Old Wed, Dec-30-2015, 09:13:11 PM   #41
e30TurboDave
e30TurboDave's Avatar
Reputation: 0 e30TurboDave is on a distinguished road
Default Re: E46 M3 - S65 Conversion Notes / DIY
Originally Posted by cozmo kraemer View Post
Are you going to be able to keep the steering rack in the stock location? Moving it down is a problem encountered in the FD swaps and bumpsteer becomes a big issue.
Looking at dropping the cross brace down about 1/2 inch and keeping the arm mounts in the same place....I customizing most likely.
Sent from my SM-N910T using Tapatalk
Jump to top e30TurboDave is offline   Reply With Quote
Old Wed, Dec-30-2015, 10:23:40 PM   #42
captaintexas
captaintexas's Avatar
Reputation: 0 captaintexas is on a distinguished road
Looks awesome!
Jump to top captaintexas is offline   Reply With Quote
Old Wed, Dec-30-2015, 10:27:32 PM   #43
Originally Posted by m3dragon View Post
Epic user ms54 99% sure
Did they do more than one s65 e46?
I asked about one particular one, and they said mss65... But that doesn't mean all of them are (if there's multiple).
Old Wed, Dec-30-2015, 10:31:18 PM   #44
Drewster
Drewster's Avatar
I highly doubt they would add the extra physical spark and fuel injection drivers rather than just re-code an MSS65...
Old Wed, Dec-30-2015, 10:35:42 PM   #45
Amadeus
Stationary Action
Amadeus's Avatar
Reputation: 0 Amadeus is on a distinguished road
If one is 99% sure of MSS54 and 99% sure of MSS65, you guys need to revaluate your percentages! Not leaving enough room for what you don't know
Jump to top Amadeus is offline   Reply With Quote
Old Thu, Dec-31-2015, 12:04:04 AM   #46
DanAvoN7
Reputation: 0 DanAvoN7 is on a distinguished road
Are you trying to keep the stock hood for exterior appearance/looks? Just curious as why you wouldn't use an E92 hood (as it has a larger "hump")? That would give you additional clearance for the intake manifold up top and likely not require as much modification/clearance of the front subframe.
04 BMW M3 6spd - Alpine White/Black
Apex ARC-8 w/ Hankook Z214, Apex ARC-8 w/ BFGoodrich R1, MCS 3-way Coilovers, GC Race Camber Plates, PFC BBK, Turner Camber Arms, Turner Sway Bars, Turner Subframe bushings, Turner Solid Diff Bushings, Turner Solid RTAB, Turner Solid Control Arm bushings, Treehouse Racing FCAB, Reinforced Subframe, OS Giken LSD, Rogue Engineering Transmission Mounts, SGT Headers, SGT Section 1, AFE Stage 2 Intake, EPIC Tune, Dinan Exhaust, Bimmerworld Airdam/Splitter/Dive Planes, Bimmerworld V2 Wing, TC Design Roll Cage, Racetech RT4119, Scroth Profi 2 Harness
NORCAL Rod Bearing/Vanos/Valve Adjustment/Inspections Member Feedback
Jump to top DanAvoN7 is offline   Reply With Quote
Old Thu, Dec-31-2015, 12:49:02 AM   #47
Would only have to be the spark drivers that are added; the injection drivers are already present. Maybe vanos drivers too if you want to be able to control and diagnose the two banks separately (and honestly, I'm not even sure the vanos signalling schemes are compatible between the two generations)
All that said, I have doubts that they're actually using an MSS5x variant of any sort.
Old Thu, Dec-31-2015, 01:05:56 AM   #48
aab010799
aab010799's Avatar
Reputation: 0 aab010799 is on a distinguished road
So awesome!!!! Can't wait to see the finished product. I've been waiting for someone to do one of these!
-Alex
'02 Imola Red E46 M3 6MT
Jump to top aab010799 is offline   Reply With Quote
Old Thu, Dec-31-2015, 04:06:43 AM   #49
e30TurboDave
No we are using the stock e46 m3 hood.
Old Thu, Dec-31-2015, 08:03:01 AM   #50
DanAvoN7
Yes, I see that you are using the stock e46 m3 hood I think you misread my post
Discussing E46 M3 - S65 Conversion Notes / DIY in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
