Old Tue, Dec-29-2015, 03:37:42 PM   #1
m3dragon
CSL M3 / Raptor / 12C
m3dragon's Avatar
Reputation: 0 m3dragon is on a distinguished road
Default E46 M3 - S65 Conversion Notes / DIY
This project stems from this build thread:
http://www.m3forum.net/m3forum/showthread.php?t=469407
Currently myself and a few friends are in the process of figuring out how to install the motor. This thread will eventually be turned into how you can do it on your own but for now it will document notes as we find them.
Notes so far on attempting to fit the S65
  • Shield around brake master cylinder stick in to far / Will need to be cut
  • Lower cross member might need to be modified
  • Steering nuckel will need to be changed on steering rack / angle looks like should be fine
  • Transmission brace will on S65 transmission will need to be made to keep proper alignment
  • Front drive shaft of e90 will need to be shortened and mated to the rear E46 M3 drive shaft
More to come
NorCal drive organizer guy
Drive database and photo locations
NorCal CSL build thread - US to CSL Conversion
Jump to top m3dragon is offline   Reply With Quote
Old Tue, Dec-29-2015, 03:46:56 PM   #2
m3dragon
m3dragon's Avatar
Default Re: E46 M3 - S65 Conversion Notes / DIY
Fitted engine to proper height under the hood. Below are the notes as of 12/29
Please excuse the "roughness" of the posts. I am posting this as we complete things and to share progress for all. I will edit and make these cleaner once we are done.
  • Cross member that the front control arms attach to has to be cut and dropped down about a inch. This will require cutting it and making it gusseted to go lower.
  • Area around ABS was cut and provided the needed clearance to get motor in
  • AC pump had to be removed in order to fit engine in frame. This will need a custom bracket to me mounted lower to keep AC.
  • Headers will need to be custom made in order to clear frame rails. These will be basically long tube headers to get proper gap.
  • Steering column will need to be longer and creative route.
  • Engine mounts will be custom in order to mount to stock points.
  • Engine and trans once set to proper depth, the shiftier linkage lines up with the stock E46 M3 shift tunnel.
Currently we are working on getting the motor in place (obviously). Once this is done we can work on each of the areas that need to be fixed. A custom oil pan may need to be made as it site very low currently. As we work through each issue I will post it.
Ultimate goal will be to offer a DIY for those of you that want to do this that can in regard to fabrication. Depending on the pain of this I would be willing to do this again but would asked to be paid for time if you don't want to make it yourself. You supply all the stuff and will make it.
As for coding and wiring I am taking the car to performance techniques in the bay to connect the wires and engine to a S54 ecu. They would also do the coding to make it work which is beyond my skill set.
Old Tue, Dec-29-2015, 03:47:21 PM   #3
m3dragon
m3dragon's Avatar
Place holder for later 2
Old Tue, Dec-29-2015, 03:47:36 PM   #4
BMWjunkie11
That guy
BMWjunkie11's Avatar
Reputation: 0 BMWjunkie11 is on a distinguished road
I can't wait to see it done
2002 Jet Black/Grey ///M3
Full Supersprint Race Exhaust l PSDesigns Velocity Stack Kit l TMS Pulleys l TTFS Custom Alpha-N Tune l Work Brombachers
"Bags are for dead hookers"
Jump to top BMWjunkie11 is offline   Reply With Quote
Old Tue, Dec-29-2015, 04:09:33 PM   #5
kokgo20
kokgo20's Avatar
Why did u choose S65 and not S62?
Build thread---------- INSTAGRAM ------------ROTREX REBUILD-------------Now offering custom digital gauges
2004 SMG PY/BLK - 600 TCKline - CPI Headers & resonated Sec1- Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - SDW monoball RTABs - AKG subframe bushings - Multi color AEs - FR-X 3.0 Projectors - Smoked Side markers - Euro bumper - V1 with hard wire & Stealth one - M Track Mod - ZCP steering rack - Dual LI - CSL Style diffuser - SCZA Exhaust - E9x Door handle LED retrofit - SCZA CSL bootlid - VEI systems custom air vent A/F & boost gauge - VEI custom air vent Water temp & oil pressure guage- Active Prima plus + HTE performance tune - Custome fab intercooler - Mishimoto Radiator & Oil cooler - H&R front Sway - UUC camber arms - keyless & push to start system - clear bra - interiors red stitching contrast - Apex PS7s - 16" Spal fan
Old Tue, Dec-29-2015, 04:40:22 PM   #6
TEASE///M3
TEASE///M3's Avatar
Reputation: 0 TEASE///M3 is on a distinguished road
He's trying to get as close to a real M3 street GTR as you can. (which used a 4.0 V8 that arguably was the test platform for the s65)
Untitled by . McFarlin, on Flickr
2006 M3 ZCP Interlagos Blue Manual Cinnamon 6MT Slicktop
RIP 2002 M3 Tiag Dove Grey 6MT
Jump to top TEASE///M3 is offline   Reply With Quote
Old Tue, Dec-29-2015, 04:50:20 PM   #7
Awesome. Please document EVERYTHING!
... damn it, this is making me want a second e46 M3, if it becomes viable..
What's your ecu plan?
Old Tue, Dec-29-2015, 05:04:38 PM   #8
AXDB
AXDB's Avatar
Reputation: 0 AXDB is on a distinguished road
YESSSSSSS. I love seeing these. Even though I can only dream of doing the swap. PerkM3 did the S62 and has documented quite a bit as well. Should be a good resource to bounce ideas off.
2003 M3 Carbon Black / Cinnamon
Jump to top AXDB is offline   Reply With Quote
Old Tue, Dec-29-2015, 05:32:19 PM   #9
w3fl3x
...yummy...
w3fl3x's Avatar
Reputation: 0 w3fl3x is on a distinguished road
Thanks for documenting the process!
Been playing with the idea of selling the diesel for a second e46 m and this will make it that much more tempting! Need to keep torque for daily driving duty.
Jump to top w3fl3x is offline   Reply With Quote
Old Tue, Dec-29-2015, 06:59:44 PM   #10
Brian N
wubalubadubdub
Brian N's Avatar
Oh baby. I can't wait to see this done. This is my dream swap.
-My Journal-
Discussing E46 M3 - S65 Conversion Notes / DIY in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
