting both parts) torque : 97 Nm with loctite
- Corrected differential subframe front bolt tightening torque (90 Nm for the stud / 77 Nm for the nut)
- Better display of transmission / guibo / propshaft connecting bolts torques
- Corrected front reinforcement plate angle torque (90 +/- 30 and not 90+30)
- Corrected front strut brace nuts torque (24 Nm instead of 40 Nm)
- Corrected front top strut housing torque
2016 April 10
- Added information for main bearing screws
- Added information for cylinder head screws
- Added torque for sealer plug for rocker arm shaft
- Added torque for 11111736005 bolt
- Corrected header -> cylinder head bolt (15 Nm M7 as per TIS)
- Corrected spark plug torque (23 3 Nm as per TIS instead of 25 Nm)
- Corrected value for knock sensor to engine block torque
- Corrected torque value for cranshaft pulse generator (9 Nm instead of 5 Nm)
- Corrected value on holder on oil cooler line
- Corrected value on headers to section 2 bolts (differentiation US version / Euro version)
- Corrected clutch master cylinder to pedal assembly bolt torque
- Corrected values for clutch hydraulic pipes coupling bolts
- Added complete gearbox tightening torques information (including SMG specific torques)
- Corrected reverse light switch (16 Nm instead of 20 Nm)
- Corrected guibo to transmission output flange torque
- Corrected stabilize link torque
- Added steering column adjusment screw torque
- Added steering colum sliding piece nut torque
- Corrected torques on rear upper / lower control arms
- Added door hinge and closing bar nuts torques
- Added front impact absorber tightening torque
- Corrected seat belt slider to body bolt torque
2016 August 23
- Added information about differential (Axle cap bolts + preload...)
2017 January 31
- Added lots of information for engine rebuild
- Made a permanent link to latest version : http://sawashie.free.fr/M3/TorqueSpec/E46%20M3%20TORQUE%20SPECS%20LR.pdf
Errata
Code:
N/A
To be checked
Code:
- Alternator pulley torque ?
Original post :
This is excellent! Thank you for the time spent on this!
TTKlaus
Jump to top TTKlaus is offline   Reply With Quote
Old Tue, Jun-25-2019, 06:24:59 AM   #116
Eric46M
Eric46M's Avatar
Reputation: 0 Eric46M is on a distinguished road
Default Re: Torque Spec Thread
Wow thank you sir !
Jump to top Eric46M is offline   Reply With Quote
Old Tue, Jun-25-2019, 07:00:07 AM   #117
Flow
Flow's Avatar
France
I see this file is still useful I just logged back on this forum because I want to put my car back on the road, when I get some time...
I received a PM about a mistake in it, I'll look into it shortly.
2004 M3 TiAg / LSB SMG
Discussing Torque Spec thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
