Old Tue, Dec-29-2015, 11:01:28 PM   #21
bimmerfan08
bimmerfan08's Avatar
Default Re: E46 M3 - S65 Conversion Notes / DIY
Figured you would take a crack at this swap sooner or later with how much interest you've shown in other conversion threads. Looking forward to the end result.
"The most difficult part of figuring out a car, the engineering, has been accomplished. Repairs and maintenance are simply dissembling parts and reassembling them." - bimmerfan08
Jump to top bimmerfan08 is online now   Reply With Quote
Old Tue, Dec-29-2015, 11:09:12 PM   #22
Originally Posted by m3dragon View Post
More of the I wanted to not leave a challenge unfinished. Also we as E46 nuts need a "street" gtr in the wild. While not 100% real will be as close as we mortals can afford.
The sharing info is becuase of my belife in our forum as a community. If the forum was not as such i would not share not be on here. Why I do the GB for rod bearings. Takes time and I get nothing for it. Like with the CSL knowledge is power so we all beniffet.
Sacramento. Anyone is welcome to come and see but bring cloths you can work it. If you are here you are helping work on car in some capacity.
One issue at a time buddy. First issue is get it to fit and all the plumbing. Then code and wires. I will share as I have better idea. Current plan is to use MS54HP with extra chip to drive the extra cylinders. Then code it to work with current gauges. This will allow the car to still be E46 for abs, dsc. Only a plan but will update once there. Until then focusing on how to fit big foot in TINNNYYYYY shoe.
Awesome.
Can't wait to hear more! If you can make it work properly with a modified mss54hp, that's about as clean of an install (electronically) as we could hope for! Can't wait to see how this unfolds.
While you're in hardware side, might be worth thinking about adding knock sensors to the block
Old Tue, Dec-29-2015, 11:15:55 PM   #23
bimmerfan08
And a dipstick.
http://store.bimmerworld.com/e9x-m3-...kit-p2042.aspx
Old Tue, Dec-29-2015, 11:24:23 PM   #24
Originally Posted by bimmerfan08 View Post
Since the s65 is map based (and has no maf), I assume they plan to build this around csl engine management... And the csl can display oil level in the cluster. Soooo, they might not NEED to use a dipstick.
Old Tue, Dec-29-2015, 11:26:10 PM   #25
Drewster
Drewster's Avatar
Define "extra chip"... I think you would have better luck with either two DME's (e92 and e46) or an Infinity rather than getting the older MS54 to try and control two more cylinders
Old Tue, Dec-29-2015, 11:57:08 PM   #26
TC2
BF.c Class of 2012
TC2's Avatar
Reputation: 0 TC2 has disabled reputation
The MSS52 was used in the M5 and that DME is nearly identical to the MSS54.
'84 325e 32k miles|'98 328i 80k miles|'01 Z3 84k miles|'05 M3 63k miles|'05 M3 103k miles|'03 M5 98k miles|'99 M Coupe 104k miles|'00 M5 105k miles|
|'03 C4S 127k miles|'07 Z4 M Coupe 68k miles|'02 PTS X50 996 Turbo 111k miles|'06 X5 4.4i 56k miles
'05 IB|ZCP|Impuls Cloth|Slicktop|SMG II
'05 IR|ZPP|Black Leather|No HK|6MT
Front wheel bearing installation tool for rent. PM me.
Jump to top TC2 is offline   Reply With Quote
Old Wed, Dec-30-2015, 12:06:59 AM   #27
Probably won't display the right oil level without some work though (since the CSL software is calibrated to how much oil the S54 pump holds and whatnot). We don't really have any of those extra curves and scalars identified.
If I were doing the swap, I think I'd try to retain the MSS60 personally and translate the messages between the new and old busses. I don't like the idea of losing knock control (and can't really add sensors without casting a new block afaik)
Old Wed, Dec-30-2015, 12:47:12 AM   #28
GrdStorm
Reputation: 0 GrdStorm is on a distinguished road
Bad azz
Jump to top GrdStorm is offline   Reply With Quote
Old Wed, Dec-30-2015, 01:55:02 AM   #29
m3dragon
CSL M3 / Raptor / 12C
m3dragon's Avatar
Reputation: 0 m3dragon is on a distinguished road
I have both DME's and will be some figuring out there. As we know Epic has been running a S65 in a race car using a MS54HP dme so it can be done. As with this project it has been done before but no data shared. Changing that one post at a time.
NorCal drive organizer guy
Drive database and photo locations
NorCal CSL build thread - US to CSL Conversion
Jump to top m3dragon is offline   Reply With Quote
Old Wed, Dec-30-2015, 02:28:07 AM   #30
svre46
svre46's Avatar
Reputation: 0 svre46 is on a distinguished road
Judging by your last build this one should be amazing. Thanks for taking the time to document the whole thing. Looking forward to the final result.
In The Garage
02' ///M3 Vert (SOLD)
07' 750li Individual (Daily)
06.5' Aston Martin V8V Coupe (Toy)
16' X1 xDrive28i (Wife's)
Jump to top svre46 is offline   Reply With Quote
Discussing E46 M3 - S65 Conversion Notes / DIY in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
